Easy Roof
Old 10-24-2004, 07:35 PM   #1
IR2
RookieContract's Avatar
Question
Easy Roof
Just wondering what you guys think. Im new so take it easy on me. I have a customer, who lives about 5 houses away (Connecticut) who wants his roof done. he is stripping it for me and wants me to put a new one on for him. 1520 square feet, 25 year architectural, one dormer with 2 valleys. one hip with two valleys, one septic pipe and one exhaust pipe. chimney also. i dont know him well, so i figured that $2320 would be a good price. what do you guys think? Any help would be greatly appreciated. Thanks
Joe
IR2
RookieContract is offline
Old 10-24-2004, 08:03 PM   #2
Grumpy's Avatar
Rewards Points: 2,000
Re: Easy Roof
Id do that if it was 3tab. I also dont think they make 25 year architecturals anymore. They were all upgraded to 30 a few years back, unless there is a company I am unfamiliar with still making them.
-Grumpy
Chicago Gutters Chicago Roofing
Grumpy is offline
Old 10-25-2004, 06:38 AM   #3
jmorgan's Avatar
Trade: Roofing
Rewards Points: 150
Re: Easy Roof
What's the slope. Seems a bit high for < 8:12.
Jim
jmorgan is offline
Old 10-25-2004, 12:20 PM   #4
IR2
Question
Re: Easy Roof
I am going to tell him that the 25 year are hard to get because they are discontinued, and it will be cheaper to go with 30 year because of that. the slope is about a 6/12. I figured about $145/sq, because its all being stripped for me, so I just have to lay it on and go. What difference should i make for 3tab and arch? Thanks again guys.
Joe Cleary Jr.
IR2
Old 10-25-2004, 02:28 PM   #5
Grumpy's Avatar
Re: Easy Roof
The difference should at least be the difference in material price. I don't think the price is too high. I think it's a few hundred low. Then again I charge alot more than most people do for new constuction, and that's essentially what you are looking at.
I guarantee the owner isn't going to have the roof prepped and ready to go, so all you have to do is shingle. I bet there will be wood that needs replacing, wood that needs refastening. Nails to be pounded in or removed, and probably broom sweep the deck.
I hate working when the home owner wants to get involved or buys materials etc... I usually pass on these jobs.
-Grumpy
Grumpy is offline
Old 10-25-2004, 08:38 PM   #6
Teetorbilt's Avatar
Re: Easy Roof
Grumpy, In roofing do you have to bring a reroof up to current code?
Teetorbilt is offline
Old 10-25-2004, 08:48 PM   #7
Grumpy's Avatar
Re: Easy Roof
I really hate re-roofs, as in lay overs. The answer is YES teetor, if the old roof isn't to code, but most codes are for underlayment, nails per shingles etc... These things are hidden.
many villages around here are getting smart and allowing one layer only. Chicago still allows 3,a nd no permit required
-Grumpy
Grumpy is offline
Old 10-27-2004, 11:14 AM   #8
Specialist's Avatar
Rewards Points: 25
Re: Easy Roof
Grumpy,
Castlebrook has 25 year architectural shingles. I put them on my roof this spring. Not too bad, good price(+/- $10.50 per bundle), look good.(well that's due to the installation more than the product)
Specialist is offline
Old 10-27-2004, 11:28 AM   #9
Teetorbilt's Avatar
Re: Easy Roof
Looks like I'm going to be a roofer, one job only, mine. All of the roofers that I trust are booked out over a year, that's another hurricane season away.
Just what I needed, another project.
Torch down(flat roof) leaks BAD...can you give advice ASAP? Detail Guy Roofing 22 01-05-2013 05:42 PM
Low Pitch Roof solutions Fixer Roofing 4 02-18-2007 10:09 AM
Help tying in this roof to addition jaymay75 Framing 0 06-18-2006 09:54 PM
Need help designing Roof for addition jaymay75 Framing 21 06-17-2006 09:47 PM
Do You Need A New Roof ??? Perfect Roofing Roofing 0 02-10-2005 01:46 AM
