Trade: building for 30 years. new homes , additions
Drip Edge ?
Dose every one use drip edge under there roofing ?
Ive worked in NJ for 30 years and we never used a aluminum drip edge on the perimeter of a shingled roof . In NY every one seems to use the drip edge ? I think i lost a job today because of the drip edge issue. Why use a drip edge. Why not . any insight . Thanks John |
Trade: siding
Re: Drip Edge ?
i like to see it when it installed well but your right here in NJ you dont see it often,what you do see is a kickout where the aluminium facia meets the roof shingle,a water trap if you ask me
Capra aegagrus
Re: Drip Edge ?
It's pretty universal in this area. One distinct advantage is that it makes wrapping the fascia a lot more forgiving.
Re: Drip Edge ?
It looks like a neater, tighter job, we do it sometimes, dont really think there is a practical reason for it . G
Re: Drip Edge ?
void
Trade: roofing,siding,gutters,windows
Re: Drip Edge ?
Almost nobody uses it here. Go 40 miles away and everybody uses it. I say use it to make yourself look different. When your competition doesn't spec it, ask the prospect what other corners they will cut.
Re: Drip Edge ?
We use it here all the time...at least the people I have worked around. Actually GAF recommends it. From their website:
The Importance of Drip Edge The drip edge is critical to provide a finished look and to add waterproofing Drips edges must be corrosion resistant Drips edges should be applied applied to edge along eaves On the rakes, drip edges are applied on top of underlayment Drip edges should be nailed as needed to hold into place
www.KirbyCustomHomes.com Last edited by 1mancrew; 03-21-2009 at 11:28 PM. |
Re: Drip Edge ?
Only saw it not used on one job. Never not installed it. Great for creating a clean appearance and protecting the fascia and roof sheathing from water damage.
Josh Jaros www.jarosbros.com Remodeling in The Woodlands, Texas |
Re: Drip Edge ?
I would use it on the rakes but what do we do with it on the bottom over the ice shield under the ice shield ? The inspectors in NJ want to see the Ice shield stuck to the fascia . John
#10 | |
Capra aegagrus
Re: Drip Edge ?Quote:
#11 | |
Not sure how to get by your inspectors unless you want to invite them up to inspect. Once adhered to the drip edge, it's waterproof and the drip edge will kick any water out away from the facia. Once they see how your doing it I would think they would also see the "light".
'The trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.' - Ronald Reagan |
Re: Drip Edge ?
PA,
If I'm understanding what your saying, how does that stop water in an ice dam situation? |
Re: Drip Edge ?
ONE caution on drip edge, when installing, do not butt the sections tight, leave 1/4'' space between the pieces, i have installed them tight only to have them swell and cause a bump to form at the roof edge at each seam, had to go up and relieve each butt joint. G
WICKED WOODCHUCKER
Trade: RESIDENTIAL CONTRUCTION, BUILDING & PROPERT MAINT.
Re: Drip Edge ?
I have never done a roof without it! To be honest I have never seen a roof without it either. Standard here in Maine
Trade: General Contractor, Roofing, siding, windows
Re: Drip Edge ?
Use steel drip edge and you won't have any problems. Put it on, then adhere the I&W to it. Lapping I&W into the gutter and such just doesn't work. I've seen it before and it just rots away and never sticks. Put the steel drip edge on and the I&W on it.
Re: Drip Edge ?
When using metal, have your inspector look up the instructions for I&W. It will clearly state to apply the drip edge first.
Trade: siding
Re: Drip Edge ?
actually there is a technique where you wrap the i&w around the facia apply the edge then use a 12'' strip of i&w ontop of the edge
Ed or Tinner could explain it better |
#18 |
KemoSabe
Re: Drip Edge ?
I like to bend my own drip-edge to match my trim coil, then the trim coil gets tucked securely behind the drip-edge. I hem the return on the bottom and predrill and nail up from the bottom with an aluminum asbestos siding nail. No visible face nails this way, never had a blowoff either.
__________________________________ "Walking the fine line between production and perfection" __________________________________ Last edited by loneframer; 08-15-2009 at 06:57 AM. |
#19 | |
Sure, you can do that, and it probably works. It's just that it makes the fascia and/or gutters harder to replace because it is stuck to it. |
#20 |
Trade: siding
Re: Drip Edge ?
ill sometimes use this technique in high wind areas or if my facia is large
i bend a starter pc i nail that to the edge of the facia over the soffit then i make basicaly a j shape in my facia and snap it in to the starter pc Last edited by Tom Struble; 08-06-2010 at 09:07 PM. |
| Unusual Drip Edge technique ? | JTW | Roofing | 15 | 01-31-2009 03:19 PM |
| Drip edge question-a little help | advanced_energy | Roofing | 10 | 01-19-2009 07:45 PM |
| Drip Edge Tips | J-Peffer | Roofing | 16 | 04-24-2008 11:56 AM |
| Drip Edge | pitterpat | Roofing | 6 | 08-30-2006 08:34 AM |
