Gutter Chain
Old 10-27-2017, 07:48 AM   #1
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 962
Gutter Chain
You gutter guys what are your thoughts on chains instead of down spouts? House working on the owns wants chains, really windy area too.
Randy Bush is online now
The Following User Says Thank You to Randy Bush For This Useful Post:
maxfederle89 (01-23-2018)
Old 10-27-2017, 08:49 AM   #2
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 12,965
Re: Gutter Chain
They're cool for certain situations. Tie them down below.
MarkJames is offline
Old 10-27-2017, 09:19 AM   #3
water re-locater
NYgutterguy's Avatar
Trade: Gutter installer
Rewards Points: 3,008
Re: Gutter Chain
Used them a few times. Here's most recent. Not sure how good it works in a downpour but looks pretty cool
NYgutterguy is online now
The Following 4 Users Say Thank You to NYgutterguy For This Useful Post:
A&E Exteriors (10-27-2017), Randy Bush (10-27-2017), rblakes1 (10-30-2017), Rio (10-27-2017)
Old 10-30-2017, 12:01 AM   #4
rblakes1's Avatar
Rewards Points: 1,468
Re: Gutter Chain
Originally Posted by NYgutterguy View Post
Used them a few times. Here's most recent. Not sure how good it works in a downpour but looks pretty cool https://youtu.be/X6Rcf-lGQNY
I didn't even know that was a thing. Seems like it would be perfect outside a sunroom/ screened porch
Sent from my SM-N910V using Tapatalk
rblakes1 is offline
Old 11-07-2017, 10:25 PM   #5
roofingrenonv's Avatar
Trade: roofer
Rewards Points: 8
Re: Gutter Chain
Make sure they're properly anchored down and you should be totally fine.
roofingrenonv is offline
Old 01-23-2018, 10:16 PM   #6
maxfederle89's Avatar
Trade: Seamless Gutter Company
Rewards Points: 66
Re: Gutter Chain
I've installed a couple. Can be very decorative. The only problem is what's below them. Is it a good place for uncontrolled water? If the wind blows will it go where you don't want it? Will you catch it in a fancy barrel? If you get winter, will the ice be an issue or will it be decorative (some frozen rain chains look snazzy). If these considerations are planned out, they can be neat. But some homeowners I worked for don't consider these things and I have to break the news to them that they may not be the best for function and their particular application.
Sent from my SM-J320V using Tapatalk
maxfederle89 is offline
Old 02-14-2018, 04:26 PM   #7
mastersroofing's Avatar
Trade: roofer
Rewards Points: 110
Re: Gutter Chain
gutter chain is fine if you are draining a smaller roof surface without a large flow of gutter water. Wind of course is a factor, so don't install in a typically high wind area or where weather storms are typically accompanied by high wind. When you install make sure you are draining onto a good surface that is not going to splash mud up onto the house as well.
Chuck
Masters Construction
mastersroofing is offline
Corner re-install Gutter question--Seamless vs. Galvanized Painter One Windows, Siding and Doors 5 05-11-2013 05:38 PM
chain smokers and painting ceilings toolman65 Painting & Finish Work 11 09-15-2012 09:05 PM
built in gutter - changing slope zeppyroof Roofing 12 07-17-2012 12:12 PM
Gutter Hangers in Stucco Wall go_hercules Construction 8 05-23-2012 12:37 AM
Gutter Apron Install Advice Gladiatorx Roofing 2 08-13-2010 02:36 PM
