Estimating, Roofing Cost For Elastomeric Coating.
Old 10-21-2008, 10:09 PM   #1
CNC's Avatar
Trade: Electrician
Rewards Points: 152
I Have a shop with t a corrugated roof, one slant, with around 25-30 degree slope. rectangle.
Its around 8500 square feet, i just coated it with elastomeric paint, what would you guys have charged for this? can you do square foot pricing, JUST wash for prep, and coat. No masking involved. I just want to know how much i could have gotten it done for?
CNC is offline
Old 10-22-2008, 12:54 PM   #2
Grumpy's Avatar
Rewards Points: 2,000
Re: Estimating, Roofing Cost For Elastomeric Coating.
Elastomeric paint or elastomeric roof coating?
Who's product are you using? At what rate are you going to apply (how many gallons per square)?
Elastomeric is a funny thing, there are so many variables. Every manufacturer is different, and the prices range incredibly.
I'm doing one next week on a flat roof, about 1/8" of slope per foot. We will be doing a fully polyester reinforced elastomeric built up system for about $350 a square using about 5 built up gallons per square. I am using Adurel which is alot more pricey than most. On a metal roof we'd be less of coarse, since it's not built up, nor reinforced. In addition it's usually sprayed on metal roofs which is faster. We pour it on our low slope roofs.
How much would I be? Material alone would cost me nearly $4k at 1.4 gallons per square in acrylic. Solvent based would cost me more. That's a 3 man 2 day job so add $4,000 for labor and burdens and some overhead. 11% for salesman... How much profit do you want?
-Grumpy
Chicago Gutters Chicago Roofing
Grumpy is offline
Old 10-22-2008, 01:49 PM   #3
roofpro350's Avatar
Trade: Commercial Roofing Contractor
The cost for a coating like you stated runs about $1.40 to $1.75 a square foot. That's labor and materials, power wash, 2 coats of elastomeric. tape minimal seams and seal fastener heads as needed.
roofpro350 is offline
Old 10-22-2008, 03:27 PM   #4
CNC's Avatar
Trade: Electrician
Rewards Points: 152
i forget the brand name, its acrylic roof coating, 3 gallons per square if i recall correctly? i can get those details tommorow.
I do know we used 13 x 5 gallons for half the roof at one coat, and the second coat over just the fasteners. so 65 gallons total, for the first half.
we will pick up another 65 gallons tommorow, and do the same for the second half. at 115 per 5 gallons, its 3000 total for material.
we are debating a 3rd coat.... what do you think?
CNC is offline
Old 10-23-2008, 06:57 AM   #5
Grumpy's Avatar
Contact the manufacturer of the product. They may have a highly reflective clear coat you can use for your 3rd coat.
-Grumpy
Grumpy is offline
Old 10-23-2008, 08:08 AM   #6
roofpro350's Avatar
When coating a metal building with white elastomeric the existing surface may show through the coating a little, if a primer was not used first a third coat will cover and look better but the roof still should be watertight.
Normally they call for 1.5 gallons per square on metal roof per coat. Its all in the preperation.
Old 12-03-2008, 09:51 PM   #7
buildpinnacle's Avatar
Trade: Public Insurance Adjuster
I have used several different products and there are quite a few variables. On a corrugated roof, our scope would be to powerwash, prime with rust inhibative primer such as zinc chromate or zinc oxide, replace all loose or missing fasteners with oversized fasteners, seal all fasteners with elastomeric mastic (hershey kiss), seal all vertical and horizontal seams with three course application of elastomeric mastic and membrane (4" or 6"), seal all penetration bases with three course application of elastomeric mastic and membrane (4" or 6"), Replace all missing or damaged vent caps, apply two coats of elastomeric mastic (Topcoat, Mulehide, or RoofGuardian) at rate of 1.25 gallons per sq per coat. Second coat is applied 24 hours after initial coat and is applied in opposite direction as first coat to catch all holidaze.
We generally charge from $185.00 to $240.00 per square for standard metal roof coating. All our roof coatings are sprayed. Coatings are hands down the best money in the roofing business.
Pinnacle Limited - Public Insurance Adjusters
http://pinnaclelimited.com
http://harrycane.com - An Amusement Park for Weather Freaks
buildpinnacle is offline
Old 12-08-2008, 06:56 AM   #8
Commercial Roofing
AaronB.'s Avatar
Trade: Roofing Contractor
I could install a 48 mil ADFT polyurea membrane fully adhered for about 2.50 a foot.
WAY better than any acryics.
I was usung the GAF Topcoat system, applied to specs, and they have all failed within five years, except for one that was a 6/12 over smooth BUR. The rest have washed off, and we are re-coating with our instant set polymer system.
http://www.roseroofing.net/
Seamless Industrial and Commercial Roofing Systems, Residential Repair. For Those That Demand Quality!
Free roof inspections within 12 miles of our locale.
AaronB. is offline
Roof Estimating And Drawing Program Ed the Roofer Roofing 32 03-07-2011 09:50 AM
EPDM Roofing orson Roofing 7 09-27-2008 08:47 AM
Coating for metal trailer roof? buildenterprise Roofing 1 08-30-2008 08:24 PM
