Condensation On A Tin Roof
Old 02-18-2007, 06:54 PM   #1
mikeybobo's Avatar
Trade: residential remodeling
I'm a carpenter, and my experiance with tin roofs is limited due to the fact that they aren't that popular anymore in my area. I recently purchased my first house, and it has an old tin roof. There dont appear to be any leaks, but during the fall when my wife and I were looking at it, there was a ton, and I mean a TON of condensation on the underside of the tin roof. When I say ton, I mean you can see all the moisture stains on the ceilings of the rooms below. (obviously going to be renovated) Now there is no insulation in the upstairs ceiling, or in the rafters, or in walls for that matter..... quality construction in the 1920's I also noticed that the attic is not vented what so ever. Correct me if I'm wrong, but its probobly the heated air inside the house and the cold air outside making the condensation. I was just wondering if any of you roofer guys have heard of this and have any input. Thanks
mikeybobo is offline
Old 02-18-2007, 08:14 PM   #2
dennis's Avatar
Trade: Roofing
Re: Condensation On A Tin Roof
You've got it right. Hot air on a cold tin roof. You need insulation and ventilation.
dennis is offline
Low Pitch Roof solutions Fixer Roofing 4 02-18-2007 11:09 AM
Help tying in this roof to addition jaymay75 Framing 0 06-18-2006 10:54 PM
Need help designing Roof for addition jaymay75 Framing 21 06-17-2006 10:47 PM
Torch down(flat roof) leaks BAD...can you give advice ASAP? Detail Guy Roofing 21 01-16-2006 02:36 PM
Do You Need A New Roof ??? Perfect Roofing Roofing 0 02-10-2005 02:46 AM
