Built In Gutter Repair Question
Old 12-19-2007, 07:34 PM   #1
Home Serve's Avatar
Trade: siding windows soffit fascia
On a job today replacing windows and doing other work I noticed a problem on a older house I would like to try and help them with (young new home owners).
The house has been remodeled by a true hack and sold to these folks. The roof is new but the built in gutters were not repaired. They are leaking back into the soffit and down the walls and out the siding. The ice of course has made it worse. When we removed one window in the area and it was soaked from the situation.
I'd like to help them deal with the issue if possible. We do have a bending brake and I could picture possibly using it to flash the interior of them but would wonder how to bond the pieces together in a waterproof fashion and so forth.
It is a small house, probably about 60' of built in gutter.
Got some ideas for me?
Thanks,
Dave C
Missouri Remodeling Company with services for Replacement Windows Vinyl Siding and Entry Doors
Home Serve is offline
Old 12-19-2007, 07:36 PM   #2
Patrick's Avatar
Re: Built In Gutter Repair Question
Ive seen them lined with copper and the seams soldered
Patrick is offline
Old 12-19-2007, 07:47 PM   #3
We did a "temporary" re-line with aluminum,
just a tight 12" lap slathered brush on geo-cel between for the whole 12".
There was @ ½" fall in 10',
but that was 10 years ago, and they are still work.
neolitic is offline
Old 12-19-2007, 07:54 PM   #4
Patrick's Avatar
Yea Geocel is great stuff, expecially the brush on, Another great use for it is under patio doors.
Patrick is offline
Old 12-19-2007, 09:45 PM   #5
Home Serve's Avatar
I remember using geo-cel many years ago now. I'm thinking you can get it in a can to brush on. It is good quality and I believe it would work if we take our time and are careful. There aren't any corners so that should help. The ice will be off the roof tomorrow so I'll take a closer look at it.
Thanks for the help all who posted.
Dave C
Old 12-19-2007, 09:58 PM   #6
To be sure I was clear,
what we did was form 10' sections of coil into a squared off "U",
to make a liner.
Just didn't make any fancy seams--simple laps.
Geo-cel was just to "glue" them together.
neolitic is offline
Old 12-19-2007, 10:19 PM   #7
Home Serve's Avatar
to make a liner.
Yeah, I thats what I figured you were talking about and that was how I was going to do it also. I think it will work well.
Thanks,
Dave C
Old 12-21-2007, 09:34 AM   #8
dennis's Avatar
Trade: Roofing
"Got some ideas for me?"
1. Call a qualified roofer with experience soldering and installing copper built-in gutters.
or
2. Find the holes in the existing gutter, clean them well, apply geocel.
Then, call a qualified roofer with experience ...
dennis is offline
Old 12-21-2007, 10:01 AM   #9
Bah Humbug!
Grumpy's Avatar
We do quite a bit of these repairs and repalcements. First you can reline them, but understand in doing so the new liner will be more shallow, and I have seen downspouts back up and into the space between the original and the new liner.
Second, you can try to identify the problem areas, clean, prime and patch with EPDM roof membrane which seems to work well, but if one spot is bad the rest soon will be, and this only a temporary repair.
If it were my house, I would tear back the first few rows of shingles, remove the existing and install brand new. I'd use copper or galvanized because both can be soldered, and each piece can be no longer than 10' so there will be alot of solder joints.
If you are relining or replacing, it really takes a lot of thought to get the pitch just right. It's not hard, just have to think and rethink before you bend each piece. If you don't you will either have standing water within the gutter or a really jacked up looking new system.
BTW I hate Geocel. It might stick and last, I don't know, but I prefer Vulkem.
Also I don't warrant patch repairs. Reason ebing although MY patch will last, more leaks will pop up and rather than convince the owner it's a new leak; I just tell them this will work for a short while and then you will need to replace it.
One other thing I have bid, but not done, was to rivet metal over any holes, then reline the entire gutter with solvent or urethane (NOT ACRYLIC) based elastomeric. Again no warranty, although I couldn't see this gutter leaking any time soon.
Grumpy is offline
Old 12-21-2007, 10:22 AM   #10
Originally Posted by Grumpy View Post
....Also I don't warrant patch repairs. Reason ebing although MY patch will last, more leaks will pop up and rather than convince the owner it's a new leak; I just tell them this will work for a short while and then you will need to replace it. .....
That's what we said....and why I'm so pleased and amazed that it lasted so long.
or
Hmmm.
First time I tried that I got 6 different gutter guys who had no clue about "dutch gutters".
Most couldn't even wrap their heads around the concept that the original was made of poplar.
Either wanted to cram 4" rolled ogee's in to replace 6",
or rip the facade down and make it shiny new!
