Ice & Watershield Step Flashing? - Roofing - Contractor Talk
Old 06-01-2010, 02:16 PM   #1
MEL's Avatar
Trade: Roofing
Rewards Points: 516
Do you guys include ice and watershield under the step flashing as a standard feature?
MEL
MEL is offline
Old 06-01-2010, 02:35 PM   #2
Grumpy's Avatar
Rewards Points: 2,000
Re: Ice & Watershield Step Flashing?
Standard. I preflash all areas that will be later flashed with metal. This includes around skylights, chimneys, walls, pipes, any penetration, any area that will later receive metal. Some people same it's a band aid, some old time roofers say it's cheating, I say it's water tight and very cheap insurance. Cost? It adds $75 to an average residential job, sometimes more sometimes less.
-Grumpy
Chicago Gutters Chicago Roofing
Grumpy is offline
The Following User Says Thank You to Grumpy For This Useful Post:
apkole (06-01-2010)
Old 06-01-2010, 04:26 PM   #3
Lou the roofer's Avatar
Trade: Roofing
Rewards Points: 25
Only around skylights (Velux asks for it) and chimneys.
Lou the roofer is offline
Old 06-01-2010, 04:42 PM   #4
copper magnet
seeyou's Avatar
Trade: custom metal fabrication
Rewards Points: 512
I always do on tear-offs and usually on new construction as a temporary dry-in. And always on skylights.
seeyou is offline
Old 06-01-2010, 07:11 PM   #5
Andy@Aarco's Avatar
Trade: roofing
Rewards Points: 25
everywhere!!!!and cement !!!!!!
Andy@Aarco is offline
Old 06-02-2010, 08:15 AM   #6
Roofing and Architectural
Renegade's Avatar
Trade: Roofing and Architectural Metals
Rewards Points: 708
omg
Renegade is offline
Old 06-02-2010, 10:10 AM   #7
Grumpy's Avatar
You ice shield the entire roof deck in lieu of felt paper? I have had condensation problems when ice shielding the entire deck. I only do it when the customer request and make for darned sure to super charge their ventilation.
I forgot to mention valleys. We ice shield our valleys as well.
-Grumpy
Grumpy is offline
Old 06-02-2010, 12:33 PM   #8
MJW's Avatar
Trade: General Contractor, Roofing, siding, windows
Rewards Points: 1,772
In certain areas yes. If the siding underlayment and roofing is installed correctly it isn't neccessary in all situations.
We always do bottom 6 feet and valleys on anything heated.
MJW is offline
Old 06-02-2010, 11:23 PM   #9
dougger222's Avatar
Trade: Roofing Contractor
Rewards Points: 1,116
Are you running a third partial roll to get to 6 feet? So far can only get two rolls to get to 5.5ft. What's the secret?
J/K, spoken like the adjusters... J/K again, see it on a lot of contracts.
I agree with Thomas on this one. We both can get made full of all we want but I like the sticky stuff.
BTW, Velux's new skylight comes with a i/w type product that you must use to get the 10 year leak warranty.
dougger222 is offline
Old 06-03-2010, 07:23 AM   #10
BamBamm5144's Avatar
Trade: Everything Exterior, Mostly Roofing.
Rewards Points: 2,786
Lol. I just realized that the other day. Now I may use that as a selling tool.
I put in 4 new Veluxs' in april. They were different since I last put them in but I tell you what, I liked them a lot better.
BamBamm5144 is offline
Old 06-03-2010, 08:13 AM   #11
MJW's Avatar
It's 3 ft wide.....are we supposed to have an overlap or what...
Most guys seem to use a ton of it for re-assurance. My Dad still says, "it makes a bad roofer a decent roofer".
It definitely has it's place but these codes are a little ridiculous IMO.
I also have a piece of Certainteed sand I&W on my deer stand floor. It's been in the weather for 3 years now and it actually holds up much better than I thought it would.
True about the Velux. We just got some flashing kits last week and they came with small rolls of sticky paper.
MJW is offline
Old 06-03-2010, 08:56 AM   #12
Grumpy's Avatar
I have seen ice shield, just like modified bitumen, on 36" rolls and 39" rolls.
