Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Roofing
Old 09-03-2009, 08:28 AM   #1
Trade: engineer
Corrugated Metal Roof Decking
I have a job that originally spec'd 20 gauge N deck. Now a concrete roof will be poured over the roof decking and the contractor changed the decking to a 20 gauge "Q" deck. I cant find spec's for a Q deck anywhere. Is is the same as B? Is is sufficient to hold the weight of the concrete with 7 foot spans?
Engineerz is offline   Reply With Quote
Old 09-03-2009, 09:57 AM   #2
3" deep type N deck is also known as Q-Deck.
Can't you just ask the contractor who the supplier is, and get the info from them.
Kgmz is offline   Reply With Quote
Old 09-04-2009, 07:57 AM   #3
Trade: engineer
n vs. q
I specified 20 gauge 3" N deck, he used 20 gauge, 1-1/2" "Q" deck.
Old 09-04-2009, 09:54 AM   #4
Originally Posted by Engineerz View Post
Is it sufficient to hold the weight of the concrete with 7 foot spans?
I would ask an engineer
Anti-wingnut is offline   Reply With Quote
Old 09-05-2009, 05:18 PM   #5
Commercial Roofing
AaronB.'s Avatar
Trade: Roofing Contractor
Find the manufacturer and get the max span from them and find out the max weight for said span.
Picking up the slack
www.roseroofing.net
Metal Roof Rehabilitation, Commercial Roofing, Polyurea Roofing Systems, Commercial Spray Foam, Leak Detection and Repair
AaronB. is offline   Reply With Quote
Metal Roof - Contractor Lie? CER Roofing 9 11-02-2009 08:04 PM
Metal Roof OVER shingles? MHMConstruction Roofing 9 12-22-2008 10:14 AM
Roof Estimating And Drawing Program Ed the Roofer Roofing 0 07-03-2008 12:53 PM
Ice guards for metal roof Chimney Monkey General Discussion 1 11-09-2006 08:11 PM
Torch down(flat roof) leaks BAD...can you give advice ASAP? Detail Guy Roofing 21 01-16-2006 02:36 PM
