How Bad Did The Roofers Mess Up And Can It Be Salvaged...
Old 08-27-2017, 06:52 PM   #1
DrkMith's Avatar
Trade: Hydronic Heating
Rewards Points: 14
Hello,
I am hoping to get an opinion on the work done on my house.
Here are photos i took after i got home and theyvwere done with the roof work... https://goo.gl/photos/Cbai8UV8mVyeFXnr7
Backstory.....
We had PV panels installed which i was not there to watch the install. Some of the panels were installed on part of the roof that is almost flat. They waterproofed the mounts on that section with chemlinks e-curb product...but failed to follow the instructions and i could tell somethung was wrong and after talking to one of their engineers i was told hus grandson could have done a better job and the warranty is void and to have it replaced.
Solar installer came to replace the e-curbs and found that it was tearing the roof......after a bunch of back and forth they said they would install a new capsheet on the entire flat roof area.
Last week they came to work on the roof...they had what lookked like tarpaper with a blue plastic on one side(not peel and stick, it said do not remove on the olastic) and self adhesive mod bit cap sheet...the tarpaper was nailed down and the cao sheet stuck to that and thats it......the edges are loose and can be lifted up......
After looking into how to do what they did online and youtube it looks like they messed up...
I dont know if it can be fixed, or is it a rip it off and redo it again situation...i am betting they will say they can fix it with some calk or simething but since im a hydronic heating guy not a roofer i dont know what is correct...i just bet they want to spend the least ammoumt of money, but they need to make it
so, yeah, long post... any advice would be very helpful
DrkMith is offline
Old 08-27-2017, 07:12 PM   #2
rrk's Avatar
Rewards Points: 1,902
Re: How Bad Did The Roofers Mess Up And Can It Be Salvaged...
According to an Inspector I talked to last year no roofing manufacturer will warranty a roof with solar panels on it. Not exactly sure thats true, but I do know many fire departments will not send anyone on a roof if solar panels are present. I know my homeowners insurance asked if I had panels.
rrk is online now
DrkMith (08-27-2017)
Old 08-27-2017, 07:44 PM   #3
DrkMith's Avatar
Rewards Points: 14
Good info to look into, but not exactly relivent to this particular issue.
Thank you for the info
DrkMith is offline
The Following User Says Thank You to DrkMith For This Useful Post:
Wile E Coyote (08-29-2017)
Old 08-27-2017, 08:00 PM   #4
John the Builder
SmallTownGuy's Avatar
Trade: Carpenter/Builder
Rewards Points: 9,926
Yeah...
naw. forget it...
SmallTownGuy is online now
Old 08-27-2017, 08:23 PM   #5
Tom M's Avatar
Rewards Points: 6,444
GAF liberty base sheet is black with what looks like plastic film. Its part of the mechanical method of attaching.
Cant see close ups of details but not all installers are craftsmen. If it works and follows specs. Thats it.
Tom M is online now
Old 08-27-2017, 09:09 PM   #6
DrkMith's Avatar
Rewards Points: 14
My concern with the work is that the base sheet and cap sheet are able to be lifted up a good few inches without any effort and you can see the old flashing and roof.
I would have expected the new roofing to be somehow sealed to the flashing so wind and water wont get under the new roofing.
From the gaf instructions it talks about removing old flashing and i stalling a new flashing ontop of the bast sheet and having the cap sheet adhered to the flashing...but i could be wrong
DrkMith is offline
Old 08-27-2017, 09:19 PM   #7
Tom M's Avatar
I personally hate installing drip cap over the finished roof as many spec's say. To me it bucks water.
For flashing, its recommended to spray the metal with an asphalt primer to improve the bond. I have used it and have not.....dont know how much it matters. It bonds either way and will not be able to lift it once its fully cured.
Tom M is online now
Metro M & L (09-12-2017)
Old 08-27-2017, 10:09 PM   #8
DrkMith's Avatar
Rewards Points: 14
The naildown (non adhesive backed) base sheet is ontop/extending paat the old extsting flashing with no adhesive or anything to bond or cure...
The self adhesive capnsheet is bonded to the base sheet only, not bonded to the flashing at all....
The GAF instructions show the flashing to be installed abovenrhe base sheet and under the cap sheet so the cap sheet is bonded to the flashing...
DrkMith is offline
Old 08-27-2017, 10:12 PM   #9
DrkMith's Avatar
Rewards Points: 14
Photo of lifting corner
How bad did the roofers mess up and can it be salvaged...-20170823_190713.jpg
DrkMith is offline
Old 08-28-2017, 10:22 AM   #10
KAP's Avatar
Trade: Custom
Rewards Points: 27,404
That's because you're lifting it...
