Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Roofing
Old 11-05-2009, 09:51 PM   #1
Trade: Roofer
Flat Roof/Steel Deck/Insulation
Is it a requirement to fill the flues on a steel deck or not? I Thought it was a given. haven't found any info that says yeah or ney..............
Case in point.... We're ripping a b.u.r. that has 1 1/2" in the flues(two layers of3/4")and 1 1/2" Iso on top of that. We found some wet and I made the comment that I didn't want to have to mess with the insul. in the flue that was stuck to the bottom of the 1 1/2" iso....So then this 25 yr. roof veteran says " f-it u dont need to fill the flues" Granted, he knows more than I about commercial flat roofing, but doesn't give a fudge about anything if its close to HAPPY HOUR, So am I wrong?? Is it just a quality thing? With 1 1/2" you'd have to fill in the flues. Its just that simple. Oh yah, he had missed an hour of happy hour when he said that.
Thanks
workorfish is offline   Reply With Quote
Old 11-05-2009, 10:19 PM   #2
I have never seen the lower flutes filled in, always just rigid on top of the whole assembly
Anti-wingnut is offline   Reply With Quote
Old 11-06-2009, 08:54 AM   #3
stop botherin' me!
Grumpy's Avatar
Trade: Roofing Siding Gutters Windows
Rigid over the entire metal deck. You don't need to fill the fluting. The insulation must be 1 1/2" thick however or risk damage from foot traffic.
Good enough is never good enough, but in this case, he was right.
-Grumpy
Chicago Gutters Chicago Roofing
Grumpy is offline   Reply With Quote
Old 11-06-2009, 10:35 AM   #4
Industrial and Commercial
Trade: Roofing
I've got 22 years on commercial flats and the only time I have ever filled the flutes was when it was spec'd and I was paid for it. It is no code that I know of.
rc-construction is offline   Reply With Quote
Old 11-07-2009, 08:25 PM   #5
Trade: Roofer
Thanks......... Huh........When someone installs the steel deck upside down.................. Then you have to fill the flues to support the 1 1/2" ISO.......... He ran circles around me today..... F-ck.... When ya got it down ... 20'x100'sheets ....ya got it down........ (head hung low).. I'll make it up in when we fab and install the metal............ somewhat anyhow.....
flat or satin for barn Traditions2 Painting & Finish Work 20 05-14-2009 09:07 AM
Primer / Sealer VS Flat paint A+ Texture Painting & Finish Work 20 05-01-2009 08:37 PM
Paint or stain on hardi plank? Jer Painting & Finish Work 23 01-31-2009 06:05 PM
I find some of these names,shocking sjm Painting & Finish Work 7 08-20-2007 05:51 AM
