Gutter Joints Leaking
I have a new home (to me)and see the gutters are leaking at many joints, The gutters are in good shape, guessing 10 years old aluminum, riveted at joints. I am guessing that some are not pitched properly, as when I goughtthe house I took a couple rubbish barrels worth of asphalt and leaf's out of them(neglected). I will be resetting these, but was wondering if anyone has recomendations for sealng the joints. I have seen at the lumber yard, guttertape and also caulk. Anyone have any input/experience with this.
Re: Gutter Joints Leaking![]() |
Trade: Roofing, Siding, Gutters
Ruscoe 12-1 Seam Sealer
1. Clean Gutter 2. Make sure Gutter is dry 3. Apply sealer (about a 1/4" thick) it will spread and thin as it drys 4. Done You can pick it up at most siding supply houses Last edited by CHB70; 02-13-2009 at 07:08 PM. |
Trade: Seamless gutters
Geocel 2310 paintable gutter sealant
As above: clean joint completly, make sure joint is dry Use a paint brush to completly cover sides and back of joint. This gives you a chance to cover all small openings and cracks in the old sealant. Also make sue you remove any loose stuff before resealing. |
Bah Humbug!
I use solvent based elastomeric, which is a expensive roof coating. However it's thin and self leveling. Thin is nice because you don't want to build up the seams too much, and it's hard to scrap out all the old sealant. It's very sticky and will adhere to the old sealant if it's fairly clean and since it's solvent based will adhere if it's even a litle bit wet. Thin is also nice since it will fill cracks and voids on and around that old sealant bonding it to the gutter.
So far so good, but if your gutters are seamed (not meaning corners, but actual seams) you would probably consider getting all new seamless gutters. Seamed gutters are always a long term maintenance issue. |
| Azek butt joints holding up? | LeonardDB | Finish Carpentry | 39 | 11-28-2009 08:30 PM |
| Gutter Setup? | guttersbyryan | General Discussion | 14 | 11-14-2008 04:57 PM |
| Control/Movement joints | Cache | Flooring | 6 | 11-02-2008 01:10 AM |
| Com Cast tv cable in wood gutter | Driftwood | Carpentry | 6 | 10-04-2008 09:40 AM |
| ice shield at gutter line? | Grumpy | Roofing | 38 | 09-08-2008 08:22 PM |
