Gutter Down Spouts
Old 08-17-2017, 08:12 AM   #1
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 970
Gutter Down Spouts
For gutter guys. I have a large condo that looks like I am going to be working on. Right now it has K5 with standard 2x3 downspouts. Some of them was thinking they should go to K6 which will be a lot of extra cost due to the height of the building . So my question is would it be of any benefit of replacing the 2x3 with 3x4 for extra water handling.
Randy Bush is online now
Old 08-17-2017, 09:40 AM   #2
water re-locater
NYgutterguy's Avatar
Trade: Gutter installer
Rewards Points: 3,016
Re: Gutter Down Spouts
Bunch of guys around here install the 3x4 with the 5" gutters since they either don't have the 6" machine or don't won't to bother with them. It will definitely help with the volume since 50% more water will flow through the larger hole . I do it on occasion.
NYgutterguy is online now
The Following User Says Thank You to NYgutterguy For This Useful Post:
Randy Bush (08-17-2017)
Old 08-17-2017, 01:10 PM   #3
Gutter Hanger
CrescentGutter's Avatar
Trade: Seamless gutters
Rewards Points: 593
My first question would be approximately how many square of roofing will be dumping into each?
As NYG says, the 3x4 will help for sure. Providing you don't get a hack who doesn't also punch the hole out bigger to go with the 3x4.
Time loves to be wasted. From that waste there is no salvage. - Henry Ford
CrescentGutter is offline
Old 08-17-2017, 01:13 PM   #4
water re-locater
See it often..Small hole big pipe.
The Following 3 Users Say Thank You to NYgutterguy For This Useful Post:
A&E Exteriors (08-17-2017), CrescentGutter (08-19-2017), Randy Bush (08-17-2017)
Old 08-17-2017, 01:17 PM   #5
Randy Bush's Avatar
Rewards Points: 970
That hack would be me who will be making the holes bigger,
As you can see in the picture is a pretty big roof, not sure they have had any real problems in the past, but you know how some people can be when a real educated people that does not really know anything tells them something.
When I tell them the cost they may change their mind. I would have to pull it to reside , but still the material cost and labor for putting larger stuff up.
Old 08-17-2017, 01:18 PM   #6
water re-locater
Grab a 3 3/8 hole saw. Will make pretty quick work out of it.
Old 08-19-2017, 11:52 AM   #7
Gutter Hanger
Rewards Points: 593
I know exactly what you mean. Once had a guy who wanted to know military specs on gutter screws. It was right then & there that I told him to find another contractor because the internet had already taught him more than I know about the gutter business.
The Following User Says Thank You to CrescentGutter For This Useful Post:
NYgutterguy (08-19-2017)
Old 08-19-2017, 12:24 PM   #8
WBailey1041's Avatar
Trade: Gutters
Rewards Points: 1,407
http://www.bergerbp.com/media/doc/Pr...poutSizing.pdf
You mean 100%.
2 inches times 3 inches = 6
3 inches times 4 inches = 12
Also, after the hole saw trim out the corners and use a proper 3x4 drop outlet.
WBailey1041 is offline
Old 08-19-2017, 12:35 PM   #9
water re-locater
You mean 100%.
Yea sometimes my stoner math comes out lol
Old 08-19-2017, 12:47 PM   #10
Trade: Gutters
Lol, Not my thing but just say twice as much.
Old 08-19-2017, 06:21 PM   #11
Big Johnson's Avatar
Trade: Contractor and Grunt
Rewards Points: 3,434
You mean 100%.
If it only has a round 3-3/8" hole it's 9 sq. in.
Big Johnson is online now
Corner re-install Gutter question--Seamless vs. Galvanized Painter One Windows, Siding and Doors 5 05-11-2013 05:38 PM
built in gutter - changing slope zeppyroof Roofing 12 07-17-2012 12:12 PM
Gutter Hangers in Stucco Wall go_hercules Construction 8 05-23-2012 12:37 AM
Gutter Apron Install Advice Gladiatorx Roofing 2 08-13-2010 02:36 PM
