Drywall Contractor
Got A Question For The Roofers...
Got a question for the roofers of this board. When installing a metal roof over shingles, are 1X stips of lumber needed between the shingles and the metal roofing. Meaning are they required or not. My brother in law has never done a metal roof in his life and insists that they 1X strips are not needed. If it was his house I wouldn't care, I can't stand him. But he's renting it from my other brother in law which I do like and I don't want the other one to mess up his house for he is trying to sell it.
Any advice would be appreciated. |
Trade: roofing
Re: Got A Question For The Roofers...
yes mudd tell they are required,for1 it lets the roof breath between the meatal and shingles. also it gives a better strength for screwing or nailing, and helps the fastning of these to look uniform and more eye appelling, tell him not to do it half ass
Commercial Roofing
Trade: Roofing Contractor
I have no idea, but if I had to bet money on it, I would say go with the first reply.
Pgriz knows metal.
http://www.roseroofing.net/ Seamless Industrial and Commercial Roofing Systems, Residential Repair. For Those That Demand Quality! Free roof inspections within 12 miles of our locale. |
Depends on the kind of system it is. Shingles, Panels ?
Some are ok to install over purlins( wood or metal ) while others are not. Best to check with the manufacturer on what their system can and cannot be installed over.I just put 1x4's on a roof I am the process of doing. The system is a vertical panel with concealed fasteners. This particular sytem I can do that because of the panel design and thickness of material. In this case 1x4s are used only because in the course of removing the old roofing, the substrate ( plywood ) appears as though it wouldnt have much holding power for the screws, other wise I would have put it on the plywood with an underlayment. Other vertical panels systems can go over the shingles or over the 1x4s or 2x4's. Existing conditions play a part in it also, its not a one application fits all. IMO. check with the manufacturer and follow their installation recomendations. Hope it helps. |
Custom Builder
It's been my experience that the more air between the shingles and metal, the better. From what I'm told the trapped heat can bake the shingles bad enough to force the metal up between the seams and give you an ugly roof in a few years of temp fluctuations.
Bob
Bob |
Trade: Roofer
Most panels are installed over furrings, while most shingles will be installed directly on the sheathing. As Red_Cedar said, you have to check with the manufacturer of the system you are using.
Personnally, I don't like the practice of only using horizontal furring strips, as the air cavity they create does not actually help with ventilation since air needs to rise by convection. The better practice is to place 2x4 vertically, then lay 2x4 horizonally on top of them. This creates a vertical air channel for allowing air flow. Of course, you need to make sure that the inflow at the bottom is clear, and that there is an appropriate vent (ridge vent or vent cavity) to allow the warm air to get out. |
It's seldom mentioned, but the expansion/contraction of the metal directly on shingles will sand holes through the metal.
Bah Humbug!
Tear off the old roof.
General Contractor
Trade: ?
Grumpy you are 100% correct.
I would never install metal over existing asphalt shingles. I always tear off the shingles to inspect the sheathing and thats very important. When I see a roofer go over the existing roof I would have to question why? Well I don't really have to question it I know why. |
Commercial Roofing
I know why too....cheap azz homeowners or lazy azz roofers.
Blissfield Maintenance
Trade: COMMERCIAL&RESIDENTIAL ROOFING& Repairs
Well i was waiting to see if any body would mention the expansion contraction over shingles . tear it off then grace or another smooth icws as far as air flow do as suggested and profile vent cap we did a huge job in 2002 546 sq and it is a thing of beauty . except for the color seafoam green yuck!!!!!
tooldude58
Trade: Home Improvement Specialist
Sounds like metal roofing is another animal entirely! Dan-o
#13 | |
Bah Humbug!
Re: Got A Question For The Roofers...Quote:
| Tight Space Stucco Question - Undershot between roof sections | CGofMP | Construction | 3 | 03-24-2009 09:10 AM |
| Question about bidding vinyl wallcovering | kanadaeh | Painting & Finish Work | 9 | 02-19-2009 05:29 PM |
| Basement Window Question | gregt848 | Windows, Siding and Doors | 9 | 07-26-2006 06:29 PM |
