Cold Weather: Heat Shingles W/Electric Matress Pad/Blanket
Old 10-29-2017, 08:40 AM   #1
MrCreosote's Avatar
Trade: Masonary
Rewards Points: 76
Going to try:
Throw the blanket/pad over the pallet of shingles, then a couple blankets/quilts and finally a tarp. Start heating 2 days in advance.
Has anyone done this?
Comments, advice, and ridicule welcome (!)
Thanks in advance...
MrCreosote is offline
Old 10-29-2017, 11:05 AM   #2
Peter_C's Avatar
Trade: Home Beautification
Rewards Points: 6,320
Re: Cold Weather: Heat Shingles W/Electric Matress Pad/Blanket
Are you trying to catch them on fire? Heating blankets have an auto shut down after around 10 hours.
Best solution would be to find a heated place to store them.
Peter_C is offline
The Following User Says Thank You to Peter_C For This Useful Post:
MrCreosote (10-30-2017)
Old 10-29-2017, 12:12 PM   #3
mstrat's Avatar
Trade: New Construction & Remodeling
Rewards Points: 1,400
Originally Posted by MrCreosote View Post
Going to try:
Why? I venture to say by the time you get them on the roof and open the package, unless you're lifting and installing one bundle at a time, if it's cold enough to need that they'll be cold again before you use them?
mstrat is offline
The Following User Says Thank You to mstrat For This Useful Post:
Old 10-29-2017, 12:49 PM   #4
B.Johnson's Avatar
Trade: Builder
Rewards Points: 968
We used to get ours frozen together like a brick because the lumberyard stored them outside. If I called ahead of time they would move them inside for me and thaw them out.
Home Designer Series Software
B.Johnson is offline
The Following User Says Thank You to B.Johnson For This Useful Post:
Old 10-29-2017, 03:57 PM   #5
MrCreosote's Avatar
Trade: Masonary
Rewards Points: 76
The issue is the large mass of shingles will reach an average temp, so if the daily temp range is 30 to 50, they will be about 40. If I can heat them up to 50, then on a 50 degree day high, I'll be good to go.
I have a heated garage 50 ft away. Don't like the idea of moving them an extra 100 ft.
As far as an electric blanket goes, they are 75-100watts per side so there is no risk of too much heat - in fact, a couple 100w light bulbs inside the pallet would help too. The 10 hour automatic shut down is an issue.
I'm looking at portable electric baseboard heaters: 24in 400w 120v for $35 - I could put one on each side using the pallet itself for a cold air return. And just a crude box or tent to contain the heat. They can be had as high as 750w @ 36in for about the same money.
Old 10-29-2017, 07:33 PM   #6
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
wait till spring...
Tom Struble is offline
Old 10-29-2017, 07:45 PM   #7
mstrat's Avatar
If the daily range is 30-50? Shoot, I thought we were talking about 0 temps! Doesn't sound like it'd be worth the hassle you're putting into it! A good shingle on a sunny 30 day will seal just fine...warming it up 10 doesn't seem like it'd do anything worthwhile?
mstrat is offline
Old 10-29-2017, 08:04 PM   #8
VinylHanger's Avatar
Rewards Points: 7,282
The last big roof I did solo was I. December/January. I was wearing overalls, gloves and an Elmer Fud hat and it would freeze at night.
No issues, just put them down. Especially at 40 or 50 degrees.
Not really sure what the problem is. Besides, don't you want the roof stacked. I don't carry shingles anymore.
VinylHanger is online now
Old 10-29-2017, 08:05 PM   #9
mstrat's Avatar
Agreed...heck, I even paid to have 4 squares delivered the other day for a small porch we built!
mstrat is offline
Old 10-29-2017, 11:34 PM   #10
MrCreosote's Avatar
Trade: Masonary
Rewards Points: 76
Yeah, I'm doing this PITA solo. I could split the job into halves and do the 2nd one in the spring. I could work in any temp drying in the 2nd half but I'm using Deck Armor and I'm a bit concerned that some people say "never again" would they NOT tarp it.
So I could be shingling in winter. Won't know until I "get" there. (I'm near Pittsburgh so there will be snow. Talk is of a warm winter which would be a big help.
Just planning ahead with the shingle heating method...
Old 10-30-2017, 05:46 AM   #11
B.Johnson's Avatar
Trade: Builder
Rewards Points: 968
If you are going to be going slow and possibly take all winter I'd put them in the garage.
Can't really complain about the heat after reading this.... Leo G Off Topic (Non Trade) 0 07-31-2015 10:31 AM
Cold weather air compressor hillbilly512 Tools & Equipment 16 12-30-2014 09:35 PM
Cold weather health tip... Robie Health & Safety 6 11-20-2014 06:55 AM
cold weather and pets boman47k Off Topic (Non Trade) 24 01-09-2010 10:29 PM
