Clapboard Doesn't Last
Old 05-18-2009, 12:24 PM   #1
onlinehandyman's Avatar
Trade: Flooring
I have been lurking this board on and off for a while gaining valuable information - thank you!
Now a question finally came up and I was hoping someone might be able to give me an idea about what is going on.
I have had this job fixed several times and never does it seem to last. The clapboard on one of the dormers on my house will not stay on. I have had several companies repair it and never does it make it through the winter.
I have attached a picture and was hoping someone might be able to give me an idea of why this was happening.
Thank you in advance.
onlinehandyman is offline
Old 05-18-2009, 12:31 PM   #2
Re: Clapboard Doesn't Last
The siding should be cut
an inch above the shingle line,
and the pointed end of the cut
should be clipped.
I can't really tell what's
going on with the flashing, but
it looks fishy too.
neolitic is offline
Old 05-18-2009, 12:41 PM   #3
solar guy
naptown CR's Avatar
Trade: solar contracting
should be clipped.
it looks fishy too.
I agree with neo however add prime and paint the lower cut edge before installation too.
naptown CR is offline
Old 05-19-2009, 11:32 PM   #4
Trade: Flooring
Just to make sure that I get it done right next time I am assuming that cut an inch above the shingle line means where the 2 over lap there should be an inch overlap. The part that I do not quite understand is "pointed end of the cut should be clipped".
I very much appreciate your help guys - thanks!
Old 05-19-2009, 11:38 PM   #5
solar guy
naptown CR's Avatar
No this means that there should be an inch of space veritcally between the roof shingles and the bottom of the siding. the clipped corner refers to when you cut this there will be a pointy end where the top of the cut piece of siding is. Clip this back to prevent water running dpwn the roof from getting onto the top edge of the siding
Old 05-19-2009, 11:38 PM   #6
genecarp's Avatar
WICKING.....
genecarp is offline
Old 05-19-2009, 11:46 PM   #7
solar guy
naptown CR's Avatar
Originally Posted by genecarp View Post
WICKING.....
absolutlely i would recommend fiber cement but that could be a pain in the a** to miter the corners.
Old 05-20-2009, 12:00 AM   #8
Working
Cole82's Avatar
Send a message via AIM to Cole82
The water might be running into that metal corner trim piece and stopping. Then when stopped it freezes and pops you siding board off. After cutting back the siding and making shure the water has an exit at the bottum. I would reroof and add some over hangs to that house and dormer.
Cole82 is offline
Old 05-20-2009, 10:48 AM   #9
Trade: Flooring
Thanks guys for all of your help! I now have a much better understanding of what needs to be done. I am a contractor myself, but as you can see quite the other end of the house from the roof. Thanks again!
Old 05-20-2009, 02:24 PM   #10
Smart phone? Scan me!
nEighter's Avatar
Trade: Painting/Framing/Drywall
all your siding is caulked to the roof
nEighter is offline
Old 05-20-2009, 03:53 PM   #11
Trade: Flooring
Is that not correct nEighter? I didn't do this job - I just know that I continue to keep having it repaired and would like to get a handle on having it done RIGHT which I am beginning to understand!
Old 05-20-2009, 06:06 PM   #12
nEighter's Avatar
You see that flashing (the metal)? You would side this coming down the roof line, leaving 1" of clearance from the roofing material to the bottom side of the siding. That flashing protects water from getting into the house. By caulking the siding to the roof, you are asking for trouble. All it takes is one spot of that caulking to fail.. then it might as well be a water balloon. and the layers down the river will fail.
nEighter is offline
Old 05-21-2009, 01:43 PM   #13
Trade: Flooring
Thanks nEighter and I got to tell all of you guys - I really learned a lot here and you were all very helpful and really nice about helping someone not in your particular trade. Now I have the knowledge to make sure that it is done right the next time. Thanks again guys!
Spraying Foam Insulation Wolfgang Insulation 8 01-03-2009 03:44 PM
Cedar clapboard sidewall/roofing tie in remoguy Roofing 4 10-16-2007 08:24 PM
Filling Clapboard? JNLP Painting & Finish Work 6 11-27-2006 06:37 PM
Did I miss something ? (Clapboard) Rich Windows, Siding and Doors 21 03-26-2006 11:03 AM
White Cedar Shingles and Red Cedar Clapboard Rich Windows, Siding and Doors 3 03-19-2005 08:38 AM
