Remodeler
Trade: Remodel
Metal Cold Roof Question .....
On one of my remodel job the client just had to have a metal roof and hired his own metal roof contractor.
I only do shingle roofs, no metal. Here is my question for you metal roof installers. When I install a cold roof I create a real open air space atop of the decking, underneath the shingles. No insulation in that space as it would negate the whole cold roof concept as it is my understanding. This metal roofing contractor is running 2x4 sleepers over the existing shingle roof, then he installs rigid insulation in the space between the 2x4s (I assumefor rigidity of the flimsy metal panels he uses). With insulation in the space between the metal and the "decking", is this still considered a cold roof? Thanks ........
... factor it in and move on ... |
Re: Metal Cold Roof Question .....
The term "cold roof" isn't something I am familiar with, being in Oklahoma, but the practice you are describing is acceptable. You stated the roof panels are "flimsy"?
I guess I need to get up to speed on cold roofing from the northerners, but it sounds like you really don't like metal roofing.
#3 | |
I haven't heard that term in quite a few years but I haven't worked in the mountains in a while either.
copied: Quote:
In the mountain areas I worked way back, cold roofs were not required on 12/12's or steeper.
#5 | |
Remodeler
Trade: Remodel
Re: Metal Cold Roof Question .....Quote:
By the way ... in the European Alps cold roofs are making a huge comeback. Rake boards of over 2 feet are not uncommon.
If the metal panels are on EPS insulation, I would venture to say they will not pick up any heat from the attic, and be as cold as the outside temps...so I guess it would qualify as a cold roof. One of the benifits of Oklahoma is never having to deal with those issues. However, I noticed last week traveling through New Mexico, most of the new construction is going metal.
Trade: Roofing
Check and see if he is leaving an air gap between the insulation and his matal panels. We do similar systems, but are carefull to leave an 1" or better air space. Sometimes have had to use 2x6 sleepers.
Jim |
Expert Roofer
if the air space is above awell insulated heated area where no heat escapes to the bottom of the decking ,it`s technically a cold roof application,where there air temp above and below the roofsheathing are similar and don`t attract condensation as the dew point is at the lower insulated ceiling area
I think the the op is talking about roof sheathing then sleepers then roof sheathing again then shingles to create a cold roof. That is how I did it and how I believe it is still done in the Colorado high country.
#10 | |
Remodeler
Trade: Remodel
With a metal roof who really cares. There just won't be any ice damming or leaks anyway. I am just talking about the principle of selling a cold roof when it is not. Thanks .........
#11 | |
Trade: General, roofing and insulation contractor
Your right, it's not a cold roof.
3rd gen,it's in the blood
Trade: roofing
ya'll are killing me.
You have ONE advantage over me.....you can kiss my butt and I can't!! |
Remodeler
Trade: Remodel
Trade: roofing
if you don't know,don't post.
for the time it takes to post what you think is....you could google and find out.
Trade: roofing
or ask me
Re: Metal Cold Roof Question ..... |
#18 |
Trade: roofing
actually I'm full of it and had to google it myself,just wanted some excitement.
#19 |
Remodeler
Trade: Remodel
I know how to build a conventional cold roof. My question was specific to metal roof, which is something I don't do.
Thanks .......
#20 |
I don't think you will find a "national standard" on Cold Roofs. Your local building dept should have the only answer that really matters.
| Tight Space Stucco Question - Undershot between roof sections | CGofMP | Construction | 3 | 03-24-2009 09:10 AM |
| Low Pitch Roof solutions | Fixer | Roofing | 4 | 02-18-2007 11:09 AM |
| Torch down(flat roof) leaks BAD...can you give advice ASAP? | Detail Guy | Roofing | 21 | 01-16-2006 02:36 PM |
| Pricing question for Baltimore rowhome roof | AmateursGuide | Roofing | 11 | 11-10-2005 03:15 PM |
| Do You Need A New Roof ??? | Perfect Roofing | Roofing | 0 | 02-10-2005 02:46 AM |