-Grumpy
Grumpy is offline
Old 06-05-2010, 10:54 PM   #13
Anderson's Avatar
Trade: Home improvement contractor
Rewards Points: 1,136
Speaking of ice shield, whats the difference between GAF's storm guard or weather watch??
Anderson is offline
Old 06-06-2010, 08:38 AM   #14
tccoggs's Avatar
Rewards Points: 874
weather watch is granulated and is for use under shingles, where storm guard is film surface and can be used in hi temp applications like under a metal roof.
I don't do much roofing, but I typically carry some storm guard to use as soft flashing around skylights, under step flashing, etc. Its a little more expensive than granulated, but it bond to itself better than granulated, and in hot weather the granulated stuff turns into a mess.
tccoggs is offline
Old 06-06-2010, 10:03 AM   #15
dougger222's Avatar
Speaking of Certainteed Winterguard versus the other brands I've never been impressed with any other brand. As a matter of fact some I've had to work with (home owners or builders bought) have been straight up garbage. The funny thing is the price at my yard for the Winterguard is cheaper than any other price out there for the other off brands.
See a lot of roofs being done without Certainteed shingles but with Winterguard.
Agree with Joe on the W&I requirements getting a little rediculous. Consider a house with a huge front overhang. This past Winter did a huge new roof for a builder and for the heck of it decided to ask the inspector how much W&I was needed on a front overhang detail. The overhang was at the front door were the roof was on a gable end and was about 7ft deep by 10ft wide. He said you have to go all the way back to the 2ft interior heated area, it was a 12/12!!! How much ice and snow is going to be sitting there? Not much! I would have done it this way anyways as the code is 2ft but it's still a huge overkill.
Have talked to inspectors in the past who said they would pass the W&I inspection with felt on at the unheated eave then ice and water at the heated area. This was in respect to houses with big front porches. Most inspectors want it from the bottom all the way up 2ft past the interior.
Old 06-06-2010, 10:04 AM   #16
dougger222's Avatar
BTW,
Cerainteed makes three types of Winterguard, Sand, Granular, and HT (high temp for under metal)
Old 06-07-2010, 10:16 AM   #17
Grumpy's Avatar
As far as my interpretation of the code, I understand the ice shield shoudl start at the gutter and extend past the warm wall 24". However yes, on unconditioned areas like porces or car ports that may possibly connect to a conditioned space on the same elevation, 15' of ice shield may be necessary to achieve code, but as we know, compltely un necessary. However you and I are at the mercy of the inespctor doing the inspection, and I have done it both ways where I start with felt on a car port, install a course or two of ice shield at the exteriior wall, then continue again with felt... Most times I just do as the code literally states so as to not have an argument later and at $75 a roll, it's worth just doing rather than arguing.
-Grumpy
Grumpy is offline
Old 06-07-2010, 06:44 PM   #18
Roofman20033's Avatar
Trade: Roofing
Rewards Points: 150
We follow Grumpy's routine to a tee when it comes to using ice guard!
Roofman20033 is offline
Old 06-14-2010, 04:59 PM   #19
becllc's Avatar
Trade: Consultant
Ice and water shield may be overkill, but if the turn the felts up 4" as recommended in ARMA, you have a cheap, but highly effective flashing under the step flashing.
becllc is offline
Old 06-16-2010, 08:53 PM   #20
Anderson's Avatar
I am using weather watch XT for the first time and let me tell you stay clear of this product. The backing is a white very thin plastic, which comes off great in the shade.
As soon as I got it on the roof, not super hot maybe 80-90. This backing came off in 4 inch strips.
Stick with paper backed in my opinion
Anderson is offline
Um, what is flashing ??? theflynner Roofing 13 03-20-2011 05:33 PM
Hardie Plank and Step flashing davinci Windows, Siding and Doors 7 04-28-2010 01:51 PM
Step Flashing vs. L-Shaped Flashing Knighton Roofing 24 12-29-2009 01:43 PM
step flashing question...is this your territory? Pennyroyal's Masonry 21 05-07-2009 11:38 PM
step flashing question. Pennyroyal's Roofing 3 04-08-2009 05:56 PM
