Gutter Apron Install Advice
Old 08-13-2010, 10:03 AM   #1
Gladiatorx's Avatar
Trade: Remod
Hi all,
In my area I buy gutter length from Ryan Gutter, they form them, and these gutters have a lip on the back, which the hanger clicks into. The lip is maybe . So If you want to install a roof apron/gutter apron, how would that work? Unless you only push the gutter up the under the apron, cause then you will hit the top of the hanger.
Guess you could install the apron after you install the gutter. On long lengths that would be a problem, because again you only have before you hit the top of the hanger, which means if you have to pitch in 30 feet you lose the aprons position of extending into the gutter because of the slop of pitch.
Should we switch gutter hangers??? Then again you still have a lip of the back of the gutter to deal with.
A couple picture are attached, Are there the proper aprons??? Is it a proper install?
At Ryan they also have flashing called a gutter apron which actually is about 1 11/4 which, and has a lip also on it. The gutter lip, and the apron lip go together so essentially you are extending the back of the gutter by 1 11/4 high. Then it is slipped under normal drip edge. The hangers have a slight angle to them, and actually you screw through the apron portion right into the fascia, just works out that way because of the angle of the hanger.
Any thoughts??????
Gladiatorx is offline
Old 08-13-2010, 11:43 AM   #2
copper magnet
seeyou's Avatar
Trade: custom metal fabrication
Rewards Points: 512
Re: Gutter Apron Install Advice
We make our own gutter apron, so we hang the gutter 1st and then make the apron flange whatever length we need.
On retrofits, we add a secondary piece as you described as necessary.
seeyou is offline
Old 08-13-2010, 03:36 PM   #3
Gutter-Maker
Ghostbeard's Avatar
Trade: Gutter & Downspouts
Originally Posted by Gladiatorx View Post
Hi all,
Any thoughts??????
We make a Hidden Hanger w/o Clip. Slide the gutter behind Drip-edge, and fasten thru Drip & Gutter into Fascia. Probably available in your area somewhere too. Or use the old Spike & Ferrule method.
Ghostbeard is offline
CopperSmith Gutter Company CopperSmith Introductions 8 03-01-2012 12:00 PM
Advice wanted for starting a construction firm P.J. Construction 34 10-09-2009 02:51 PM
glueing wide planks advice nailkiller1 General Discussion 5 06-15-2009 12:53 PM
Gutter Install Pricing HxVoC General Discussion 8 09-14-2007 09:10 PM
advice on materials? replacing old TNG beadboard soffits jordanski Carpentry 7 05-01-2007 12:29 PM
