Look At This Roof...
Old 04-05-2008, 07:09 PM   #1
WilliamH's Avatar
Trade: GC Roofing, Siding, Gutters and Light Construction
I have a sub with 20+ years of experience installing roofs. In all that time, he has never installed a roof quite like this. I have been involved in many installations as well, but nothing like this either. Perhaps I'm making more out of it than I should. I thought I would post some pics here and see what you guys think. This is a pentagon shaped church with a domed roof. The dome is composed mostly of triangles intersecting to create the shape. Take a look at how the intersections come together. The look is somewhat like an inverted valley. The current roof just looks like it should leak (the way the sections come together). At least the current shingle is flat. I'll be installing a 50 year dimensional shingle. I think dimensional shingles would be more difficult to do than what's already installed (insuring no leaks), but that's what they want. I'm looking for any suggestions or comments. Is ice and water shield overkill if I have it installed along all these intersections. Is it even necessary.
I would appreciate any ideas or comments.
Here's the link to the pics http://www.h4built.com/cumc.htm
WilliamH is offline
Old 04-05-2008, 07:10 PM   #2
WilliamH's Avatar
Re: Look At This Roof...
Post 14
WilliamH is offline
Old 04-05-2008, 07:11 PM   #3
WilliamH's Avatar
Post 15
WilliamH is offline
Old 04-05-2008, 07:14 PM   #4
APPLIED RIGHT
johnk's Avatar
Trade: roofing
If you are ever worried about any intersection,protrusion,etc,use the ice and water.Better safe than sorry!
"A Roof is only as good as it is Applied"
johnk is offline
Old 04-05-2008, 07:15 PM   #5
Handle It!
MALCO.New.York's Avatar
Only in a Church could you find a NIGHTMARE such as that!!!
Lots 'O luck!!!
Ultimate Wisdom---------
MALCO.New.York is offline
Old 04-05-2008, 07:16 PM   #6
APPLIED RIGHT
johnk's Avatar
Trade: roofing
Are you trying to get your post count up?
johnk is offline
Old 04-05-2008, 07:18 PM   #7
Handle It!
Apparently!!!!!
What he did was post the original and found out he could not post a link. He then made 14 and 15, then went back and edited his original and added the link!!!!!
Pretty sneaky sis!
Old 04-05-2008, 07:20 PM   #8
WilliamH's Avatar
I had to get to 15 posts before I could insert a link.
WilliamH is offline
Old 04-05-2008, 07:23 PM   #9
WilliamH's Avatar
Originally Posted by MALCO.New.York View Post
Apparently!!!!!
What he did was post the original and find out he could not post a link. He then made 14 and 15, then went back and edited his original and added the link!!!!!
Pretty sneaky sis!
That is exactly what I did.
WilliamH is offline
Old 04-05-2008, 07:24 PM   #10
Handle It!
The only thing I have to add is that you are quite the sharp one. Yes? It took me a day or so to figure out the extent of the edit feature!!!! And I AM rather sharp!
Old 04-05-2008, 07:25 PM   #11
APPLIED RIGHT
johnk's Avatar
Trade: roofing
1 note on that roof-Yuuuuck!!!Not only would I use ice and water,but I'd flash it,gum it,glue it and screw it,lick it and stick itJust kidding,hope you priced it high and got most of the money up front.Bring your chalkline
johnk is offline
Old 04-05-2008, 07:32 PM   #12
dougger222's Avatar
Trade: Roofing Contractor
That would be a good roof to do if you are hurting for work and need money to pay your mortgage. Seen a few roofs like those over the years. My dad bid one several year ago and figured the biggest section of roof was under a bundle. The roof needed more ridge than shingles! He turned it down.
