Commercial Roofing Labour %
Old 01-26-2011, 12:57 AM   #1
Roofing Contractor
Jason-F's Avatar
Trade: Roofing
Rewards Points: 264
Hey guys I was trying to make some projection sheets up and was hoping someone could share what percentage of the gross price of a job is generally attributed to labour expense. This is in regards to flat roofing projects only. I know everyone works with different products when it comes to flat roofs and a solid labour budget would be a great help to pricing jobs accurately.
www.remstarroofing.com
Jason-F is offline
Old 01-26-2011, 07:04 AM   #2
jmiller's Avatar
Trade: Roofing
Rewards Points: 1,002
Re: Commercial Roofing Labour %
We put in our first commercial bid yesterday (after being invited hundreds of times over the years) and it was pretty exciting for us. I'm only mentioning this because it's likely I'll put my foot in my mouth:
Why is it any different from residential? The numbers might be higher if you're paying prevailing wage, but do you not still figure materials+labor+O&P?
jmiller is offline
Old 01-26-2011, 01:32 PM   #3
Roofing Contractor
Jason-F's Avatar
Trade: Roofing
Rewards Points: 264
Well for my purposes I figure Materials + Labour * (O&P). Labour % is a varriable that can be calculated as a fixed cost for specific tasks only.
The numbers are not the same as they are for residential roofing becasue it is a different task, Just as you can expect your labour to account for a larger part of your budget if you are Shingling a roof, as aposed to installing metal.
Example. for shingle installation install is expected to consume 25% of the gross cost, and materials 40%, leaving me with my
When I do metal the materials usually come in around 50% and labour drops to 15%
In my case I know I can buy a ft of tpo for 100$, but i dont know what it will cost me to install that ft, so i can't calculate a accurate estimate.
Can someone please shed some light on this,
Jason-F is offline
Old 01-28-2011, 03:05 PM   #4
Grumpy's Avatar
Rewards Points: 2,000
Jason I'd like to give you a magic answer but none does exist.
I have been told by commercial roofing suppliers and manufacturers that I shouldn't be marking up the materials, only the labor. Hmmmmm. Now I will say most people have no idea what it costs them to run their business. I'll also say that the way you markup is actually meaningless unless you know what it costs you to run your business. Furthermore, the manner you use to markup absolutely does not matter what so ever so long as it meets with your necessary overhead and profit target.
I personally feel that you can only use a % markup on an average kind of job. If the job is not average, then your % will be flawed unless adjusted to reflect your over head and profit target. I can give you numerous scenarios how or why this is... An interesting article, if I do say so myself since I wrote it, you may want to read is: How Much Should I Charge?
The method I use is a little convuluded. I markup labor once, then I markup the overall gross costs of goods sold (labor, material, rental fees, permits, etc...) again. I do this because I recognize the logic behind what you are asking. I can sell some high end materials that may take me no longer to install than the cheaper flimsier materials. Marking up only the gross cost of goods sold may make me way too expensive in this case. However marking up only the labor and not the other expenses involved may cause me to be too cheap and not reach my desired overhead and profit target. This markup formula is done in my spreadsheet automatically so I had only need to figure it out once.
However I can tell you even the flaws in the system I use. Therefore in addition after running the spreadsheet, I reverse engineer the pricing. I say how much will it cost me to do this job, how long will this job take to do, how much does it cost me to run my business, and I just do a reality check to ensure that my pricing is realistic and my formula not flawed. In school they called this "checking your work."
If you know your material cost but not your labor rate and not your overhead target, you are like a captian at sea with no compass and no stars to navigate. You'll just be guessing. Furthermore my profit target may be too low or too high for your business structure, so it's impossible for anyone of us to really give you an answer any better than just a guess.
-Grumpy
Chicago Gutters Chicago Roofing
Grumpy is offline
The Following 2 Users Say Thank You to Grumpy For This Useful Post:
Sar-Con (01-29-2011), seeyou (01-30-2011)
Old 01-29-2011, 04:56 AM   #5
Roofing Contractor
Jason-F's Avatar
Trade: Roofing
Rewards Points: 264
Very good response but, mabey I should simplify here. This is not a "what should I charge scenario." I am not asking about overhead or material costs either.That(as im sure you know) varies too much by region to be answered in a global forum. Labour costs generally remain the same though as tradesmen across the contry make comparable wages.
I am wondering as a average what portion of a gross sale should be resonably attributed to labour expense. Labour only. Forget about Materials and overhead,markup and all the other jazz.
If I was to sell a roof for X amount of dollars, What would it be resonable for me to assume labour of the tearoff and new install to cost me 20% of the contract? Mabey flat roofing is very difficult to install and time consuming, and it would it be fair to expect that a crew would cost me 50%. Im just looking for a number I can resonably assume, a starting point for say. I would hate to hire a sub crew and be negotiating blind, I am just looking for a % i can derive from the principal as a realistic expectation of labour cost.
