Cutting Birds Mouth
Old 08-21-2008, 12:27 PM   #1
Dodge 3500's Avatar
Trade: framer
Cutting Birds Mouth
Hey I am building a barn and I am trying to figure out how to cut my bird mouths. I need one at both ends of my raffters, I am just using ruff cut 2x8 for raffters and and 3 laminated ruff cut 2x8s for beams. The top beam will be at 16' and the bottem at 10' the run is 12 and the rize is 6'. So when I go to step off my birds mouth do I use 6" and 12" on my square?
Dodge 3500 is offline
Old 08-21-2008, 02:11 PM   #2
tinner666's Avatar
Re: Cutting Birds Mouth
Yes. When the pitch is set or known, all cuts are the same.
Frank Slate Roof Repairs, Richmond, Va.
tinner666 is offline
Old 08-21-2008, 03:40 PM   #3
orson's Avatar
Trade: Kitchen & Bath
A framer posting a framing question in the roofing section?
orson is offline
Old 08-21-2008, 03:59 PM   #4
I was gonna say something,
but I don't want to go 'round
with my cynicism showing.
Maybe he is a "framing consultant"?
neolitic is offline
Old 08-21-2008, 05:18 PM   #5
genecarp's Avatar
zipping my mouth, and leaving
genecarp is offline
Old 08-21-2008, 05:38 PM   #6
Brock's Avatar
Trade: Residential Remodeler
Don't reccomend birds mouth on both ends of any rafter. With a 2x8 you want a good 4 inches height-above-plate (HAP) for your cuts. The other end will have your common pitch cut. Don't forget to factor in you ridge thickness for your rafter measurements.
Brock is offline
Old 08-21-2008, 07:08 PM   #7
Plumber / Carpenter
Bill's Avatar
Trade: Virginia Building and plumbing contractor
Send a message via Yahoo to Bill
Hey, this is a family site, watch what is showing
Is it beer thirty yet
Virginia Department of Licensing
Virginia Plumbing Codes
Bill is offline
Old 08-21-2008, 07:50 PM   #8
Yessir....now kindly point the
pistol some where else!
neolitic is offline
Old 08-21-2008, 10:14 PM   #9
RooferJim's Avatar
Trade: roofing
what
RooferJim is offline
Old 08-21-2008, 10:14 PM   #10
RooferJim's Avatar
Trade: roofing
what kind of bird are you refering to ? can you cut that with a hook blade ? in jest of course.
Old 08-22-2008, 08:23 AM   #11
Dodge 3500's Avatar
Trade: framer
Not really a framer more of a farmer! Thanks for your help guys.
Metal cutting circular saws??? nwksremodeler Tools & Equipment 17 05-04-2008 07:29 PM
best 26 & 29Ga cutting tools nwksremodeler Tools & Equipment 4 04-22-2008 11:18 PM
Bird's Mouth/ Heel Cuts in stick built roof framing DEAD_ONConst Framing 34 03-27-2008 05:29 PM
proper way of loading of brush from a cutting pail Zeebo Painting & Finish Work 7 08-11-2006 11:58 PM
Determining Manhours for rolling vs. cutting - your suggestions would be helpful Zeebo Painting & Finish Work 9 06-02-2006 06:12 PM
