Eaves: Ice & Water Laying Over Metal Fascia
Old 07-27-2017, 07:52 AM   #1
Dairylander's Avatar
Trade: Renovator
Rewards Points: 43
I'm putting ice&water down first, then drip-edge, then synthetic over the drip-edge.
I want to run the ice& water a few inches down the fascia, but how would that meet the metal fascia?
If the metal fascia is installed after the ice&water, then water could creep behind and get to the sub-fascia.
If the metal fascia goes goes on first, then it would drain correctly?
It makes sense in my head, but I've never seen metal fascia go up first before any underlayments are applied.
Dairylander is offline
Old 07-27-2017, 08:03 AM   #2
Sean
SLSTech's Avatar
Trade: Principal / Owner
Rewards Points: 20
Re: Eaves: Ice & Water Laying Over Metal Fascia
I&W strip over wood fascia, drip edge....
As for metal fascia it goes between the drip & I&W that was wrapped
http://thehtrc.com/2013/getting-deta...-roof-flashing - scroll down about a third of the way to see how it is supposed to be
SLSTech is offline
The Following User Says Thank You to SLSTech For This Useful Post:
Dairylander (07-27-2017)
Old 07-27-2017, 08:05 AM   #3
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 290
It might be different there, but here I would never do that. I gutter guy would have a fit trying to get gutter up behind that . IPO I would do Ice and water over the drip on the eves then the underlayment if you want, then make sure the shingles are overhanging the drip maybe like 3/4 " or so . I have seen way to many roofs with the shingles flush with the drip , that can cause as much trouble as anything Just my 2 cents.
Randy Bush is online now
The Following 2 Users Say Thank You to Randy Bush For This Useful Post:
B.Johnson (07-30-2017), CrescentGutter (07-30-2017)
Old 07-27-2017, 08:28 AM   #4
water re-locater
NYgutterguy's Avatar
Trade: Gutter installer
Rewards Points: 1,052
Can't get sucked into another drip edge thread. lol.
NYgutterguy is online now
The Following 2 Users Say Thank You to NYgutterguy For This Useful Post:
Big Johnson (07-30-2017), Randy Bush (07-27-2017)
Old 07-27-2017, 08:37 AM   #5
Trade: Renovator
Rewards Points: 43
Originally Posted by NYgutterguy View Post
Oh no. Not another ice/water and drip thread.
I know, I know!
I found a thousand threads on ice&water going over wood fascia, but it's different over metal fascia.
Because to put ice&water over metal fascia, you have to have the fascia on first. But the fascia can only go up after the metal soffit. And I've never seen soffit up before the roof underlayment goes down.
It just seems out of order.
Old 07-27-2017, 10:54 AM   #6
Texas Wax's Avatar
Rewards Points: 694
Originally Posted by Dairylander View Post
I know, I know!
Up in the land of cheese, tyme machines, bubblers and the Dairy aire ... W&I over metal drips. Especally at the gutter edge.
Either way 'Go Wisconsin; Out drinking your state sinse 1848"
...as the page loads, so go the days of our lives, at CT
Texas Wax is offline
Old 07-27-2017, 11:12 AM   #7
Trade: Renovator
Rewards Points: 43
Hah! That takes me back! Nowadays, you'll need a time machine to find a tyme machine, they went the way of the dodo bird. But bubblers will live forever!
Old 07-30-2017, 06:36 AM   #8
Gutter Hanger
CrescentGutter's Avatar
Trade: Seamless gutters
Rewards Points: 593
Thanks Randy. We gutter installers are usually the step children of the industry. People do all kinds of weird stuff and then expect us to hang a gutter on it. Gutters are usually an afterthought.
Time loves to be wasted. From that waste there is no salvage. - Henry Ford
CrescentGutter is offline
The Following User Says Thank You to CrescentGutter For This Useful Post:
Randy Bush (07-30-2017)
Old 07-30-2017, 06:46 AM   #9
Big Johnson's Avatar
Trade: Contractor and Grunt
Rewards Points: 1,149
"•Place metal drip edges or wood starter shingles over the membrane."
I know nobody does this but that's what the manufacturers says.
• Do not fold over the roof edge unless the edge is protected by a drip edge, gutter or other fl ashing material.
https://gcpat-tools.com/construction...r%20Shield.pdf
Disclaimer: I'm not a roofer.
Big Johnson is online now
Old 08-04-2017, 08:40 AM   #10
Shingler extraordinaire
A&E Exteriors's Avatar
Trade: Roofing, Framing, siding, decks
Rewards Points: 10,366
Over the drip on the eaves and under on the rakes.
A&E Exteriors is online now
The Following User Says Thank You to A&E Exteriors For This Useful Post:
Randy Bush (08-04-2017)
Come on, Share some pictures of your work... Dyer Sandblasting 577 08-22-2015 10:31 PM
Water Pump in 5 gal Bucket or Tray??? DemRem Tiling 19 07-04-2014 02:48 PM
Why is wood rotting ? SKC Construction 44 07-23-2012 03:06 AM
Comments on replacing tank water heater with tankless CRIMPS Plumbing 3 12-04-2009 11:54 PM
Metal roof question Burby Roofing 11 01-22-2009 01:16 PM
