I Need Help......
Old 11-27-2011, 08:44 PM   #21
KemoSabe
loneframer's Avatar
Rewards Points: 12,204
Re: I Need Help......
Originally Posted by carpentershane View Post
Yes it is and yes we do
Well, when it gets buried in snow, I guess you gonna have one hell of an ice dam somewhere downstream of that thing.
loneframer is offline
Old 11-27-2011, 08:47 PM   #22
Sawdust Sweeper
carpentershane's Avatar
Rewards Points: 28
I alerted the job super to this fact already... He was the one who put in the fan
"Perfection is an unachievable goal, the illusion of perfection is the work of a true craftsman. " LoneFramer
carpentershane is offline
Old 11-27-2011, 08:47 PM   #23
Tech Geek
WarriorWithWood's Avatar
Trade: Remodeling Guru
Rewards Points: 1,342
Is that shingle wrapped rake board done like that on purpose?
-Dennis
WarriorWithWood is offline
Old 11-27-2011, 09:03 PM   #24
KemoSabe
loneframer's Avatar
With the torch down, you most likely are in good shape in that area. I just think it could have been detailed more efficiently to simplify things.
Without a curbside view, it's hard to say what cosmetic effect my idea would have had.
I've had to frame my share of less than perfect roof lines. lots of areas with diverters, EPDM or fiberglass/resin.
i need help......-001-13-1.jpg   i need help......-008-2-.jpg   i need help......-014.jpg   i need help......-091.jpg   i need help......-092-2.jpg
Old 11-27-2011, 09:19 PM   #25
Sawdust Sweeper
Rewards Points: 28
loneframer;1339556]As the framer, I would have changed the design there. There should have been a diversion done starting from the ridge to the left, across to the roof on the right, creating 2 valleys that empty at or slightly beyond where the gutter on the right side ends. That rake on the right could have continued to plane into the rake on the left, eliminating the pocket.
I am having a hard time visualizing this...
Old 11-27-2011, 09:25 PM   #26
Sawdust Sweeper
Rewards Points: 28
yup
Old 11-28-2011, 05:02 AM   #27
copper magnet
seeyou's Avatar
Trade: custom metal fabrication
Rewards Points: 512
Originally Posted by Tom Struble View Post
not that kind of help
i need to make this mess work somehow
currently the room just below the valley is showing water damage,looks to me the step flashing just ends at the stone
seems like i need to get the first step past the stone so it can drain out
idk... any suggestions?mason/metal/roofing guys?
sorry about the pic,h.o. took them
Is that real stone or lick & stick? I'm guessing the later. I can't see because of the ladder, but it appears the stone is laid on the roof for a few inches below the corner.
Set a 2x4 on the roof, narrow side up. Ride a grinder on top of it and cut the stone away over the shingles. Step flash and kickout to behind the house wrap. Install a piece of PT 2x4 in the void created and counter flash over it with cu.
edit: and move that downspout as mentioned earlier.
seeyou is offline
The Following User Says Thank You to seeyou For This Useful Post:
Tom Struble (11-28-2011)
Old 11-28-2011, 05:12 AM   #28
KemoSabe
loneframer's Avatar
Essentially, the roof to the right would not end with a fascia. It would continue down to meet the other roof, forming what I refer to as a dead valley, because there would be no slope to divert water.
To achieve a pitch, I would put a sleeper down that starts at the ridge on the left of your picture, following a level line over to the roof on the right.
From the corners of the sleeper, to the point where the two roofs meet on the open end, strike lines and lay valley plates. Fill in a few jacks and sheath it.
It looks like you would end up with enough slope to lay I&W and simply shingle the area.
The other thing I see that troubles me is the outlet on the gutter. It appears that it simply dumps into the corner of a suspect area. I see major ice build-up in that corner after a good snowfall.
Old 11-28-2011, 06:41 AM   #29
Roofing Sage
2ndGen's Avatar
Trade: Thoroughbred Roofer
Rewards Points: 2,020
Tom,
Here's what I'd do:
1. Remove shingles to deck
2. Remove siding 3' vertically
3. Re-frame the roof against the siding to continue down onto the next roof.
This will eliminate that open space where water/ice/snow will build up and
I'd use a closed-valley.
4. That's going to leave you some fascia area right next to the stone
(a right triangle shape). That can be strategically trimmed with coil
stock to blend in.
5. I'd wrap all of that with Ice & Water shield and go up at least 24" up the wall before step-flashing it in. Also, I'd build up a "cant" from the wall out just for a little security; Not an aggressive height, but just enough to convince the water to not hang around there.
