How To Measure A Hip Roof From Blueprints
Old 02-02-2018, 01:15 PM   #1
Jboogy66's Avatar
Trade: Roofing
Ok Iím relatively new to the hip roof blueprints so how would I measure the square footage of a hip roof from a set of architectural drawings?
Jboogy66 is offline
Old 02-02-2018, 01:19 PM   #2
Sure, I can do that...
jlhaslip's Avatar
Trade: carpentry/renovations
Rewards Points: 90
Send a message via Skype™ to jlhaslip
Re: How To Measure A Hip Roof From Blueprints
Same as any triangle.
one half (base times height).
There are pitch calculators on the web that will help measure the height based on roof pitch.
jlhaslip is offline
Old 02-02-2018, 01:20 PM   #3
Jboogy66's Avatar
Trade: Roofing
Would I measure the ridge from the birds eye view or find the elevations that show the ridge and measure from there?
How to measure a hip roof from blueprints-38676c5b-6ab8-47c1-bb09-0ff13f37da24_1517595398125.jpeg
Jboogy66 is offline
Old 02-02-2018, 01:24 PM   #4
Jboogy66's Avatar
Trade: Roofing
Right but how do I find the height from the birds eye view? I canít can I? That wouldnít be right I donít think
Jboogy66 is offline
Old 02-02-2018, 01:34 PM   #5
jlhaslip's Avatar
Rewards Points: 90
Scaling ruler would be one method.
Or look at the framing prints that give more detail.
jlhaslip is offline
Old 02-02-2018, 01:34 PM   #6
Jboogy66's Avatar
Trade: Roofing
Can anybody help me. Iím kinda in a hurry lol
Jboogy66 is offline
Old 02-02-2018, 01:35 PM   #7
Jboogy66's Avatar
Trade: Roofing
Scaling from the eave to the peak would be correct? How do I calculate in for the pitch since the roof is not flat?
Jboogy66 is offline
Old 02-02-2018, 01:43 PM   #8
jlhaslip's Avatar
Rewards Points: 90
Try this:
Use the run measurement and multiply by the pitch multiplier.
jlhaslip is offline
Old 02-02-2018, 01:45 PM   #9
jlhaslip's Avatar
Rewards Points: 90
The scaling number is the run. Use the multiplier to find the length of the rafter which would be the triangle height.
jlhaslip is offline
Old 02-02-2018, 01:48 PM   #10
Jboogy66's Avatar
Trade: Roofing
And that gives me what? The total height from the eave to the ridge?
Jboogy66 is offline
Old 02-02-2018, 02:00 PM   #11
jlhaslip's Avatar
Rewards Points: 90
Gives you the height of the triangle for the calculation you need for the hip. Base is scaled from fascia to fascia. Do the math and you have the square footage.
jlhaslip is offline
Old 02-02-2018, 02:04 PM   #12
Jboogy66's Avatar
Trade: Roofing
So just multiply the whole base by the multiplier and thatís it?
Jboogy66 is offline
Old 02-02-2018, 02:32 PM   #13
Big Johnson's Avatar
Trade: Contractor and Grunt
Rewards Points: 1,595
Take it to your roofing supplier and let them do it.
How are you a roofer and you don’t know how to do a roof takeoff?
Big Johnson is online now
The Following 2 Users Say Thank You to Big Johnson For This Useful Post:
concretemasonry (02-02-2018), Seven-Delta-FortyOne (02-02-2018)
Old 02-02-2018, 02:42 PM   #14
Eater of sins.
ScipioAfricanus's Avatar
Trade: Designer/Drafter Extraordinaire
Rewards Points: 966
How are you a roofer and you donít know how to do a roof takeoff?
He said that he was new to doing this from plans.
He also said that he was in a hurry for the free advice...good luck to him on that score.
Andy.
ScipioAfricanus is online now
Old 02-02-2018, 02:44 PM   #15
Jboogy66's Avatar
Trade: Roofing
Because Iím new to doing it is the whole reason Iím on here asking. U must be fun to work with. Thanks for the help ??
Jboogy66 is offline
Old 02-02-2018, 02:44 PM   #16
Fishindude's Avatar
Trade: Industrial
Rewards Points: 242
My thoughts also. This is pretty basic math.
If you are estimating / quoting a job, you stand to get yourself in some serious financial trouble if you can't get through a simple roof square footage take-off. Get some mathematics help from a private tutor or your local community college.
Fishindude is offline
Old 02-02-2018, 02:48 PM   #17
Jboogy66's Avatar
Trade: Roofing
Why can people not just offer advice rather than belittling someone. I come here asking help from hopefully someone who knows how to since Iím relatively new to this and I get slammed. Do u know a good tutor maybe they can help
Jboogy66 is offline
Old 02-02-2018, 03:05 PM   #18
Eater of sins.
Rewards Points: 966
Don't be so thinned skinned man, it's not that big of a deal.
As was said before. looking at the triangle that the roof plane looks like on the plans, you multiply the base (the long part of the triangle) by the height of the triangle (the peak of the triangle down to the base) then divide that in half.
Then take that last number and multiply it by the number in the "FACTOR" category that Jlhaslip posted and bam! you have the total sq. footage of the roof.
For example, let's say the plans show a 5 in 12 roof pitch and you scale the roof plane at say 22' long (the base) and 13' high (the height). you can go like this 1/2 x 22' = 11' cool?, then 11' x 13' (the height) = 143 sq. ft.
Then take the 143 sq. feet and multiply that by the 5:12 pitch FACTOR (=1.085) so you have 143 sq. ft. x 1.085 = 155 sq. ft. of roofing surface.
Are we groovy now?
Andy.
Old 02-02-2018, 03:07 PM   #19
Call Joe Manchin
tel:304-342-5855
SmallTownGuy (02-02-2018)
Old 02-02-2018, 04:47 PM   #20
Tom M's Avatar
Rewards Points: 4,672
You need to learn how to do the math for the slope. I can read a roof slope by looking at it but........
GAF made a plastic business card that had some cut corners on it. If you couldnt read a roof pitch by looks.....You would hold the card up to the gable and keep rotating the card till the angle matched. Under the angle was the correct pitch and per ft value.
A handy thing if you can find it
Tom M is online now
Do you judge a worker by his tape measure? Millworker Tools & Equipment 175 03-01-2016 10:54 AM
Residential Flat roof Nac Roofing 8 04-23-2013 10:51 PM
Framing addition - Matching existing roof plane ncornilsen Framing 18 01-11-2013 12:47 PM
Roof rafters, floor joists. Wood to mortar contact. Baltimore Masonry 16 08-04-2012 03:58 PM
Low Pitch Roof solutions Fixer Roofing 4 02-18-2007 11:09 AM