The fun ones are when the leader is buried in the wall!
neolitic is offline
Old 12-21-2007, 12:42 PM   #11
Ed the Roofer's Avatar
Trade: Roofing Contractor
Another solution, which was slightly hinted at by Grumpy, is to line the exiting inlaid gutters with an elastomeric coating and a fibeglass or polyester reinforcement mesh with a bottom and top coat of the elatomeric. This needs to go under the shingles on the high side and over the shingles on the low side.
It has to be clean and dry for it to hold. On the lowere side, which should be going over the shingles, you can decoratively cap the elastomeric memberne with some color clad sheet metal.
Ed
Ed the Roofer is offline
Old 12-21-2007, 02:39 PM   #12
Charitable animal
Bone Saw's Avatar
Trade: decks
Thanks,
Dave C
tell em to hire a roofer who does custom pole gutter work
Bone Saw is offline
Old 12-21-2007, 02:42 PM   #13
tinner666's Avatar
Soldered copper or leaded copper in 2' lenghts, as specified for copper Built-in gutters. Hire a pro.
Frank Slate Roof Repairs, Richmond, Va.
tinner666 is offline
Old 12-21-2007, 07:11 PM   #14
Home Serve's Avatar
or
I am as qualified roofer as these customers need to do a repair on their built in gutters. I simply know that like most other issues there are several different methods of repair.
These folks aren't lawyers with heavy checkbooks. If knew someone as you describe in #1 and could trust them to perform the repairs at a reasonable cost this might be an option. However, this simply is not case in this situation, if it was I would not have asked the original question.
As I described the problem originally, your answers don't do much for me.
Many of the other responses have offered some real answers to the issue.
Thanks guys,
Dave C
Old 12-21-2007, 09:14 PM   #15
Rather than calling guttering contractors, I would suggest contacting a reputable sheet metal fabrication and installation shop, who have guys who know how to solder properly.
You will have better luck contacting them for the proper level of talent required.
Most gutter guys just know how to pump out seamless and hang them as fast as they can.
Ed
Old 12-21-2007, 09:16 PM   #16
dennis's Avatar
Trade: Roofing
"Many of the other responses have offered some real answers to the issue."
I see 4 for doing it with copper, 1 option for epdm lining, 1 for aluminum smeared with geocel, 1 for coating and mesh. Not sure what bone saw meant.
Notice the terms, temporary, no warranty.
I agree, there are different methods of repair. And different repairs will last different periods of time. And cost different amounts of money.
I was just trying to give the best option. It's your job and you will do it the way you want.
My option #2 would allow for a low cost temporary repair while the home owners saved up the money for a permanent solution later. (if they actually saved and did the work instead of waiting till the window rotted out again)
Another option would be a PVC membrane liner. Costs less than copper but would do a better job than aluminum and sealant.
neolitic,
notice I didn't say " gutter guy". I think you would be hard pressed to find a "gutter guy" that could spell solder.
dennis is offline
Old 12-21-2007, 09:33 PM   #17
Home Serve's Avatar
neolitic,
Thanks! Dennis I guess I just had one of them days, I thought you were just being a smart a**.
Dave C
Old 12-21-2007, 09:36 PM   #18
Hey, I guess I spelled "solder" right.
Woo-Hoo!!!
Ed
Old 12-21-2007, 09:42 PM   #19
Charitable animal
Bone Saw's Avatar
Trade: decks
I meant to tell them to hire a roofer who does pole gutter work or dig up your seamers, tongs, irons and salamoniac and do the job right
Bone Saw is offline
Old 12-22-2007, 12:46 AM   #20
Expert Roofer
theroofinggod's Avatar
Trade: ROOFING/HOME IMPROVEMENTS-WINDOWS/SIDING/GUTTERING/COPPER WORK,ETC
Send a message via MSN to theroofinggod Send a message via Yahoo to theroofinggod
we`ve lined them with copper, peel-n-seal,app,sbs,epdm,etc,and installed new drain sleeves with it,except for obvious holes the drain sleeve is usually where the leak
"If it`s worth doing.It`s worth doing right!!!
www.ADVANCEDROOFINGNEWYORK.com
theroofinggod is offline
The Following User Says Thank You to theroofinggod For This Useful Post:
Tom Struble (02-25-2009)
built up slab question stampcrete Concrete & Paving 9 03-27-2008 05:24 PM
pergo floor repair question painterofeveryt Flooring 8 08-24-2007 05:41 PM
Stupid Question about drain holes in built up walk Jacey Concrete & Paving 6 04-01-2007 04:53 PM
6" Gutter question carlspackler Roofing 7 03-31-2006 10:38 PM
Ok, ceiling repair Question Knyte260 Drywall 18 10-23-2005 01:15 AM
