Infrared Thermography....experience? Any Comments?
Old 07-26-2004, 09:58 PM   #1
Thunder Johnson
Guest
Thunder Johnson's Avatar
Posts: n/a
Question
Anyone have experience or any comments on infrared thermography as used in roofing?
Old 07-26-2004, 10:09 PM   #2
Teetorbilt's Avatar
Re: Infrared Thermography....experience? Any Comments?
I can explain the process from a number of different angles (sattelite, local and arial).
In essence it will show thermal differences on the surface of the roof.
Why is this important?
Teetorbilt is offline
Old 07-27-2004, 10:14 AM   #3
Thunder Johnson
Guest
Posts: n/a
I've heard arguments for and against it. I've never seen one done, have seen the devices at a trade show. I like what I've seen, trying to get some thoughts from someone who conducts inspections or has had one done for them.
The arguments I've heard against it is that you can adjust the sensitivity of the tool to show "some type" of problem or make a minor problem appear severe.
Old 07-27-2004, 01:21 PM   #4
Bah Humbug!
Grumpy's Avatar
Very common in diagnosing the insulation of flat roofing. If the insulation is wet it should be replaced.. and determines the general area of a leak. If the insulation is wet it will show as a bright color in the scan.
Grumpy is offline
Old 07-27-2004, 02:05 PM   #5
Teetorbilt's Avatar
Thunder, You have piqued my interest and as I woke up in 'slowmode', I decided to do some investigating. What I found is way kewl and something that even an old guy (me) could do.
I placed a call to FLIR and will get back to you when they return my call.
Do you have any other manufacturers names or sites? I recognized FLIR from the military.
Old 07-27-2004, 04:02 PM   #6
Teetorbilt's Avatar
Thunder, I spoke with Mr. Louh at FLIR. In answer to your last question, the answer is yes they can be adjusted to do about anything that you want them to do including scaring a customer into uneeded repairs.
I figured that they would be pricey and they are. They recommended a B1 model (B is for building) that sells for a mere $10K, If you want something a little more versitile the E4 is a steal at $20K.
I think that I would ensure that there is a market prior to spending that kind of money.
Old 07-27-2004, 04:31 PM   #7
Thunder Johnson
Guest
Posts: n/a
Thank you for your responses.
I visited the FLIR booth at an expo. a few months ago and also talked to a preventive maintenance company that uses infrared. They told me you can rent a hand held for $750 a week and that they charge $750 for a 1 day evaluation and report. I'm not sure about software costs.
It appears this type of non-intrusive testing is becoming popular and they are constantly finding new uses for it.
I found an article about a thermographer who was offering it as an inspection service for boat buyers.
Old 07-28-2004, 01:59 PM   #8
Bah Humbug!
Grumpy's Avatar
there is definetly a market for ir scans in the commercial roofing industry. The IR scan has been part of every scope of work I have seen on commercial or large scale flat roofs when a tear off wasn't involved.
A sub priced a scan for me at $5,000 for 700 squares of roofing. I'd say the tool pays for it's self after a few scans.
There are other ways to "see" under the roof such as nuclear scans but I know nothing about these technologies.
Grumpy is offline
Old 08-05-2004, 07:37 PM   #9
jmorgan's Avatar
Trade: Roofing
I have a friend who does infrared scans. You guys are about right on pricing around here too. He does them at night, when the airs has cooled off. Very cool color printouts of the wet insulation areas. I used to have to take cuts every 10 sqs, sometimes more often, in the old days when I did flat industrial in LA. We had a 2 prong moisture meter that also worked (sometimes). I hated spending all day cutting and repairing the cuts. The new infrared cameras are great.
Jim
jmorgan is offline
Old 08-06-2004, 02:23 AM   #10
Teetorbilt's Avatar
I guess that I should have said that the E4 model (E meaining electrical) will show wiring heating as well as mechanical friction in drive couplings and bearings. A body could make a decent living at this.
Siding & Windows Sales needed - Chicago area - NO SALES EXPERIENCE Grumpy Help Wanted or Looking For Work 4 05-26-2009 03:51 PM
LP Smartside experience 58hydraglide Windows, Siding and Doors 1 05-11-2007 02:23 PM
Florida Licensing Service and Experience Requirements DoubleJ Contractor Licensing 0 03-21-2007 02:47 PM
Does anyone have experience on "galvanize coating"? mustardseed Painting & Finish Work 4 02-22-2007 05:46 PM
Experience denick General Discussion 17 08-11-2006 11:10 AM
