EPDM Roof With A Twist - Page 3 - Roofing - Contractor Talk
Old 02-23-2018, 08:04 PM   #41
Sealik's Avatar
Rewards Points: 128
Re: EPDM Roof With A Twist
Originally Posted by madrina View Post
on second look, those roof edges arent at all as bendy as I imagined. edge metal will fit fine on that.
Ya...in 10ft of roof line the pitch only changes from 2/12 to 1/12. The length (39') of the roof rises 3/4" per ft.....whereas the width (14') is a 2/12 pitch......2" per ft.
Sealik is offline
Old 04-03-2018, 02:30 PM   #42
Sealik's Avatar
Rewards Points: 128
Looks like the tarp managed to keep the roof dry.........I was somewhat concerned over the course of winter...lol.
I've decided to install the epdm asap...weather permitting. Is there a temp that is the most conducive for the install? Here's a drawing of the layout of the epdm and fascia detail.....will start at the ends and finish in the center. Seems I can't find any termination bars locally, so....I figure I I could sandwich the epdm between the 2x10 and 1x12 fascia?... with the same results. The epdm should be wrapped over the edge to seal it up properly, do not want any air or water getting underneath when the tiny home is moved. Still not sure whether to use any cover board at all, seems to be mixed opinions on that. Would the washers/screws be visible after the epdm is laid? Assuming they would telegraph through?
EPDM roof with a twist-img_2129.jpg   EPDM roof with a twist-img_2244.jpg   EPDM roof with a twist-img_2231.jpg
Sealik is offline
Old 04-04-2018, 12:45 AM   #43
Designer/Contractor
Rio's Avatar
Rewards Points: 2,386
Your detail looks like it could be a water trap with the EDPM being sandwiched between the fascias............
Rio is online now
The Following User Says Thank You to Rio For This Useful Post:
Sealik (04-06-2018)
Old 04-06-2018, 04:01 PM   #44
Sealik's Avatar
Rewards Points: 128
Yeah....have a Plan B in the works....lol
Will reduce the size of the 2x4 nailer and increase the width of the bottom metal facia to 5"ish. Just so the custom drip edge isn't isn't too flimsy on the vertical.
Sealik is offline
Old 04-06-2018, 04:25 PM   #45
Designer/Contractor
Rio's Avatar
That looks better, if you can, consider putting a capillary break along the bottom of the 1x or run the metal fascia all the way up.
Rio is online now
Sealik (04-06-2018)
Old 04-06-2018, 04:44 PM   #46
Sealik's Avatar
Rewards Points: 128
I figured i would cut the backside bottom out of the 1x4...half the width of a table saw blade. Maybe 1"ish deep (high)....so one could stuff the metal fascia in after the fact. It will be tight in the cut....but still float. Less of a chance of 'buckling' when the home is moved......not that it would buckle...lol.
Caulk if necessary.....
Sealik is offline
The Following User Says Thank You to Sealik For This Useful Post:
Rio (04-07-2018)
Old 04-15-2018, 10:48 AM   #47
Shingler extraordinaire
A&E Exteriors's Avatar
Trade: Roofing, Framing, siding, decks
Rewards Points: 11,664
You are way overcomplicating this
A&E Exteriors is offline
Old 04-15-2018, 12:11 PM   #48
Sealik's Avatar
Rewards Points: 128
Well...I'd probably cut the epdm flush with the edge of the fascia and simplify things.....but....since it's going to be moved down the highway at 50 mph+ I decided to seal the epdm a little better with some 'termination bars'.
Sealik is offline
A&E Exteriors (04-16-2018)
Old 04-15-2018, 12:47 PM   #49
Sealik's Avatar
Rewards Points: 128
Also...it enables me to get the epdm on the roof without any drip edge/ fascia detail. Get the roof sealed up and worry about the rest after the fact. Besides....it will look good when I'm done.....
Sealik is offline
Old 06-02-2018, 05:48 PM   #50
Sealik's Avatar
Rewards Points: 128
Cut the first sheet to see how it would lay...about 15x6ft. As you can see there a few ridges in the epdm, not sure if that would broom out...lol. Due to the twist...that section of roof is a little over an inch out of square. This is the worst part of the roof though, will get better as I work towards the center of the building.
Sealik is offline
Old 06-02-2018, 08:25 PM   #51
Looks good. It should broom out pretty decent, you may end up with a "worm" or two but it's no big deal
The Following User Says Thank You to A&E Exteriors For This Useful Post:
Sealik (06-06-2018)
Old 06-06-2018, 08:39 AM   #52
Sealik's Avatar
Rewards Points: 128
I forgot to mention that the piece of epdm was sitting in the sun for about an hour and was broomed a couple of times prior to pic....so it didn't look that good when i initially rolled it into place....
Going to start on the roof later today...is there a max time letting the epdm relax in the sun?
Sealik is offline
Old 06-06-2018, 08:43 AM   #53
No. It can relax as long as you want to wait
Sealik (06-06-2018)
Old 06-06-2018, 08:47 PM   #54
Sealik's Avatar
Rewards Points: 128
Other than a nasty looking worm at the lower edge of the roof when we
started...it came out rather well.
Which by the way......rolled out.
Zero anomalies.....most excellent.
Although...have yet to glue the center piece
Thanks guys..
EPDM roof with a twist-img_2313.jpg   EPDM roof with a twist-img_2314.jpg   EPDM roof with a twist-img_2315.jpg   EPDM roof with a twist-img_2307.jpg
Sealik is offline
Old 06-06-2018, 09:11 PM   #55
Thanks guys..
Looking good!
Sealik (06-07-2018)
Old 06-07-2018, 02:22 PM   #56
Sealik's Avatar
Rewards Points: 128
Looking good!
Hi...have one possible 'issue'....the epdm is 10' 1 1/2" wide, not 10' as I assumed..lol..which increases my lap distance a bit...lol. Around 7 3/4" instead of 6". Will be using 6" secure tape.
Should be OK....correct?
Thanks...
Sealik is offline
Old 06-07-2018, 02:28 PM   #57
John the Builder
SmallTownGuy's Avatar
Trade: Carpenter/Builder
Rewards Points: 962
This thread was started on 09-30-2017.
You lonely or just plan on talking about it until somebody bails you out?
SmallTownGuy is offline
Old 06-07-2018, 02:42 PM   #58
Sealik's Avatar
Rewards Points: 128
Well....if you would of read the thread you would of came to the conclusion that winter had arrived and I could not do anything until a few days ago.
Bails me out?
Roof is pretty much finished....
Sealik is offline
Old 06-07-2018, 03:21 PM   #59
John the Builder
Rewards Points: 962
Bails me out?
So: everything I said is true. And you be lucky Andy didn't charge you by the hour - or by the month.
Old 06-09-2018, 06:31 PM   #60
Sealik's Avatar
Rewards Points: 128
Interesting how the water runs relative to the changing pitch....over and or away from the seams heading to the 2 corners of the structure.
EPDM roof with a twist-img_2317.jpg   EPDM roof with a twist-img_2318.jpg   EPDM roof with a twist-img_2319.jpg
Sealik is offline
Joe Fusco's roof framing calculator bookmdanno Roofing 2 07-18-2012 02:41 PM
Correct Substraight for EPDM roof. Warmsmeallup Roofing 11 05-19-2009 04:56 PM
EPDM Roof Question, Re-stripping seams Aggressive Roofing 14 03-12-2009 06:53 PM
Low Pitch Roof solutions Fixer Roofing 4 02-18-2007 10:09 AM
