Lightweight Faux Cedar Shingles
Old 04-02-2018, 04:57 PM   #1
Joe Wood's Avatar
Rewards Points: 526
In coastal So Cal all the cedar shingle roofs get covered in mildew pretty quick, it looks terrible, so I'd like to look in to faux shingles that don't attract mildew, that I can install over skip sheathing like regular cedar shingles, looks good from below, and is not too heavy?
and then how about individual flat faux colored (I'd like a light blue) smooth roof tiles, again individual tiles installed over the skip?
I've looked at a few online but never seen any in person,
https://www.bravarooftile.com/roof-t...ar-shake-roof/
https://shakeguys.com/2017/07/compar...hake-products/
https://www.davinciroofscapes.com/products/shake/
https://woodsshop.com/
Joe Wood is offline
Old 04-02-2018, 10:17 PM   #2
Bull Trout's Avatar
Rewards Points: 1,104
Re: Lightweight Faux Cedar Shingles
have you tried copper strips on the roof? I don't know if there are ones that would fit the look of your structures, but would be a way to continue using cedar
Bull Trout is offline
Old 04-03-2018, 08:02 AM   #3
Joe Wood's Avatar
Rewards Points: 526
The copper might help with mildew but not over the entire roof area but thanks anyway, still looking for those faux shingles.
Joe Wood is offline
Old 04-04-2018, 09:52 AM   #4
Joe Wood's Avatar
Rewards Points: 526
So who has actually worked with one of the synthetic shingles? I could sure use some recommendations.
Joe Wood is offline
Old 04-11-2018, 08:09 AM   #5
Been around
Mr Latone's Avatar
Trade: Roofing
Rewards Points: 1,570
DaVinci are pretty good looking. I have installed the Slate, but not the shake. there is also one called "Fancy Shake"
I did not look up the installation over skip sheathing, so that's on you.
I don't know if distribution reaches your neck of the woods.
Above all, a good roof
Mr Latone is offline
Old 04-11-2018, 08:30 AM   #6
Joe Wood's Avatar
Rewards Points: 526
Are those davinci heavy and dense My Latone?
Joe Wood is offline
Old 04-28-2018, 09:04 AM   #7
Been around
Mr Latone's Avatar
Trade: Roofing
https://www.davinciroofscapes.com/pr...width-davinci/
+/- 300# / sq
What they call a "valley shingle" is a solid version. The field shingles have a hollowed out molded rib pattern underneath which makes them weigh less. The solid shingles are for where an end cut would show.
I assume the valley shingles weigh more than the field shingles, but the use is limited to exposed cuts.
weaving cedar shingles MakitaMan Windows, Siding and Doors 4 03-31-2014 02:51 PM
woven corners for cedar shingles woodworkbykirk Windows, Siding and Doors 21 12-06-2012 06:02 PM
Lightweight concrete alternative in a condo DanFreysinger Flooring 17 11-14-2012 09:10 AM
cedar shingles wink Roofing 22 10-08-2008 06:36 AM
Cedar shingles Nail banger Windows, Siding and Doors 6 07-09-2008 08:42 PM
