Flat Roof Under Deck
Old 12-10-2015, 07:33 PM   #1
kressman's Avatar
Trade: Renovation
Rewards Points: 36
I have some repair work to do at my parent's house. Let's just say it was not well built.
There was multiple leaks/floods in a finished room in the basement. It is a walk out basement with a block foundation. The area in question is a PWF one story addition, with a flat roof and a deck on top.
I ripped out the drywall and the insulation. When I pulled the ceiling I found a lot of water just sitting in the VB. Short story is 4 joists and 2 sheets of plywood are badly rotted. I've yet to actually start taking any of it apart so I'm not sure how he did it, but I have no doubt it's terribly wrong. The deck is PT, he laid 2x4 sleepers on the roof and used 2x6 for deck boards. The leak appeared to have started where a post was installed for the railing. I don't see any damage from below in any other areas.
I'm hoping just to repair this area for now, I will be ripping out the deck in spring. What kind of product should I be using to seal the roof? Is it even a good idea to replace the existing deck? I can't say I've ever seen anything that looks like it before, but what do I know. If I were to redo it completely, what would be the correct way?
kressman is offline
Old 12-10-2015, 07:38 PM   #2
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 6,275
Re: Flat Roof Under Deck
EPDM roofing, sleepers, and decking. Properly flashed at all post penetrations.
Easy Gibson
Warren is offline
Old 12-10-2015, 10:22 PM   #3
pizalm's Avatar
Rewards Points: 730
We normally use torch down, sleepers, then decking and avoid any penetration through the roof.
Sent from my iPad using Tapatalk
pizalm is online now
Old 12-11-2015, 08:10 AM   #4
1985gt's Avatar
Trade: Roofing
Rewards Points: 346
All the ones we do we install EPDM, no penetrations then a floating deck on the top, railings are attached to the deck. Here is one we did awhile back where the post penetrated the roofing. Lots of damage from the posts not being sealed correctly.
1985gt is offline
Paint or stain on hardi plank? Jer Painting & Finish Work 28 02-17-2017 08:29 PM
Flat roof - What roofing system should I use? acro Roofing 10 04-15-2013 05:47 PM
Hidfast Gun redwood Decks & Fencing 28 06-08-2012 07:43 PM
Flat Roof Deck Question GordC Decks & Fencing 13 06-07-2009 08:20 PM
Flat roof over garage leaking under exterior walk out door IHI Roofing 18 05-30-2006 10:28 PM
