Epdm Lap Seal
Old 08-17-2009, 10:12 PM   #1
thorroofer's Avatar
Trade: Roofing
Epdm Lap Seal
I have been roofing a long time and I will never understand why rubber companies want you to use lap seal. Every EPDM rubber roof I have ever been on the lap seal is always cracked up in 3 years or less. You can not trust glue and primer by itself so I use solar seal it is the best chaulk there is. I think it is even better than NP 1 . I had allot of problems with geo cell, Its not sticky enough . It will hang off a brick chimmney like spaghetti. With solar seal there will never be any leaks , it is a commercial roofing chaulk but allot of people will use it for siding. There is allot of diffrerent types of chaulk that almost have the same name. Solar seal is hard to find so I would order strait from the supplier
thorroofer is offline
Old 08-18-2009, 02:32 AM   #2
Commercial Roofing
AaronB.'s Avatar
Trade: Roofing Contractor
Re: Epdm Lap Seal
Isn't the lap seal a temporary measure designed to seal the lap until the seam adhesive can fully cure?
It is not needed with seam tapes, correct?
http://www.roseroofing.net/
Seamless Industrial and Commercial Roofing Systems, Residential Repair. For Those That Demand Quality!
Free roof inspections within 12 miles of our locale.
AaronB. is offline
Old 08-18-2009, 10:17 AM   #3
thorroofer's Avatar
Trade: Roofing
Re: Epdm Lap Seal
I thought so too but I would never Trust just glue on EPDM .
I am a Virginia beach Roofing Contractor serving all of Hampton roads. Norfolk, Chesapeake, portsmouth, Virginia Beach, Hampton and Newport News, and Suffolk Virginia. All of the seven cities.
http://www.exteriorexpertsofvirginia.com/
Old 08-21-2009, 10:05 AM   #4
Commercial Roofing
AaronB.'s Avatar
Re: Epdm Lap Seal
Me neither :-) This is why I do seamless roofing now.
AaronB. is offline
Old 08-25-2009, 10:52 PM   #5
Commercial Roofing
tekwrytr's Avatar
Trade: Commercial Roof Repair and Re-Roofing
Re: Epdm Lap Seal
Most EPDM installations now use Inseam Tape (double-sided adhesive) for seams and endlaps. Scrub the overlapped and overlapping areas with ScotchBrite pads dipped in QuickPrimerPlus or some equivalent product, put down the tape (sticky side down), flop the overlapping portion of the sheet over it, then pull off the paper backing to expose the upper adhesive surface. Roll thoroughly and you are done--no lap seal, except around patches, flashings, etc.
Lap seal used to be used as insurance for laps made with splice adhesive. Inseam tape is a LOT better.
Commercial EPDM Rubber Roof Repair - Maintenance - Re-Roofing Exclusively. Serving the Twin Cities, MN Metro area since 2001.
http://www.tekwrytrs.com/roofing/
tekwrytr is offline
Old 08-25-2009, 11:04 PM   #6
oldfrt's Avatar
Re: Epdm Lap Seal
My understanding was the lap sealant was to keep dirt from getting under seam(capillary action) and causing an uplift at edges leading to failure.
It was suppose to be put on after 24hrs,so all gases from seam seal had a chance to escape.
oldfrt is offline
The Following User Says Thank You to oldfrt For This Useful Post:
Tom Struble (08-26-2009)
Old 08-26-2009, 08:33 AM   #7
outlaw's Avatar
Trade: roofing,siding,gutters,windows
Re: Epdm Lap Seal
Lap seal should still be used in some cases were seam tape is also used.
If your membrane is re-inforced, all raw or cut edges should be cualked with lap seal to prevent water from wicking into the scrim and destoying the membrane.
www.clarkroofingandsiding.com
outlaw is offline
Old 08-26-2009, 01:26 PM   #8
A&E Exteriors's Avatar
Trade: Roofing, Framing, Finish Carpentry
Re: Epdm Lap Seal
Solar seal is the best caulk on planet Earth. I use it on all my roofs, slope or flat.
A&E Exteriors is offline
Old 08-26-2009, 04:22 PM   #9
GC
GrasshopperPete's Avatar
Re: Epdm Lap Seal
ALLIED carries this stuff...prob also the rest of the big guys.
GrasshopperPete is offline
Old 08-26-2009, 06:51 PM   #10
Tom Struble's Avatar
Trade: siding
Re: Epdm Lap Seal
cant get that stuff here in N.J. unless its in a 16 oz tube
you have to buy a special gun for it,has something to do with the e.p.a. and voc's
Tom Struble is offline
Old 08-26-2009, 07:27 PM   #11
Bah Humbug!
Grumpy's Avatar
Re: Epdm Lap Seal
I still use lap/edge sealant even with seam tapes. In addition, I saw a product last year in a mag but can't remember the name. It was a combination primer, adhesive and lap sealant all in one. I wanted to give it a try on a repair once to see how it worked. S best I could tell it was probably a neoprene caulk.
Grumpy is offline
Old 08-26-2009, 11:41 PM   #12
Re: Epdm Lap Seal
you could get real crazy and use cover tape.
Old 09-17-2009, 07:05 PM   #13
bradcorep's Avatar
Trade: Roofing Siding Windows Doors Decking
Re: Epdm Lap Seal
Geocel 4500 is some nice stuff. It acts as caulk, adhesive and it can completely cure under water. You wont have any cracking or peeling problems with this stuff. great for repairs or new installs
bradcorep is offline
Old 09-22-2009, 12:47 AM   #14
theflynner's Avatar
Trade: Roofng
Re: Epdm Lap Seal
I install a lot of Firesone EPDM, and you should avoid dependending on Lap Sealant - it degrades in the sun.
Firestone switched to a whole line of products called "Quick-seam" these are all details which are 2-sided tapes. Most of these items eliminate the need for lap-sealant.
-- Firestone Building Products/Technical Data Base
John in MN
theflynner is offline
Tags
roofing contractor, virginia beach
Correct Substraight for EPDM roof. Warmsmeallup Roofing 11 05-19-2009 05:56 PM
IceMelt on EPDM? tekwrytr Roofing 6 11-24-2008 03:53 PM
EPDM Questions big builder Roofing 21 10-11-2008 12:36 AM
EPDM and asphalt? tekwrytr Roofing 19 07-24-2008 08:46 AM
Pictures of aluminum edge flashing for EPDM roof ??? epdmHelpNeeded Roofing 4 10-28-2006 05:03 PM
