Exposed Fastener Metal Roofing
Old 07-29-2017, 11:42 AM   #1
MLY's Avatar
Trade: Solar Carports and Solar Trackers
Rewards Points: 4
We are doing a carport.
The customer insists on exposed fastener roofing so that they can mount a solar water heater in the future.
The heater panel installation calls out using metal roofing mount screws as anchors.
Can anyone recommend an inexpensive system with fairly large sheets.
Home Depot has 2' x 8' I think.
I'd like bigger so fewer components.
It's just a car port so it doesn't have to be 100% watertight.
Also the roofing will not have plywood or roof underneath it. Just mounted to strapping so it needs to have some integrity of it's own.
Plastic, Aluminum or Steel are all potentially fine.
I apologize if I could have easily found the answer by searching.
Thanks
MLY is offline
Old 07-29-2017, 12:22 PM   #2
FrankSmith's Avatar
Rewards Points: 4,154
Re: Exposed Fastener Metal Roofing
Thanks
Talk to any lumber yard. They should be able to order you steel to the length you tell them to. I would put some plywood under there. to eliminate most of the noise when it rains.
FrankSmith is offline
Old 07-29-2017, 07:15 PM   #3
MLY's Avatar
Rewards Points: 4
Thanks
We are really an engineering service firm.
Hadn't considered the commercial yards.
I'll check them out.
Thanks
Michelle
MLY is offline
Vent under metal roofing hacksaw Roofing 6 06-02-2014 07:52 AM
Residential: Metal roofing? bensaccount Roofing 16 07-05-2013 04:45 PM
Metal roofing jason72081 Roofing 4 03-25-2013 09:40 PM
Metal Roofing question? fullhouse Roofing 9 07-01-2011 10:32 AM
metal roofing on interiors???? nightingalematt Roofing 17 06-24-2009 10:20 AM