Jason-F is offline
Old 01-29-2011, 07:36 AM   #6
Grumpy's Avatar
I disagree. And here is why. If you have a 2 man crew you ened to markup the labor more than if you have a 12 man crew.
It really is impossible to answer the question you are asking because some jobs might be mostly labor with very litle material like a repair for example, or a project using very premium high end materials.
If you are trying to figure out how long a job will take based on the material costs, don't. If you are trying to figure out how much to charge for the whole job simply based on the material costs, don't. Truly material costs have nothing to do with labor and material costs vary from job to job, therefore it'd be impossible to say that labor is 20% of the job.
For example this November, I did two very similiar jobs in terms of size and scope. Tear off roofs on 100 year old buildings about 4" thick and install new fiberboard and new single ply. One was .045 TPO and the other was .080 PVC. The labor was the same. The material costs were signifigantly higher with the PVC roof.
I somewhat think you are going about this all wrong, now that I understand why you are asking. My suggestion would be to request a price list from your subs first. If they've done it before they know what they need to charge. If don't know what to charge, maybe they haven't done it before. If you are asking how long it takes to install TPO, well, I figure on a new construction wide open commercial job each skilled roofer will yield 10 squares per day complete. If you use that number as your starting point you can derive your cost per square to pay the sub. If you say the sub is worth $45 an hour that's $45 x 8 hours = $360 / 10 squares = $36 a square. If you pay your sub more or less than $45 an hour, that $36 a square won't work, so do the math with your own numbers. If the job is not so wide open maybe they'll achieve 8 squares a day so then again the numbers change.
-Grumpy
Grumpy is offline
Old 01-29-2011, 07:54 AM   #7
Sar-Con's Avatar
Trade: Civil Construction, Excavation, Concrete + Forming
Rewards Points: 504
Perhaps in what you're doing you can generalize like that, but with my line of work you'd loose your shirt on some jobs and not get the rest of them...
With so many variables our labour ranges from 20% to 80% job to job depending on our scope.
Don't get me wrong, I use averages all the time, but usually for checking estimates and budgeting potential work. It's all about knowing your costs and applying averages appropriately.
Every company is different, every job is different, and when you're pricing work, only thing that matters is your company and that job!
Sar-Con is offline
Old 01-29-2011, 09:35 AM   #8
General Contractor
greg24k's Avatar
Rewards Points: 7,238
What ever you come up with, divide by $Tree Fitty and you will have the magic number
greg24k is offline
Old 01-29-2011, 01:40 PM   #9
Roofing Contractor
Jason-F's Avatar
Trade: Roofing
Rewards Points: 264
Good point grumpy, Now I understand your point. usually when I quote I do estimate man hours and then add percentages so it all works the same.
Is that a real number, should i realisticly expext 1000 ft a day per man? what about on a roof requering a tear off?
Jason-F is offline
Old 01-30-2011, 03:06 AM   #10
Grumpy's Avatar
Thae 10 squares per day per roofer on a new construction is an average realsitic number for an average job based on a 5 man crew with 4 roofers and one helper. From that crew I'd expect a 40 square day. For tear off.... man I can only give you a long complex formula because most of our tear offs are 4" thick, 3-5 layers, possible have a few layers of rock... We might get 3 squares a day per man production, to make it water tight, but not complete. tear off is an animal unto its' self and each and ever tear off job is unique.
When I am pricing a job I based my tear off price by setup, layers, and dum fees. If I a tearing off a roof 4" thick that is 4 layers of old BUR and 2 layers of pea gravel, I charge for 6 layers of tear off. Then based on my experience I make an educated guess as to how many dumpsters will be needed. It can be averaged out into some kind of forumal easily for example layers x squares = total squares to be torn off. Then determine how many squares can fit in a yard of dumpster space and you have your formula for future use.
-Grumpy
Grumpy is offline
Old 01-30-2011, 10:24 PM   #11
Roofing Contractor
Jason-F's Avatar
Trade: Roofing
Rewards Points: 264
Thank you, this is exactly what I needed as a start point.
Jason-F is offline
Commercial Construction Spreadsheet Help?? SBI Commercial Construction 16 12-17-2010 10:17 AM
Illinois Roofing License Exam kaconrad Roofing 7 11-20-2010 07:55 PM
Certainteed Announces Industry-First Photovoltaic Training for Roofing Contractors Grumpy Roofing 16 09-05-2010 07:55 AM
CertainTeed's Shreveport Roofing Plant Paves the Way to Greener Operations, Recycling Grumpy Roofing 0 08-12-2010 09:19 AM
Bison Roofing - Louisville Roofing Contractor Bison Roofing Introductions 0 03-22-2010 02:05 PM
