Trade: roofing
I&W Shield
Ive used every brand of I&W you can think of besides Grace up until now. Wow this stuff blowes everything Ive ever used out of the water. One question though I cant get it to do a split release on the back paper. I claims it has a rip cord release but it's no where to be found. My salesman couldnt find it either. So whats up with the back of this stuff, anyone know any tricks to make it do a splilt release?
Roofer
Re: I&W Shield
I have used grace quite a few times and never seen a split in the backing.
Grace is the toughest I ever used, but it's also the most damaging, I never use it except in dead valley situations.
Bah Humbug!
Re: I&W Shield
Some grace have the rip cord, some do not. I have seen both. The rip cord does make it a little bit easy to flop and layout.
The rip cord should be imbedded between the release paper and the back of the ice shield. It's a very very thin wire. It's located at the exact center of the ice shield. You may have to peel up a little bit of paper to find it. Once you find it simply pull it and it tears the paper. |
#4 | |
Trade: roofing
Re: I&W ShieldQuote:
Trade: framing/remodeling
Re: I&W Shield
The rip cord is there. It is extremely thin. Once you figure out where it is, it will be easier to find it the next time. Like Grumpy said, peel back the paper in the exact center and use a fingernail to separate the thin wire from the iceguard.
Trade: roofing
Re: I&W Shield
Thanks Warren. Is this so called rip cord visible with the naked eye because Ive pulled the paper back and cant see it? Im going to feel like an idiot tm when I find it and have to come back and let you guys know.
Re: I&W Shield
I feel the same way about the grace, superior to everyone else.
The ripcord is actually more embedded in the material than on the paper. There is a dotted line on the front of the material that indicates the center. Make a small slit in the end on the line and bend the material, you should see a small peice of monofiliment. Once you get it started, its easy to pull out and tear the paper. |
GC
Re: I&W Shield
Maybe use a stud finder.
Trade: roofing
Re: I&W Shield
I found the rip cord. i also found out it was sent to my supplier by mistake. Right now Im paying $72 for a 2 square roll, the next time they have to order Grace it will be around $110 per roll. Tomorrow Im going to buy whats left of the Grace and it will be my last time because Im not paying $110 for I&W. So is $72 for a 2 square roll of Grace a fair price?
Re: I&W Shield
You said yourself it was better than any that you have used. Quality comes at a price. Thats about what we pay here. I only use that for potential problem areas.
Trade: roofing
Re: I&W Shield
You're right Warren I did say that but I don't see it worth the money. Ill still use is it certain area just not a the eaves and in some valleys. Ill have close to a full pallet so it will last awhile.
Bah Humbug!
Re: I&W Shield
I'd kill for $72, We're paying about $100 here. Infact if it were $72 consistently I'd be using grace and grace only. You can get the cheap thin generic stuff for $50 a 2 square roll here.
| H&C Shield Crete Epoxy | 420sully | Painting & Finish Work | 20 | 05-27-2011 03:28 AM |
| Help, old shingles stuck to ice shield??? | 232323 | Roofing | 45 | 09-16-2009 04:27 PM |
| shield material | Cache | Painting & Finish Work | 28 | 02-10-2009 11:00 AM |
| MI Ice & Water Shield Reg Interpretation | lituani | Roofing | 3 | 10-26-2008 09:58 AM |
| I&W shield | shopman | Roofing | 23 | 03-09-2006 11:32 PM |
