Drip Edge Corner Installation
Old 05-10-2009, 01:59 PM   #1
jcs0009's Avatar
Trade: Residential Architecture
Working in Texas... Replacing Roofs damaged in Hail storms...
Some of our subcontractors are having difficulty cutting drip edges with no gaps at top around exterior corners. Should this be a cause of concern.
I have been told the way to avoid this is to use two pieces.
Id like to develop a visual of this process; to make these homes roofs better.
A. We are using metal drip edge from lowes. Its not a 90, its the more expensive stuff which bends 3 times; not an L more of a T...
B. It seems logical to me to cut pieces symetrically centered at gables first and work down lapping 6 inches under from top.
c. Another thing I am finding is a tendency to install all drip edges over felt.
I am printing manufacturer spec with pics in spanish in an attempt to solve this. I was wondering if this is maybe drip edge spec; or metal???
Anyone know what I mean?
Anyone care to share methods of explanation; for the subs?
My goal is to ensure warranty and help make buildings better.
Yes, I am learning spanish.
jcs0009 is offline
Old 05-10-2009, 02:15 PM   #2
Al Smith
A W Smith's Avatar
Re: Drip Edge Corner Installation
Not sure what you mean by gaps at top. A picture would help. You mean at the ridge? or at the rake end at the eave? Home centers don't carry much of the correct drip edge. I can use off the shelf stuff for rakes but I usually bend up my own at the gutter as the profile I need varies with different pitches. as far as felt I have read that some roofing codes in storm effected regions of the US are contradictory. Requiring felt both over and under the drip in some interpretations. Here in NJ not so much. At the rakes I put drip edge over felt but at eaves i put I&W over drip edge. I use shingle starter at rakes.
Al Smith
http://www.awsmith.com
A W Smith is offline
Old 05-10-2009, 02:42 PM   #3
jcs0009's Avatar
I mean at the top of the "T" at the corner of hips.
jcs0009 is offline
Old 05-10-2009, 02:55 PM   #4
Al Smith
A W Smith's Avatar
Hips? now I'm lost. Why would you put "drip edge" on top of a hip? Or do you mean around the corner at the gutter? You cant just cut the drip edge at an angle of the hip and intersect them?
Al Smith
Old 05-10-2009, 02:58 PM   #5
MrRoofer's Avatar
Trade: Roofing
At hip corners I will cut the roof 'leg' and the kickout 'leg', but not the vertical 'leg', and bend the metal around the corner. The trick is to make your cut's at the right spot so the drip isn't too tight to the fascia.
Preferred sequential method of installation otherwise is; Drip, I&W eavs valleys, Felt paper rest of the roof, Rake edge. Usually laps on drip and rake edges are minimal, about an inch. Otherwise those two layers of metal get noticable beyond appreciation
'I'm living on the edge!'
MrRoofer is offline
Old 05-10-2009, 02:59 PM   #6
Capra aegagrus
Tinstaafl's Avatar
I think a couple of pictures or drawings would come in quite handy here.
Tinstaafl is online now
Old 05-10-2009, 03:22 PM   #7
jcs0009's Avatar
The roof corner at the bottom of the hip... the top of the drip edge metal.
You can cut and bend the drip edge or you can cut one piece to length, stopping at end of facia trim, 1x2, then place next piece; question is how to bend this condition. And how to tell people who are speaking a different language what you want.
also does it matter? Second method looks better, but is it? There is shingle over corner and a hole seems to defeat the purpose...
jcs0009 is offline
Old 05-10-2009, 03:43 PM   #8
Al Smith
A W Smith's Avatar
Because its a slope in two different roof planes intersecting. There's no way to relief cut the top and bend it around the corner accurately. the metal wants to climb out and away from the facia at the same slope as the preceding roof plane. For a hip cut it slightly longer and cut and bend ears over the drip edge of the other roof plane.
Al Smith
Old 05-10-2009, 03:49 PM   #9
jcs0009's Avatar
Amerimax F 4.5" modified...
I cant post links yet.
Manufacturer uses gable examples; not hip/roof corner conditions...
I will post pics of two results soon..
jcs0009 is offline
Old 05-10-2009, 03:51 PM   #10
jcs0009's Avatar
thanks. ears... ok...
jcs0009 is offline
Old 05-10-2009, 03:57 PM   #11
Al Smith
A W Smith's Avatar
this one?
http://www.amerimax.com/product-drip...pEdgeStyleId=1
Al Smith
Old 05-10-2009, 08:34 PM   #12
MJW's Avatar
Trade: General Contractor, Roofing, siding, windows
Get better crews and don't nitpick. I'm pretty sure I know what you are talking about, but I'll wait for the pics.
MJW is offline
Old 05-10-2009, 08:40 PM   #13
Crock's Avatar
Trade: Fan of Bodger
ya you will still have missing material anyway you cut it. The only way is to join two pieces together at the apex of the outside corner. I hope to
God I'm wrong and someone has figured out an alternative way to cut it because thats my favorite edge to use.
Crock is offline
Old 05-10-2009, 10:00 PM   #14
house bldr's Avatar
Trade: general contractor
we refer to this as style D roof edge and just cut two ends at a 45 and join them at the corner---or you could relief cut and bend it around and slip a flat piece in from the back side to fill in the missing corner.
house bldr is offline
Old 05-11-2009, 01:58 PM   #15
jcs0009's Avatar
I really appreciate all the help you have provided.
Several ideas to solve this problem have been uncovered here.
Seems like there is not an industry standard.
I am asking Amerimax too.
Thanks,
jcs0009
jcs0009 is offline
Old 05-12-2009, 09:01 AM   #16
apehangeralfy's Avatar
Trade: Certified Roofing Contractor
At the corner you need to miter cut the drip or it will look like hell.
To start cut the first pc from the long point at a 45* angle on the overhang part of the drip.
Follow the 45* cut on the top of the drip and snip it off (the part that sits on the roof).
From the inside of the first cut move back .5" and snip the kick on the bottom.
Trim the face so you have an ear to fold at a 90* bend and install so the bottom is bit past the corner (just a hair) and nail in place.
The second pc. gets another 45* cut for the long point on the top overhang. Trim the top off.
Hold the drip in place so the long points match and mark the under/back side with a pencil.
Cut the pencil line and install.....
Hard to explain but I hope this helps....
apehangeralfy is offline
Old 05-12-2009, 09:04 AM   #17
J-Peffer's Avatar
Trade: Roofing & Siding Contractor
Exactly how I do it.
I hate when people "FOLD" them around the corners, you can see from the bottom a nice chunk where there is no drip edge.
J-Peffer is offline
Tags
corners, drip edge, gaps at drip edge corners
Drip edge vent ? Home Work Pro Roofing 8 04-17-2009 11:37 AM
drip edge ? wellbuilthome Roofing 67 03-27-2009 07:13 AM
Drip edge question-a little help advanced_energy Roofing 10 01-19-2009 07:45 PM
Drip Edge Tips J-Peffer Roofing 16 04-24-2008 11:56 AM
