Laminate Cutting
This is the first time I've had to cut
vent hoods into laminate/dimensionals. I have three of these, and the first one was a real bear! Broke three hook blades cutting in one little Broan hood. ![]() Is there a trick? Better tool? Magic incantation? Gonna try some old fashioned linoleum knives on the next one. Maybe nukes if that doesn't go well.
catalfanoc
![]() Trade: roofing and remodeling
Re: Laminate Cutting
old metal shears
Roofing and Architectural
Trade: Roofing and Architectural Metals
A lot of my guys use old steel airplane snips. I've always used my hook blade, I guess it just takes practice.
Trade: Thoroughbred Roofer
In a tight place, a small propane torch to soften up the shingle (not directly on the shingles, but over them to warm them up). They should be like butter after that. It'll make for a nice clean cut with a hook blade (I prefer AJC's deep hook blades).
Or...you could use shears.
"I've been up on the roof. I know what those guys go through. My whole life has been about making that profession respectable." Ken Hendricks www.SolutionsRoofing.com |
Trade: roofing
the best hook blades buy far are the Sheffeilds made in UK . you can get them in bulk at 1-800-282-5233. But when you get into the 50 year shingles you should use a pair of metal snips, spray some wd-40 on them to make them cut like butter. they also have shingle cutters for the heavy weight lams. good roofers dont make hack cuts
Roofer
Make sure to wipe the WD off before you get on the roof tho,
WD is not compatible with shingles. Thanks for the phone number, whats the price of them?
Thanks guys
We'll see how that goes. I used the 24" shears for straight cuts when I replaced roll with step flashing once before, but that didn't seem "right". So now I know, trick is.... ain't no trick. You're welcome??? ???
#8 | |
Roofer
Re: Laminate CuttingQuote:
thanks for the phone number RooferJim, i was refferring to the number he posted for the hook blades.
| Laminate over Laminate | dayspring | Finish Carpentry | 16 | 10-03-2007 08:11 PM |
| Miter Joints In Laminate Flooring ?? | AL MURZYN | Flooring | 6 | 12-27-2006 10:15 PM |
| Laminate Floor | Richard | Flooring | 15 | 12-22-2006 12:59 PM |
| proper way of loading of brush from a cutting pail | Zeebo | Painting & Finish Work | 7 | 08-11-2006 11:58 PM |
| Determining Manhours for rolling vs. cutting - your suggestions would be helpful | Zeebo | Painting & Finish Work | 9 | 06-02-2006 06:12 PM |
