Trade: roofing
Boots For Overhead Lines??
I'm getting tired of getting a roof done. Coming back the next day or so to meet the electric guy so he can cut the power so I can install the boot cover. How do you guys approach this? Anybody ever use those split boots and if so how do they hold up?
Rock it...
Re: Boots For Overhead Lines??
I have never had them cut the power, just used those fully plastic boots that have a plastic base as well, then cut it straight up from the bottom, then us this plastic welder cement that melts it back together, it takes like 45 seconds. I dont really like the plastic boots but havent had a problem yet.
www.battleridgebuilders.com |
I like Green things
I get split ones or lead ones.
Warner Remodeling ll Auburn Indiana Remodeling ll Dekalb County Remodeling ll Custom Woodworking Auburn Indiana Warner Remodeling Facebook |
Trade: roofing
Re: Boots For Overhead Lines?? |
#5 | |
Re: Boots For Overhead Lines??Quote:
Lead, you can bend and seam lots of ways.
Trade: Siding, Metal Roofs, and Beer Drinking PRO
I get the rubber with lead base ( for pro or R panel) and spit them myself at a 45 on low side then overlap and seal with butyl ( I seal all jacks with it) nothing against sparkys but id rather not have to wait on em nor pay them. I respect but am not skeered of power lines
APPLIED RIGHT
Trade: roofing
"A Roof is only as good as it is Applied" |
Bah Humbug!
I have done a number of things.
Dope? Naaa that cracks and leaks but I have done it in repair situations, reluctantly. Wrap the conduit with ice shield, buy a lead plumbling pipe flashing 1" larger in diamater than the electric pipe, split it, fit the lead around the conduit, caulk between the conduit and lead where the seam will be in the lead. Wrap and secure with hose clamps and if you're really really really good at soldering you can solder the solft lead closed. Also try... http://portalsplus.com/retrofit_flash2_110.htm |
Trade: Roofing
I use two boots. Cut the first one at the top, put it around the pipe then take a second one and cut it at the bottom and put it over the first boot. It only makes sense. Use a little geoseal and you will never have a leak nor have to wait for a electric company.
#10 | |
Trade: GC/Remodeling
may have to try that one
-Steve "The most beautiful thing we can experience is the mysterious. It is the source of all true art and science." ~ Albert Einstein |
| nailing into gas or freon lines | Javelin350 | Windows, Siding and Doors | 15 | 10-10-2009 10:16 PM |
| Work Boots | Gilby | General Discussion | 28 | 05-18-2009 02:45 AM |
| Plumbing air compressor lines | CNC | Plumbing | 6 | 02-07-2009 02:47 PM |
| Danner Quary boots not as good as I thought | ALCbuilding | Tools & Equipment | 14 | 10-16-2008 08:08 PM |
| Painters wear boots and you gotta believe me | slickshift | Painting & Finish Work | 29 | 12-21-2007 08:09 PM |