Seen some were they ran ridge on the transitions and others were they overlapped the shingles a few inches chaulked lines and cut them.
dougger222 is offline
Old 04-05-2008, 07:48 PM   #13
rooferpro
rooferboy's Avatar
Trade: Roofing and siding
Some 50 year shingles require open metal valleys ,did a job that was tear out all the valleys to install metal,to fix others roofers mistake.water actualy ran between shingles and because of design thickness caused leaks everywhere even with ice and water. Lots of cap on that one.
rooferboy is offline
Old 04-05-2008, 08:23 PM   #14
WilliamH's Avatar
My thoughts exactly regarding the 50 year shingle. There's so much more potential for water to go where to don't want it to go. I suppose contacting the manfacturer for their input would be a good idea.
WilliamH is offline
Old 04-05-2008, 09:28 PM   #15
tinner666's Avatar
Looks straight forward enough. Similar to a regular dome. I over lap the ridges. On this one, http://www.rooferscoffeeshop.com/sho...8&file=764&s=0, just overlapped 3" each way. They went 3" one way and cut them off. It's just felted. Even has tears in the felt. Never been an issue when the roof is correct.
I put 50 year on my house and weaved the valleys. Only trick I know of there, is I lay my valley shingles flat on the roof in the sun beffore weaving. I don't use them straight from the bundle. No problems.
Frank Slate Roof Repairs, Richmond, Va.
tinner666 is offline
Old 04-05-2008, 10:58 PM   #16
Al Smith
A W Smith's Avatar
I agree. looks pretty straight forward to me also. At least the roof surface isn't curved like a Islamic temple roof or a corner turret. If it was in my area I definitely would bid on it confident that others would be scared away.
Al Smith
http://www.awsmith.com
Last edited by A W Smith; 04-06-2008 at 10:44 PM. Reason: damn spell check is definitely being "Defiant"
A W Smith is offline
Old 04-05-2008, 11:17 PM   #17
WilliamH's Avatar
Thank you sir. Those are some great pics. I came to this forum because I want to be sure the roof is installed correctly. Many of you have much more experience than I do; I appreciate and value your opinions and comments. Have a great day.
William
WilliamH is offline
Old 04-06-2008, 08:48 PM   #18
Commercial Roofing
AaronB.'s Avatar
That looks like nothing but a money-maker.
I dont do a lot of shingles anymore, but for something like that, I would take the job.
That roof looks to be properly done. I have seen them with custom bent metal at the transitions, but I didnt like the look of it.
No cap needed on most of that.
http://www.roseroofing.net/
Seamless Industrial and Commercial Roofing Systems, Residential Repair. For Those That Demand Quality!
Free roof inspections within 12 miles of our locale.
AaronB. is offline
Old 04-06-2008, 10:40 PM   #19
Mark
mmitchell's Avatar
Trade: Beautiful Exteriors-Roofing,Siding,Windows,Doors,Gutters,Sticky Stone and Brick,Custom Storm Doors
I agree that's money. No a lot of low ball competion for that one. They will want a roofer they trust and they will value their opinion. Someone mentioned getting the manufacturer involved and that's the right idea. If you don't know the regional rep for the manufacturer your distributor will. I also agree with the idea that a laminate is not right for that job. I would rather see a hatteras or slateline for the bend and overlap installation and the wind resistance. I always use winterguard liberally but the synthetic felt would be good also with this job applied with plastic caps. The issue with 50 year shingles in valleys is interesting. We do a cut lace valley with 50 year but also use metal with many of the ultra heavy weights as they are required by the manufacturer. With Certainteed 50 year it's the contractors call. Never run from your professional challenges-they are your profit potential if you've been around long enough to know what profit really is this is the time to earn some, Get some baby!!!!!!!!!!!
mmitchell is offline
Low Pitch Roof solutions Fixer Roofing 4 02-18-2007 11:09 AM
Help tying in this roof to addition jaymay75 Framing 0 06-18-2006 10:54 PM
Torch down(flat roof) leaks BAD...can you give advice ASAP? Detail Guy Roofing 21 01-16-2006 02:36 PM
Do You Need A New Roof ??? Perfect Roofing Roofing 0 02-10-2005 02:46 AM
