Does All Gutter Seal Suck Or What?
Old 10-20-2010, 12:11 AM   #1
MikeGC's Avatar
Trade: All construction, remodeling, home improvements
Location: Rochester, NY Elmira, NY, WNY, Finger Lakes, Southern Tier
Rewards Points: 510
I have a tried two dozen gutter seal brands over the years with very disappointing results.
It does not seem to matter what it claims to do, whats in it or how much it costs.
What is your favorite brand and method of applying gutter seal to get consistent drip free results?
(For aluminum gutters)
MikeGC is offline
Old 10-20-2010, 07:37 AM   #2
nlgutters's Avatar
Trade: seamless gutters
Re: Does All Gutter Seal Suck Or What?
Geocell 2300
www.nlseamlessgutters.com
nlgutters is offline
Old 10-20-2010, 11:47 AM   #3
Grumpy's Avatar
Rewards Points: 2,000
Solar Seal polyurethane caulk works well.
-Grumpy
Chicago Gutters Chicago Roofing
Grumpy is offline
Old 10-20-2010, 12:05 PM   #4
Superior Firepower
skyhook's Avatar
Trade: GC HVAC/R Lic. since 1985
Rewards Points: 3,880
If you're not using it on fresh, new metal, before it gets wet or dirty, they are all going to suck.
skyhook is offline
Old 10-22-2010, 07:59 AM   #5
outlaw's Avatar
Trade: roofing,siding,gutters,windows
Rewards Points: 250
I'm a big fan of solar seal. It seems that with gutters, no matter which brand you use, you need to use a lot.
www.clarkroofingandsiding.com
outlaw is offline
Old 10-22-2010, 09:04 AM   #6
AAA Gutter's Avatar
Trade: Seamless gutters
Rewards Points: 75
Geocel 2320 gray, use plenty
AAA Gutter is offline
The Following User Says Thank You to AAA Gutter For This Useful Post:
seeyou (10-25-2010)
Old 10-22-2010, 09:28 AM   #7
RooferJim's Avatar
Trade: roofing
never liked any geocell products very much. for gutters the best is Alcoa gutter seal . "liquid solder" . dosent work well though when its below freezing.
RooferJim is offline
The Following User Says Thank You to RooferJim For This Useful Post:
superseal (11-01-2010)
Old 10-23-2010, 10:48 AM   #8
mpvoss's Avatar
Trade: Landscaping
Rewards Points: 25
I use Ruscoe 12-3 with great results.
mpvoss is offline
Old 10-24-2010, 03:34 PM   #9
Gutter Hanger
CrescentGutter's Avatar
Rewards Points: 593
Another vote for Geocel 2320. White on white gutters and clear on other colors.
CrescentGutter is offline
The Following User Says Thank You to CrescentGutter For This Useful Post:
seeyou (10-25-2010)
Old 10-24-2010, 05:01 PM   #10
Grand Rapids Remodeling
Paulie's Avatar
Rewards Points: 2,052
Sub it out with seamless gutters. No seams to fail.
Paulie is offline
Old 10-24-2010, 07:04 PM   #11
Gutter Hanger
Rewards Points: 593
There are still end caps, corner miters, etc. that need sealing.
Old 10-24-2010, 08:35 PM   #12
Tom Struble's Avatar
Trade: siding
Rewards Points: 4
anytime i work with sealing gutter metal i always pre clean with alcohol or brake cleaner
Tom Struble is offline
English Roofer (10-26-2010)
Old 11-01-2010, 09:27 PM   #13
AAA Gutter's Avatar
Rewards Points: 75
UMM, you are putting it on the inside, right?
Old 11-01-2010, 09:37 PM   #14
davitk's Avatar
Trade: Perfessional Contracter
Rewards Points: 502
davitk is offline
Old 11-01-2010, 09:42 PM   #15
Jeff
jkfox624's Avatar
Trade: master turd burglar
Rewards Points: 502
Whenever i use it i end up with it inside my shirt, tool belt, nose and anywhere else my fingers end up. Does that count?
jkfox624 is offline
Old 11-01-2010, 11:19 PM   #16
Eater of sins.
ScipioAfricanus's Avatar
Trade: Designer/Drafter Extraordinaire
Rewards Points: 966
Like rooferjim already said, this is the best stuff no doubt. Alcoa Gutter Seal.
http://www.vintagetrailersupply.com/..._p/vts-138.htm
Andy.
ScipioAfricanus is online now
Gutter Apron Install Advice Gladiatorx Roofing 2 08-13-2010 03:36 PM
Foam seal sealer dvd Framing 9 10-15-2009 05:39 AM
Epdm Lap Seal thorroofer Roofing 13 09-22-2009 12:47 AM
Gutter Setup? guttersbyryan General Discussion 14 11-14-2008 04:57 PM
ice shield at gutter line? Grumpy Roofing 38 09-08-2008 08:22 PM
