Hail Damaged Slate?
Old 11-06-2011, 04:52 PM   #1
jmiller's Avatar
Trade: Roofing
Rewards Points: 1,002
Hail Damaged Slate?
Does this look like hail damage or routine wear and tear? The area was hit pretty hard a few years ago so the copper valleys are dented up pretty bad. Some of the damage is obviously hail, e.g. where two pieces have semi circle damage next to each other, but I was curious if all the missing corners were likely caused by hail as well (or if that was likely just age).
jmiller is offline
Old 11-06-2011, 06:34 PM   #2
stonecutter's Avatar
Trade: Stonemasonry
Rewards Points: 2,344
Re: Hail Damaged Slate?
It is curious that it is mostly right corners that are broken off.
www.thewoodfiredenthusiast.com
stonecutter is offline
Old 11-06-2011, 10:18 PM   #3
Renaissance Man
superseal's Avatar
Rewards Points: 4,948
That slate looks like it was walked on and hailed on
golf ball lunkers for sure!
superseal is offline
Old 11-07-2011, 03:36 AM   #4
Splinter hands's Avatar
From the pic. it looks like most of the damage is in one area to me. With hail the damage would be more uniform I would think. Kind of looks like someone was up there walking around in that one area. Maybe it's just the picture angle or something though.
Splinter hands is offline
Does Home-Owners policies cover wind and hail damaged shingle roofs? C. Bowers General Discussion 4 07-24-2011 11:33 PM
Painting over a slate roof...Have you done it? CarrPainting Painting & Finish Work 5 03-24-2011 06:26 PM
Looking for porcelain tile that mimics slate hillblazer Flooring 8 02-28-2009 01:13 PM
4 Case Studies Of 4 Separate Hail Caims With Different Insuarance Companies Ed the Roofer Roofing 14 08-31-2008 07:42 PM
