Gutter Splash On Underside Of Raw Pine Roof Deck
Old 07-22-2009, 07:50 AM   #1
LetItBeLEED's Avatar
Trade: green building
Here's one I've never thought about before: when rain runs off a roof into gutters, does it splash back up much? Do ya'll ever do anything special to protect roof decking where the bottom side is exposed between the fascia and the drip edge?
Thanks
LetItBeLEED is offline
Old 07-22-2009, 01:59 PM   #2
Just a Roofer's Avatar
Trade: roofing
Re: Gutter Splash On Underside Of Raw Pine Roof Deck
Yes, it's called gutter flashing.
Just a Roofer is offline
Old 07-23-2009, 10:02 PM   #3
well duh. Thanks.
Old 07-24-2009, 06:32 PM   #4
Trade: roofing
Not sure as to what your asking then considering a gutter is put on & then flashing is installed into the gutter & under the roof. What at this point is exposed? Please explain.
Old 07-26-2009, 12:13 PM   #5
buildpinnacle's Avatar
Trade: Public Insurance Adjuster
I guess I don't understand either. There should be no exposed roof decking anywhere if proper installation of the gutter and drip edge was installed. There should be no exposure of fascia at all. When applicable, the gutter should be installed under the drip edge so the drip counter flashes it and does not allow moisture down the fascia boards. If that is not applicable, we always require some type of slip flashing.
Pinnacle Limited
Public Insurance Adjusters
(800) 918-7840
buildpinnacle is offline
Old 07-26-2009, 08:16 PM   #6
SeamlessGutters's Avatar
Trade: Seamless Gutters & Leaf Protection
Yeap, You have to install flashing, apron whatever you call it at every job.
-Note to roofers.
Why do you install drip edge in places you know are getting gutters? My contractors do that constantly and I just don't understand it. I tell them that I rip it off anyway.....
Just curious, maybe there is a reason.
Ryan Grambart
Grambart Exteriors, LLC
www.grambartexteriors.com
320-237-7001
"Specializing in Seamless Gutter installation in Central Minnesota"
SeamlessGutters is offline
Old 07-26-2009, 08:32 PM   #7
nlgutters's Avatar
Trade: seamless gutters
Not sure if i understand why you rip off drip edge?
www.nlseamlessgutters.com
nlgutters is offline
Old 07-26-2009, 08:35 PM   #8
oldfrt's Avatar
-Note to roofers.
Ryan Grambart
320-237-7001
Building codes here dictate the use of drip edge at the eaves,I don't recall any codes for gutter installations.
I haven't seen any of the local gutter installers using any kind of flashing or apron.Could you post a pic of what you use?
oldfrt is offline
Old 07-27-2009, 11:03 AM   #9
JimmyS
jimmys's Avatar
Trade: General contractor
We sometimes flash the gutters with the Z flashing you get for installing between the lifts of T-1-11 ply siding panels. It's maybe an inch up, half inch out, half inch down. Tuck under the drip edge and out over the gutter. A few aluminum trim nails through the drip holds it. It's a workaround and a pain to install after the gutters, but otherwise they often drip between fascia and gutter.
As for exposed sheathing, we try to end the sheathing flush or behind the fascia so nothing is exposed. Old timers here used red cedar shingles for a drip, but sometimes they didn't outlast the composition roof.
Jim
jimmys is offline
Old 08-02-2009, 10:09 PM   #10
I meant siders edge sorry
Bison deck supports for roof deck Chris G Decks & Fencing 20 11-17-2010 05:36 PM
Conduit under roof deck Jm H Electrical 14 06-09-2009 11:25 AM
Deck over a tar and gravel roof yipee General Discussion 2 06-02-2008 10:30 PM
Under Deck Roof soffit G_PooBA Finish Carpentry 6 05-31-2008 09:08 AM
Deck stairs with a roof?? workswithwood Decks & Fencing 5 05-13-2008 11:23 AM
