HELP -Add A Patio Roof To Existing Roof
Old 04-16-2007, 08:32 PM   #1
Jeffrey442's Avatar
Trade: Contractor
Im Working in upstate NY on a Ranch style home. I'm looking to add a patio roof to the back of this house. The existing roof has a 5/12 pitch, Theres a 12" overhang and its just over 10' high. I would like to extend 16' out by 32' wide. I dont have enough height to carry the 5/12 pitch out to 16'. Theres a shingle roof on the house that I will be replacing with this new patio roof. What is the best way to tie into the existing roof.
Jeffrey442 is offline
Old 04-17-2007, 02:17 AM   #2
3rd gen,it's in the blood
roofwiz74's Avatar
Trade: roofing
Re: HELP -Add A Patio Roof To Existing Roof
what material are you gonna use on the "addition"
on the roof.
You have ONE advantage over me.....you can kiss my butt and I can't!!
roofwiz74 is offline
Old 04-17-2007, 02:18 AM   #3
roofwiz74's Avatar
Trade: roofing
by the way the best way to tie into the roof would be to call a roofing contractor for his PROFESSIONAL ADVICE.
Old 04-17-2007, 11:34 AM   #4
tinner666's Avatar
Go with an 'ell'. Run a ridge line to existing ridgeline. 2 valleys. Don't even think of a shed roof.
tinner666 is offline
Old 04-26-2007, 09:55 PM   #5
APPLIED RIGHT
johnk's Avatar
Trade: roofing
i would tie in by lowering the pitch on the addition to 2/12 or less depending on height you want to achieve.i would use a low slope roof product such as torch-on,rubber or t.p.o.iwould do the tie in by removing the bottom 6 or 7 courses of shingles bring your low slope roof product 18-24 inch up 5/12 roof pitch,replace 3 or 4 rows of shingles keeping your nails high and bond the bottom couple of rows with material compatible adhesive.
johnk is offline
Old 04-27-2007, 08:13 AM   #6
MJW's Avatar
Trade: General Contractor, Roofing, siding, windows
Are you asking how to tie the shingles together or the framing?
This should be brought in and valleyed out with the L shape mentioned. If not it will be trouble.
MJW is offline
Low Pitch Roof solutions Fixer Roofing 4 02-18-2007 11:09 AM
Help tying in this roof to addition jaymay75 Framing 0 06-18-2006 10:54 PM
Need help designing Roof for addition jaymay75 Framing 21 06-17-2006 10:47 PM
Torch down(flat roof) leaks BAD...can you give advice ASAP? Detail Guy Roofing 21 01-16-2006 02:36 PM
Do You Need A New Roof ??? Perfect Roofing Roofing 0 02-10-2005 02:46 AM
