EPDM Roof With A Twist
Old 09-30-2017, 05:23 PM   #1
Sealik's Avatar
Rewards Points: 88
Hi guys....and girls... Designed a tiny home with a slightly different roof line and have a couple of questions on the install. I'm using 60 mil Carlisle EPDM.....unfortunately I couldn't get anything wider then 10ft, so they'll be 4 seams and the first one will be centered at the middle of the 14'x40' home and working out each way from there. Roof has 7/16 OSB (rough side up) with rafters at 16" centers. I'll go over the roof deck with some 100 grit and soften any burs etc. before I lay the EPDM. Was thinking of wrapping the EPDM over the edges about 3" and fasten with roofing nails, possibly put a bead of lap sealant and or between the EPDM and wood 2x10 facia..(?), where the nails will penetrate. Place brown aluminum drip edge (2 1/2" (top) x 1 3/4" (hangs down facia)) on roof and securing with ring shanked nails/roofing nails(?) and finish with the Carlisle 6" overlayment strip. Cut EPDM flush with the bottom of the drip edge. 10" metal facia will be stuffed up between the membrane and drip edge.....caulked where the drip edge meets the facia if need be. Alls seams with have the 6" Carlisle Securtape. Most likely use 2 coats of bonding adhesive for maximum adhesion on the OSB. Does this sound OK relative to the design of the roof? Do i need termination bars? Assuming I need 1/8" gaps between the 4x8 sheets of OSB. Also....I'm putting a low slope wood stove flashing on the roof (stove pipe will have a spark arrester) and not quite sure how to seal it....being galvanized steel and all. And......Being that the trailing edge changes to a leading edge on the same side of the roof...should I be using any lap sealant on the edge/corner of the roof.......where the EPdM stops?
Ends of roof are a 2/12 pitch (opposite to each other) and rises and falls 3/4" per foot, flat in the very center.
Thanks.
Sealik is offline
Old 09-30-2017, 07:00 PM   #2
Sealik's Avatar
Rewards Points: 88
Re: EPDM Roof With A Twist
Also should mention that there will be 3.5" of closed cell spray foam on the underside of the roof.
EPDM roof with a twist-img_1734.jpg   EPDM roof with a twist-ccad5a_54e50f63fea54e399099f06518f84d94-mv2.jpg
Sealik is offline
Old 09-30-2017, 07:24 PM   #3
slowsol's Avatar
Rewards Points: 2,212
I like a cover board between osb and plywood. The rest sounds fine. I typically donít see any type of seam roll on epdm.
-John
slowsol is offline
The Following 2 Users Say Thank You to slowsol For This Useful Post:
A&E Exteriors (09-30-2017), Sealik (10-01-2017)
Old 09-30-2017, 08:28 PM   #4
Shingler extraordinaire
A&E Exteriors's Avatar
Trade: Roofing, Framing, siding, decks
Rewards Points: 10,872
Skip the sanding and put down a layer of IOS or at the very least celotex
A&E Exteriors is online now
Old 09-30-2017, 09:26 PM   #5
Cheap insurance
Also I prefer to cut the edge flush as it makes the drip application much cleaner. Also the only place I ever caulk is where my coverstrip overlaps, just a little dab in the corner.
Old 09-30-2017, 11:18 PM   #6
Designer/Contractor
Rio's Avatar
Rewards Points: 1,256
Very interesting skewed roof, wonder if there will be issues because of it? I really like the design, so innovative and looks good also!
Rio is online now
Old 10-01-2017, 09:29 AM   #7
Sealik's Avatar
Rewards Points: 88
Any cons when not using the cover board? Not sure I can even get it in this locale. Thought the seam tape was the norm....lol
Sealik is offline
Old 10-01-2017, 09:32 AM   #8
Sealik's Avatar
Rewards Points: 88
Sanding would probably take about an hour....just to knock down any area where the nail left any splinters. I'll try....but not sure i can get ISO (?) or celotex.
Sealik is offline
Old 10-01-2017, 09:34 AM   #9
Sealik's Avatar
Rewards Points: 88
Cheap insurance
Which edge?
Sealik is offline
Old 10-01-2017, 09:35 AM   #10
Well, I'm sure in Canada you can get iso board. A coverboard of some sorts over the sheeting and under the membrane is the cheapest insurance you can get. Also adds to your insulation value
Old 10-01-2017, 09:38 AM   #11
Originally Posted by Sealik View Post
Which edge?
Where the roofline meets the facia, if you fold and nail it over the edge it has a tendency to make your drip look like
Old 10-01-2017, 09:40 AM   #12
Sealik's Avatar
Rewards Points: 88
Thanks.....Good question....we shall see....lol. For application of EPDM- the 'only' issue I can see would be trying to lay larger sheets on the roof to glue together? Because of the skew....
Sealik is offline
The Following 2 Users Say Thank You to Sealik For This Useful Post:
A&E Exteriors (10-01-2017), Rio (10-01-2017)
Old 10-01-2017, 09:47 AM   #13
Sealik's Avatar
Rewards Points: 88
The insurance would be if the EPDM had to be ever removed? And the smoother surface itself? I'm above the required R value for roof insulation. Would the roof require a nailer board around the perimeter, next to the fiberboard? For a more solid edge to nail the top of the drip edge to.
Sealik is offline
Old 10-01-2017, 09:52 AM   #14
Unsur ance against a spli.ter poking a small hole in the membrane of a faster backing out and puncturing it. I wouldn't sweat a nailer board, just make sure you use a long enough fastener to grab and hold the framing. Either a 3" roofing nail (ring shank if you can find it) or a flat roof screw with no plate and you will be fine
The Following User Says Thank You to A&E Exteriors For This Useful Post:
Sealik (10-01-2017)
Old 10-01-2017, 10:14 AM   #15
Sealik's Avatar
Rewards Points: 88
Thickness of fiberboard? Also...how many mechanical fasteners per 2x8 sheet? Thanks...
Sealik is offline
Old 10-01-2017, 10:26 AM   #16
Fiberboard is the celotex I was referring too and is usually 1/2" thick. On a 2x8'sheet I would use 8 screws and plates
Old 10-02-2017, 01:19 PM   #17
Sealik's Avatar
Rewards Points: 88
Talked to the local building supply company who in turn contacted a couple of roofing supply companies and.....the only thing available would be the 1/2" donnacona wall fiber board (garbage). Still waiting to here back from a few other sources....but doesn't look good.
Sealik is offline
Old 10-02-2017, 02:01 PM   #18
That is what you want, same as celotex....it is simply to keep something stupid (splinter nailhead etc) from making a pinhole that you will never find when it leaks
Old 10-02-2017, 02:02 PM   #19
Old 11-07-2017, 10:24 PM   #20
roofingrenonv's Avatar
Trade: roofer
Rewards Points: 8
Very cool design but looks like a nightmare with sealing, insulation, and upkeep.
Emily
http://roofingrenonv.net/
roofingrenonv is offline
Joe Fusco's roof framing calculator bookmdanno Roofing 2 07-18-2012 02:41 PM
Correct Substraight for EPDM roof. Warmsmeallup Roofing 11 05-19-2009 04:56 PM
EPDM Roof Question, Re-stripping seams Aggressive Roofing 14 03-12-2009 06:53 PM
Low Pitch Roof solutions Fixer Roofing 4 02-18-2007 10:09 AM
