Felt Paper Or Not Under Metal Rofing
Old 12-09-2006, 09:01 AM   #1
gman's Avatar
Trade: framer
Okay I know this is a professional site, didn't think I would geta good answer on DIY I have
a roof decked with OSB , questions is Some say no Felt, other say need felt because of sweating and it will root the OSB , 30# felt or not?. That is the quesation. The house is in eastern TN
Thanks
gman is offline
Old 12-09-2006, 09:30 AM   #2
GC/ Master Electrician
Ken@K&R's Avatar
Trade: General Contractor/ Master Electrician
Send a message via AIM to Ken@K&R Send a message via Yahoo to Ken@K&R
Re: Felt Paper Or Not Under Metal Rofing
We always use felt under them. We are East TN. too.
Ken
Ken@K&R is offline
Old 12-09-2006, 10:48 AM   #3
joasis's Avatar
One of my comany's specialties is metal roofing, and we have done it both ways....but the safe answer is this: Felt is dirt cheap, why not? In my new construction, I do not deck the roof, but rather use 2X for strapping, and roll insulation before metal....you would not believe the break on the cooling load on a typical home......in Oklahoma, attic temps in the summer can easily reach 140 degrees....with insulation under the metal, temps are 40 degrees or more lower.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Serving Oklahoma Statewide
joasis is offline
Old 12-10-2006, 10:34 PM   #4
RooferJim's Avatar
Trade: roofing
most codes and good roofing practice would require felt. with metal roofing its also a good idea to put a layer of red rosin paper between the felt "or Ice&water shield" and the metal that way it wont potentialy stick to it and cause oil canning and would allow for expansion.
RooferJim
www.jbennetteroofing.com
RooferJim is offline
Old 12-10-2006, 11:13 PM   #5
Charitable animal
Bone Saw's Avatar
Trade: decks
RooferJim
I agree
Bone Saw is online now
Old 12-11-2006, 04:12 AM   #6
joasis's Avatar
RooferJim
And of course, there are a lot of styles of metal roofing....what we install,(vertical panel) for instance, does not oil can.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
joasis is offline
Rosin paper or roofing felt? Mike Finley Flooring 35 01-06-2009 03:06 PM
metal cold roof question ..... Vermonster Roofing 30 09-06-2007 01:30 AM
Felt paper used as insulation??? Age General Discussion 9 06-10-2006 04:25 PM