6. When you re-install the leader, use a "B" elbow to point the water towards the other roof (not directly "at" the valley). I'd form my own elbow there. It looks like an factory "B" might shoot the water past the gutter. What angle? Like my old man taught me "think like water" when you decide what angle to make it and I'd cut the bottom of the elbow at the same pitch of the roof (to control any heavy rain).
[You could also re-locate that little leader (downspout) and install it on the front of that wall, turning the elbow directly "into" the gutter. It might not be as clean looking as running it on the side is, but it will definitely eliminate a lot of issues with it and personally, I think it would look better than the extra 4"-6" that it's extended past the rake now.]
7. Where those leaves are settling? It looks like built-up underlayment is causing a little damming there.
I've attached the pics with how I'd alter them.
If you do go ahead with relocating the leader,
I'd use standoff brackets like these for that stone
(they'd be a nice clean install):
"I've been up on the roof. I know what those guys go through.
My whole life has been about making that profession respectable
Ken Hendricks
2ndGen is offline
The Following User Says Thank You to 2ndGen For This Useful Post:
Tom Struble (11-29-2011)
Old 11-28-2011, 06:50 AM   #30
Roofing Sage
2ndGen's Avatar
LF,
Do we have the same idea?
Ken Hendricks
2ndGen is offline
Old 11-28-2011, 08:02 AM   #31
Red Adobe's Avatar
Trade: Metal Roofs, Sparky , Remodels and beer specialist
Rewards Points: 92
Tom:
As low as that J-Channel is I wouldnt be suprised if its not part of a problem. I'd be for checking on what they did behind the siding, I like to keep the J up at least an inch that keeps nails up 2 1/4.
Maybe some painted L trim 3x3 behind the siding and sealed and screwed thru shingles
Red Adobe is offline
The Following User Says Thank You to Red Adobe For This Useful Post:
Old 11-28-2011, 09:05 AM   #32
Sawdust Sweeper
Rewards Points: 28
That gutter is going to be sloped to the outside to avoid dumping more water into the trouble area
Old 11-28-2011, 11:39 AM   #33
Shingler extraordinaire
A&E Exteriors's Avatar
Trade: Roofing, Framing, siding, decks
Rewards Points: 11,382
I would do something along the lines of what I did here, grind out your reglet, somewhat smooth out the stone, tapcon a 1x something to it, flash , counterflash, done.
This of course assumes you remove siding, shingles, etc., but this should solve the stone issue.
Name:  2011-07-19 12.05.51.jpg
Name:  2011-07-19 12.05.42.jpg
Name:  2011-07-21 11.34.57.jpg
Name:  2011-07-21 11.51.15.jpg
Name:  2011-07-21 14.21.31.jpg
A&E Exteriors is online now
Old 11-28-2011, 11:40 AM   #34
Name:  2011-07-21 12.46.59.jpg
Old 11-28-2011, 02:29 PM   #35
windowsonwashington.net
WindowsonWash's Avatar
Trade: Exterior Construction
Rewards Points: 1,178
What...you mean that bead of caulk at the chimney:shingle interface won't keep out water...
This is how we do our flashing in similar situations.
WindowsonWash is offline
The Following User Says Thank You to WindowsonWash For This Useful Post:
A&E Exteriors (10-08-2015)
Old 11-28-2011, 10:27 PM   #36
Roofing and Architectural
Renegade's Avatar
Trade: Roofing and Architectural Metals
Rewards Points: 708
C'mon WoW, we all know caulk fixes everything!
Renegade is offline
Old 11-29-2011, 08:16 AM   #37
MJW's Avatar
Trade: General Contractor, Roofing, siding, windows
Rewards Points: 1,772
Well yeah! What do you think is on the top of that reglet.....
Tom, you know that is probably a siding issue or ice issue. Once you take it apart you will find it rather easily I'm sure.
Loneframer....how could that be an ice problem in there? I didn't read where there was an insulation or ventilation problem....
MJW is offline
Old 11-29-2011, 02:48 PM   #38
dennis's Avatar
Trade: Roofing
Rewards Points: 150
For the original question by Tom, I would do something like this;
Depending on the budget, epdm, modified or single ply would all work. Just get the shingles and step flashing out of the way.
For that last set of photos with the chimney cricket, why all that work with the new 1x and cutting/chiseling of the chimney.
Why not just counter flash to the existing mortar joints?
dennis is offline
The Following 2 Users Say Thank You to dennis For This Useful Post:
superseal (11-30-2011), Tom Struble (11-29-2011)
Old 11-29-2011, 02:58 PM   #39
Because you can't flash something that's all lumpy
Old 11-29-2011, 03:44 PM   #40
It's hard to tell in the picture, but the center of those stones are about 1 1/2"- 2" off the mortar line
