Flat Roof, Torch Roof Question
Old 07-02-2009, 08:37 AM   #1
enforcer's Avatar
Trade: windows-siding
as i said earlier we have 60 sq of regular pitch roof and 10 sq of a flat/torch roof. is the install any more difficult on a flat torch roof? my installer seems to charge more for a flat for some reason. is the material more,what kind of material?
thanks guys
enforcer is offline
Old 07-02-2009, 10:39 AM   #2
Handle It!
MALCO.New.York's Avatar
Re: Flat Roof, Torch Roof Question
thanks guys
Enforcer my friend and Compadre.........
Material is more and the tools and experience to install is greater. I have NO idea concerning the Local Pricing. I have not touched a Roof since I was in Atlanta!
I have ALWAYS used Firestone Granulated. If not granulated you need to Aluminum Coat one-month later. Then sell them a Service/Repaint Contract.
http://www.contractortalk.com/f15/fa...aterial-53661/
http://www.contractortalk.com/f15/fl...uestion-14556/
Protrusions are what make the Flat Install pricier. Stink Pipes, Vents, Skylites..........All of these things need be wrapped in a VERY particular and time consuming manner.
Ultimate Wisdom---------
MALCO.New.York is offline
Old 07-02-2009, 11:02 AM   #3
Patrick's Avatar
I would use TPO or even base and cap before I would do a torch down.
Whats kinda odd is home depot now sells torch down scary
Originally Posted by Celtic
Like I said...I'm sure you are very good at what you do ~ whatever that is and where ever it happens.
Patrick is offline
Old 07-02-2009, 11:34 AM   #4
genecarp's Avatar
YES, torchdown requires a different skill set than regular roofing, also the risk and liability associated with torchdown is much greater, AS IN , keep the hose handy. G
genecarp is offline
The Following User Says Thank You to genecarp For This Useful Post:
MALCO.New.York (07-02-2009)
Old 07-02-2009, 11:42 AM   #5
enforcer's Avatar
as always,thanks for the responses guys...
enforcer is offline
Old 07-04-2009, 08:17 PM   #6
Gilby's Avatar
Trade: Roofing Contractor
As Genecarp said the Liability issue is huge and there is not many insurance companies out there that will insure torch down roofing. That may have something to do with why it is more expensive. I would use Duro-Last
www.durolast.com
Gilby is offline
Old 07-04-2009, 08:22 PM   #7
Lack Of All Trades
Darwin's Avatar
Trade: Professional handyman services
thanks guys
he charges more because the application takes a bit longer and is a bit more involved process...
Darwin is offline
Roof Estimating And Drawing Program Ed the Roofer Roofing 32 03-07-2011 10:50 AM
rubber roof over rolled asphalt ? ? btownpa Roofing 2 03-06-2009 03:03 PM
adding pitch to a flat roof. PAPERSTREET Roofing 3 03-07-2008 08:38 PM
Flat roof framing red_cedar Framing 3 02-28-2006 10:48 AM
flat roof vs. gable Iloveneworleans Roofing 2 02-18-2006 07:51 PM
