Metal Around Dormers - Roofing - Contractor Talk
Old 12-26-2016, 09:09 PM   #1
Jchresidential's Avatar
Trade: Custom homes
Rewards Points: 12
Hi all, been a long while since it posted , so long I had to set up new login
So I have a question I am installing gran rib on a house we are building and it's has two dormers in the garage roof .my question is do any of you install full sheets up around dormer and tuck it under the vally flashing.I never do metel and when I do its usually strait runs. I see that fabral recommends cuting the sheet under dormer valley and then there is a lap seem on each side of dormer but I don't want to have a seem on the sides of dormer when all rest of sheets a full length
Jchresidential is offline
Old 12-26-2016, 09:43 PM   #2
Trade: Custom homes
Rewards Points: 12
Re: Metal Around Dormers
Here is the best pict I have of garage dormers
Old 12-26-2016, 10:51 PM   #3
PatChap's Avatar
Trade: Roofing, eaves
Rewards Points: 132
Youll need to split the sheets at the valley.
PatChap is offline
The Following User Says Thank You to PatChap For This Useful Post:
Tom Struble (12-27-2016)
Old 12-27-2016, 06:37 AM   #4
mrcat's Avatar
Trade: Pole Barns, Residential Framing
Rewards Points: 652
+ 1 on splitting the sheets, just make sure you add a little extra length to those ones, don't just cut it out of a full sheet or you'll wind up short at the top.
Sent from my SM-G900V using Tapatalk
mrcat is offline
Old 12-29-2016, 11:44 AM   #5
Been around
Mr Latone's Avatar
Trade: Roofing
Rewards Points: 1,578
I think you should just wing it and hope it all comes out OK. Sounds like that's the plan.
My New Year's Res is to be more helpful. Still have a couple days to get there.....
Above all, a good roof
Mr Latone is offline
The Following 2 Users Say Thank You to Mr Latone For This Useful Post:
PatChap (12-29-2016), Tom Struble (12-29-2016)
Sealing Metal Valley Section artinall Roofing 20 11-07-2012 12:18 PM
shelf supports into metal studs cleveman Carpentry 17 04-17-2012 12:34 PM
Curbs for metal roofs? 232323 Roofing 7 01-26-2012 04:43 PM
metal cold roof question ..... Vermonster Roofing 30 09-06-2007 12:30 AM
