IceMelt On EPDM?
Old 11-18-2008, 08:02 PM   #1
Commercial Roofing
tekwrytr's Avatar
Trade: Commercial Roof Repair and Re-Roofing
IceMelt On EPDM?
My steamer is down for the duration, and with snow arriving soon, I am not too inclined to replace it until next year. Anyone have any experience using rock salt (sodium chloride) or IceMelt (mix of chlorides) on EPDM? I have tried to ask several manufacturers, and either get a runaround or a "warning" that "salt is corrosive."
I have an EPDM repair job with a puddle (now solid ice) of about 10 square, a half to a full inch thick. I need the ice off to repair it before winter sets in. Current temps are below freezing for a high, so anything that melts from escaped heat from the building refreezes at night. Lows are in low- to mid-twenties.
Steam is skatey, but if someone conscientious is doing it it can work. Unfortunately, that option is closed. Torches are out (this is EPDM). Any alternative suggestions?
Thanks
Commercial EPDM Rubber Roof Repair - Maintenance - Re-Roofing Exclusively. Serving the Twin Cities, MN Metro area since 2001.
http://www.tekwrytrs.com/roofing/
tekwrytr is offline
Old 11-19-2008, 08:18 AM   #2
Bah Humbug!
Grumpy's Avatar
Re: IceMelt On EPDM?
MY advice was going to be to ask the manufacturer but I can understand their run around. Get a big pot and boil water with a torch then pour it on the puddle?
Grumpy is offline
Old 11-23-2008, 12:38 PM   #3
MrRoofer's Avatar
Trade: Roofing
Ever heard of tires failing from salting the roads? Ever wondered where EPDM comes from? I dont imagine leaving big salt licks up there for the horses year round to be a good thing, but if used in moderation I'd say common sensically speaking what you want to do is ok. If not I would wonder about all those EPDM roofs in coastal areas next to the big salty seas...just my 2 cents, none of which were paid for by Firestone BTW, so you may want to take that with a grain of ....
'I'm living on the edge!'
MrRoofer is offline
Old 11-24-2008, 10:23 AM   #4
Bah Humbug!
Grumpy's Avatar
I don't think EPDM and road tires are one in the same. I'm sure road tire is very similiar, but engineered different to be way way more rugged.
If you intend to try this do it by first telling the customer that damage may occur and you aren't responsible, and on a very small area incase it does cause damage.
Grumpy is offline
Old 11-24-2008, 12:09 PM   #5
Capra aegagrus
Tinstaafl's Avatar
Torpedo heater.
Tinstaafl is online now
Old 11-24-2008, 01:11 PM   #6
APPLIED RIGHT
johnk's Avatar
Trade: roofing
Break up ice with a hammer and sweep it up?
"A Roof is only as good as it is Applied"
johnk is offline
Old 11-24-2008, 03:53 PM   #7
BULLHART's Avatar
Trade: Commercial Roofing Inspector/ Trainer
I break it and squeegee it
BULLHART is offline
Ballast Removal from EPDM Roof? tekwrytr Roofing 26 06-19-2009 05:12 PM
EPDM Questions big builder Roofing 21 10-11-2008 12:36 AM
EPDM and asphalt? tekwrytr Roofing 19 07-24-2008 08:46 AM
EPDM strap failure... orson General Discussion 3 04-12-2008 02:18 AM
Pictures of aluminum edge flashing for EPDM roof ??? epdmHelpNeeded Roofing 4 10-28-2006 05:03 PM