KAP is offline
The Following 6 Users Say Thank You to KAP For This Useful Post:
A&E Exteriors (08-29-2017), Bull Trout (09-12-2017), heavy_d (08-28-2017), SmallTownGuy (08-29-2017), Tom M (08-28-2017), Tom Struble (08-28-2017)
Old 08-28-2017, 11:25 AM   #11
DrkMith's Avatar
Rewards Points: 14
Ok.....is there suposed to be something to keep the roofing material on the roof? I am not exerting much of any force to lift the corner of the roof.
There is no adhesive or whatever you want to call it under the tarpaper, or bast sheet or whatever you want to call it.
The adheaive cap sheet or whatever you want to call it is adhering quite nicely to the bast sheet but the base aheer is only nailed down to the roof and not nailed close to the edges.
Im on the coast and do get some nice wind from time to time and i could see the wind getting under the edge that is not adhered to the roof in any way lifting up when a 60mph gust catches it.....or would i have to get up there and lift it manualy to help the wind.
It is my impression of the instructions ofnthe GAF Liberry self adhesive modified bitumen cap sheet that the roofer should have removed the old flashing and installed the new flashing inbetween the bast sheet and capsheet so that the capsheets self adhesive backing would self adhere to the flashing so as to make a waterproof/windproof/fingerproof seal and keep from being lifting up.........am i wrong?
DrkMith is offline
Old 08-28-2017, 12:06 PM   #12
Wormdrive Operator
heavy_d's Avatar
Trade: Contractor
Rewards Points: 6,498
What do you want to hear? That you should sue him? Even if we agree with you it can't be used it anyway, we are just some ppl on the internet.
Sent from my SM-G930W8 using Tapatalk
heavy_d is offline
Old 08-28-2017, 12:18 PM   #13
DrkMith's Avatar
Rewards Points: 14
I dont want to sue anyone, i am just trying to find out if there is a way to salvage the install that will last. I am not a roofer, but in my trade i know how to fix problems i come across and was hoping someone might have any ideas on how to fix this mess without having to repeal and replace the work already done, but if there is no good way to fix the issues i am going to request they start over.
If they are cheep or incompetent i could see them showing up with tubes of silicone saying that they will fix everything with silicone...
I dont want to make them redo all the work if there is a way to seal the edges that will last...flashig cement? Bituthane? Some roofing sealant like shahco through the roof? Hot tar? Some kind of torchdown product that could go inbetween the old roof flashing and base sheet?
Some way i cant think of to fix it in an acceptable way thata wont leak in acouple years?
But ohwell whatever
DrkMith is offline
Old 08-28-2017, 06:34 PM   #14
B.Johnson's Avatar
Trade: Builder
Rewards Points: 1,424
If everything else is ok and you just want to secure the edge to keep the wind from lifting it, just use the best "Black Jack" type of caulk that you can find. You should pay about $8.00 for the good stuff.
Home Designer Series Software
B.Johnson is offline
Old 08-29-2017, 10:58 AM   #15
kixnbux's Avatar
Rewards Points: 1,440
Just go around the edges on top of the drip cap and run a bead of blackjack. It'll bond up solid on the first hot day and you won't be able to lift it at all
kixnbux is offline
Old 08-29-2017, 08:03 PM   #16
B.Johnson's Avatar
Trade: Builder
Great Idea! I wish I had thought of it.
Old 09-12-2017, 01:13 AM   #17
madrina's Avatar
Trade: roofing and other envied trades
Rewards Points: 972
That is grade A dog sh17 job. No u cant salvage that and why would you want to? That looks terrible. The first windstorm that blows thru there is going to rip it off. The laps arent right, the end seams arent cut right, the material doesnt even cover the space or terminate high enough under the shingles. Looks like you hired sheetrockers to put that on.
madrina is offline
Old 09-21-2017, 05:42 AM   #18
builditguy's Avatar
Rewards Points: 406
Something is up with the edge. Right by the gutter, hanging over the drip edge. What is that blue plastic?
Was there a plastic backing that they pulled off, before they applied it? From what you pulled up, it appears there is only a small adhesive line on the bottom edge. What's holding the roofing material down? Did they apply some sort of sealant, then lay the roll roofing?
Also, did they tear the old roof off or did they just lay the new roof over a mop tar roof? Where you lifted the corner, the substrate looks weird.
Having asked all those questions, right after I install a roof, the shingles aren't necessarily sealed down. It can take a day, or two, depending on the weather conditions.
It that what is happening here? Did they get done and you ran up and lifted a corner, before it had a chance to seal down?
Even if that's the case, I don't see what it is supposed to seal to.
builditguy is offline
