Flat Metal Roof?
Old 07-03-2006, 05:18 PM   #1
Soon to be senile
Shamrock's Avatar
Trade: Remodel and repair
Flat Metal Roof?
Several years ago I built a pergola/trellis/whatever the hell you want to call it...basically just what I call a shade roof over an existing deck that leads to the front door of the home...8' x 20'. No big deal. Customer now wants me to remove the 1x4's I originally laid over the rafters and replace them with metal roofing. There's absolutely no way to get any pitch out of the thing unless I get the homeowner to accept the fact that I'd have to re-do the whole perogla...which she doesn't want. Anyone had any experience with metal roofing used in this manner...zero pitch?
Shamrock is offline
Old 07-03-2006, 06:02 PM   #2
joasis's Avatar
Re: Flat Metal Roof?
I am guessing it is 8 feet wide? meaning the metal sheets will be 8 feet? (or so) Some metal buildings are designed with 1/4 on 12 pitch...and they work...I suppose if you were able to get any space on the straps you will attach the metal to and get at least a fall going away from the house, then you could flash and use an expanding closure to seal it. If it stayed perfectly flat, it would still work, but it will hold water...maybe not much, but some.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Serving Oklahoma Statewide
joasis is offline
Old 07-03-2006, 07:41 PM   #3
Commercial Roofing
AaronB.'s Avatar
Trade: Roofing Contractor
Yeah, you can build several z closures of progressive sizes to set the panels onto and creat some pitch.
http://www.roseroofing.net/
Seamless Industrial and Commercial Roofing Systems, Residential Repair. For Those That Demand Quality!
Free roof inspections within 12 miles of our locale.
AaronB. is offline
Old 07-03-2006, 07:46 PM   #4
Soon to be senile
Shamrock's Avatar
Yeah it's 8' wide but to support the metal roof, I'd be running the material length wise...20' across the existing rafters. It looks like the material of choice that the homeowner wishes is a product called Advantage Lok by Union Corrugating Company. It has a 1 3/8" high rib that inter locks with each preceding piece. Looks like it should remain fairly water tight at each joint. I guess my main concern is that at 20' of length, while water won't be a major issue, some amounts will remain on the roof for an extended period of time especially in any possible low spots.
Oh..and adding any pitch will place the metal roof slightly above the existing shingled roof...the thing either has to remain flat or suffer a rebuild. I can understand where the homewoners coming from...she spent a lot of time painting the pergola and added quite a bit of little detail touches...she really doesn't want to have them screwed up.
Shamrock is offline
Old 07-03-2006, 08:44 PM   #5
Class A Contractor "BLD"
Gordo's Avatar
Trade: Remodeling and home improvements
Your gut is telling you what to do and the HO is trying to change what you already know. Do not go against the gut just because she already did some fluff and paint. You will be the one to live with the mistake.
Looks like some pros were here.
Gordo is offline
Old 07-05-2006, 10:20 AM   #6
Bah Humbug!
Grumpy's Avatar
Copper, soldered seam, flat lock panels. Small tedios but a very nice roof. I don't think I'd do it on zero pitch, but it's the best metal flat roof system I know of.
Grumpy is offline
Old 07-05-2006, 04:44 PM   #7
Commercial Roofing
AaronB.'s Avatar
Flatlocked and soldered copper is good for dead level. If done properly, nothing can get through it and there is zero watersoak.
AaronB. is offline
Old 07-07-2006, 05:53 AM   #8
Soon to be senile
Shamrock's Avatar
Thanks for the advice guys...chatted with the homeowner and we decided to put a couple panels up and watch it for a week or so...at least one good rain and see what happens. Homeowners a good egg and knows if it doesn't function as we hope, we'll then look at other options.
Shamrock is offline
metal cold roof question ..... Vermonster Roofing 30 09-06-2007 01:30 AM
Low Pitch Roof solutions Fixer Roofing 4 02-18-2007 11:09 AM
Flat roof over garage leaking under exterior walk out door IHI Roofing 18 05-30-2006 10:28 PM
Torch down(flat roof) leaks BAD...can you give advice ASAP? Detail Guy Roofing 21 01-16-2006 02:36 PM
Do You Need A New Roof ??? Perfect Roofing Roofing 0 02-10-2005 02:46 AM
