Flat Roof Question
Old 10-01-2008, 08:45 PM   #1
USER8493893's Avatar
Flat Roof Question
Client wants a price on a flat roof repair. it is about 20 years since any one has done anything right up there. there is a million layers of tar which is all cracking and leting in water. new is out of the question not enough cash. so i informed him that there's no warrenty but he wants to band-aid the thing what do you guys think i should use just more tar?
USER8493893 is offline
Old 10-01-2008, 08:52 PM   #2
ContractorTalk Flunkie
dayspring's Avatar
Re: Flat Roof Question
I know times are hard and we are all doing what we can to make a buck, but why don't you call a roofer that does this all the time, get a price then let him do it, make a buck, go on about your merry way. Don't jepordize yourself with something like this if you not familiar with it
T.C.
"Never met a man yet that I couldn't learn something from"
Met a few you couldn't teach though
http://remodelingncarolina.com
dayspring is offline
Old 10-01-2008, 09:24 PM   #3
Ed the Roofer's Avatar
Trade: Roofing Contractor
Check with the local building code department and see if One Million and One layers are allowed and get back to him with their regulations.
Ed
Ed the Roofer is offline
Old 10-01-2008, 09:28 PM   #4
genecarp's Avatar
QUICKSILVER
http://www.texasrefinerycoatings.com...f_coating.html
genecarp is offline
Old 10-01-2008, 09:30 PM   #5
APPLIED RIGHT
johnk's Avatar
Trade: roofing
No more Tar!!!
"A Roof is only as good as it is Applied"
johnk is offline
Old 10-01-2008, 09:53 PM   #6
Roofing and Architectural
Renegade's Avatar
Trade: Roofing and Architectural Metals
Ed
Problem with that, Ed, is that all that tar is considered maintenance...not a roof layer.
Some jobs you just have to stand your ground on. This sounds like one to either do right or don't do at all. Sometimes that's tough but it's all part of the game.
Renegade is offline
Old 10-02-2008, 12:20 PM   #7
RooferJim's Avatar
Trade: roofing
Is there a gravel surface ? you can do spot repairs with a good mastic and membrane. use Karnak flashing cement or Bulldog. if there is gravel you will need a scratch bar and a little bit of skill in using it. you will also need a trowel, I like to use a good margin trowl. that way i can clean every bit out of that bucket. dont forget to sweep clean all dust from work area as well and apply mastic at about a 1/4" thick consistancy then you can rub in your membrane"ashpalt impregnated mesh" into the mastic and rub it in nice, then apply another layer over it. Keep it neat and you wont get covered in the stuff.
RooferJim is offline
garage roof framing question basslander2008 Framing 20 04-27-2008 05:22 PM
Help - Secondary roof Drain Question? works4me Roofing 3 04-18-2008 01:08 AM
metal cold roof question ..... Vermonster Roofing 30 09-06-2007 01:30 AM
Another roof framming question dproc Framing 1 04-01-2006 03:14 AM
