Flat Roofs
Old 04-06-2006, 12:13 AM   #1
gutrman
gutrman's Avatar
Trade: Gutters, Gutter Protection & Under Deck Systems
Flat Roofs
Try to make a long story short...
I am on a finance committee for our parish and we were told that the flat rubber roof on the school is leaking and there is water between two rubber roofs and maybe into the insulation.
Questions:
What are your reccommendations? Do we consider building a new roof and installing a standing seam roof? Would that be too costly? We are tight for money (of course).
If we stay with a flat roof what are the best types out there? We are for now going to replace the roof and not go over the top of it, because of the water underneath. We want to elimate the threat of mold!
Thanks in advance.
gutrman
gutrman is offline
Old 04-06-2006, 08:35 AM   #2
joasis's Avatar
Re: Flat Roofs
Location of your Parish may help in giving you an answer. Code for your area may dictate what you do to fix it.
joasis is online now
Old 04-06-2006, 10:11 AM   #3
RooferJim's Avatar
Trade: roofing
Re: Flat Roofs
as good rubber roof would be your answer. standing seam has to have a good pitch and would not be practicle.
RooferJim
www.jbennetteroofing.com
RooferJim is offline
Old 04-06-2006, 11:20 AM   #4
gutrman
gutrman's Avatar
Re: Flat Roofs
We are located in Northwest Ohio.
gutrman is offline
Old 04-06-2006, 12:09 PM   #5
Commercial Roofing
AaronB.'s Avatar
Trade: Roofing Contractor
Re: Flat Roofs
If you want something that willl ast a hundred years or so, flatlock copper is the way to go (soldered, of course) High up front cost, but nearly zero maintenance.
http://www.roseroofing.net/
Seamless Industrial and Commercial Roofing Systems, Residential Repair. For Those That Demand Quality!
Free roof inspections within 12 miles of our locale.
AaronB. is offline
Old 04-06-2006, 08:34 PM   #6
Blissfield Maintenance
tiny's Avatar
Trade: COMMERCIAL&RESIDENTIAL ROOFING& Repairs
Re: Flat Roofs
Call custom seal good product and they have a good warrenty.There in ohio lima maybe well look them up on the web.
tiny is offline
Old 04-07-2006, 08:47 AM   #7
Bah Humbug!
Grumpy's Avatar
Re: Flat Roofs
Agreed with Aaron. soldered flat seam is a excellent choice for a LONG LASTING flat roof. But I wouldn't install this unless you tear off.
You said "rubber" but I suspect your roof isn't rubber at all, but is modified bitumen. EPDM is rubber. There are some roof systems more economical than copper on the market which you can expect to last 20 years when properly installed and maintained, which would be thge modified bitumen and/or EPDM.
If you have water between the roofs, and have leakage your insulation is more than likley wet. There are tests which can be done to determine if all the insulation is wet all over or just in islocated location(s). These tests are: Infra-red, Nuclear, and Core cutting.
Grumpy is offline
Old 04-07-2006, 01:41 PM   #8
gutrman
gutrman's Avatar
Re: Flat Roofs
We have one company lined up to take some core samples. You are probably right about the rubber Grumpy. I really don't know. All I know is that it is black in color and when you work with it you become black yourself. (very dirty)
We are defenitely replacing the roof and not going over top the existing.
Money is tight but we want a good product at a good price. If it could be so simple!
Thanks for your help guys.
gutrman is offline
Old 04-07-2006, 02:20 PM   #9
jack of all, master of 1
snapper21's Avatar
Trade: carpenter/roofer
Re: Flat Roofs
Looked into hypolon?
snapper21 is offline
Old 04-07-2006, 03:07 PM   #10
Anita's Avatar
Trade: Commercial and Residential Roofing
Re: Flat Roofs
gutrman,
Copper would be beautiful...but expensive.
You could go with epdm, I believe it works well in your area.
There are also several different PVC single ply systems available, and if you want to replace the roof again in five years, you could go with a TPO
This is what we use
Anita is offline
Old 04-07-2006, 03:51 PM   #11
RooferJim's Avatar
Trade: roofing
Re: Flat Roofs
Whats wrong with TPO ??
RooferJim
Flat roof over garage leaking under exterior walk out door IHI Roofing 18 05-30-2006 10:28 PM
flat roof vs. gable Iloveneworleans Roofing 2 02-18-2006 07:51 PM
FYI, Velux for flat roofs Grumpy Roofing 7 12-05-2005 11:01 AM
Wilma and S tile roofs VS Flat and metal. GO2SHH Roofing 1 11-01-2005 09:21 AM
