Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Roofing
Old 09-21-2009, 09:31 AM   #1
Trade: general
Joining a flat roof to sloped shingled roof
Our covered porch has a flat roof on top and then sloped shingles in the front. What options are there for the joining, so that it isn't this ugly shiny strip. the roofer is saying that there are no other options.
Thanks
emandel is offline   Reply With Quote
Old 09-21-2009, 09:40 AM   #2
Trade: general
Here is a pic of the structure
Old 09-21-2009, 11:01 AM   #3
MrRoofer's Avatar
Trade: Roofing
Become a contractor, then DIY .
'I'm living on the edge!'
MrRoofer is offline   Reply With Quote
Old 09-21-2009, 11:16 AM   #4
JonM's Avatar
Copper edge...in time it will turn a nice patina color...will look good with the brick and the style of the house...
JonM is offline   Reply With Quote
Old 09-21-2009, 12:05 PM   #5
stop botherin' me!
Grumpy's Avatar
Trade: Roofing Siding Gutters Windows
The roof membrane should overlap onto the shingles about 3" and be secured with a typical roofer nail about 1' apart. Then a cover metal can be installed to cover the membrane. The metal doesn't need to be "shiny" it can be a color coordianted "factory painted) metal. It could also be copper like above suggested. If the membrane they are using is torch applied, do not use aluminum. If the metal is properly matched, you won't see it from the ground. in addition, there will need to be a metal flashing where the front porch roof meets the brick wall, so it'll match just fine even if you can see it.
LOL now if they are using galavanized and saying there are no other options, that's a problem. Kynar steel will cost just slightly more than galvanized steel. Aluminum trim coil is petty much the norm, but I stress again, not to use aluminum if the low slope membrane is torch/heat applied since the heat will warp and bend the aluminum.
-Grumpy
Chicago Gutters Chicago Roofing
Grumpy is offline   Reply With Quote
mounting conduit on existing flat roof bhe Electrical 24 02-15-2009 09:42 AM
Low Pitch Roof solutions Fixer Roofing 4 02-18-2007 11:09 AM
Help tying in this roof to addition jaymay75 Framing 0 06-18-2006 09:54 PM
Need help designing Roof for addition jaymay75 Framing 21 06-17-2006 09:47 PM
Flat roof over garage leaking under exterior walk out door IHI Roofing 18 05-30-2006 09:28 PM
