Best Way To Clear Ice Off New EPDM Roof??
Old 12-10-2008, 05:08 PM   #1
big builder's Avatar
Trade: home builder
Rewards Points: 77
The title just about says it all.
We now have 4 feet of snow here and ice underneith.
What type of products don't affect EPDM...... Salt or another ice melter?
I see guys using the torch. Can't be good for the rubber though.
Any ideas?
big builder is offline
Old 12-12-2008, 09:41 AM   #2
Trade: home builder
Rewards Points: 77
Re: Best Way To Clear Ice Off New EPDM Roof??
Uh oh.
Nobody wants to touch this one.
We need to get some sleepers down but there is quite a bit of ice there now.
Is it safe to use an ice melter product ........salt.....or something else?
Old 12-12-2008, 11:07 AM   #3
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 2,045
Not sure what sleepers are doing on a rubber roof (probably my definition is off). I've put down a few roofs like that, but never fooled with 'em at all in cold weather. I'd be reluctant to even walk on them if deeply frozen.
Too much ice to shovel it off and hope for a sunny stretch to clear it? Tent it with tarps and run a torpedo heater? I think I'd call the manufacturer for recommendations on any use of salt/chemicals.
Tinstaafl is offline
Old 12-12-2008, 11:19 AM   #4
Handle It!
MALCO.New.York's Avatar
Rewards Points: 2,000
Any method that does not include high heat, a scraping motion or chemicals!
Does not leave very many options!!!
Sorry!! But dem be da facts!
Ultimate Wisdom---------
MALCO.New.York is offline
Old 12-12-2008, 11:26 AM   #5
Burby's Avatar
Trade: Remodel / repairs / Certified Mold inspector, Remediator
Rewards Points: 250
As long as careful with the torch, the water will prevent the torch from causing damage. Don't heat enough to boild the water from the melted ice.
Depending on roof size.
What about shoveling off the snow and if possible use a water hose to melt the ice & have guys follow with the use of floor squeeges to dry off the rubber.
As far as salt, check with manufac to be safe, it shouldn't hurt, if used to melt the ice enough to break up and rince off after. but ya know about assuming.
Building up North dealing with snow & ice we used water hoses & squeegees several times to keep the jobs going.
A lot depends on size of roof, how much time you have, and accesibility to water and or cost you want to put into clearing it off.
Nice thing about winter, it does end, the sad thing is, it does return
Proud to help make a house your Home
Never judge another by one's own intelligence
Burby is offline
Old 12-12-2008, 04:02 PM   #6
APPLIED RIGHT
johnk's Avatar
Trade: roofing
Rewards Points: 250
Break up ice with a hammer and either sweep or squeegee it up.
"A Roof is only as good as it is Applied"
johnk is offline
Old 12-14-2008, 05:11 PM   #7
Trade: home builder
Rewards Points: 77
Yes, So I called FIrestone and they said no problem with using salt. Won't hurt the roof at all.
We are putting a wood deck on top of the epdm so we need the sleepers to reverse the fall of the roof.
We cover the bottoms of the sleepers with extra rubber left over so there is no wear thru issues.
Going to do it toomorrow. Hopefull it works good.
Old 12-15-2008, 07:21 AM   #8
Grumpy's Avatar
How was the insulation under the epdm fastened? Better hope with adhesive or the deck will rip a hole through the epdm at the fasteners.
-Grumpy
Chicago Gutters Chicago Roofing
Grumpy is offline
Roof Estimating And Drawing Program Ed the Roofer Roofing 32 03-07-2011 09:50 AM
Ballast Removal from EPDM Roof? tekwrytr Roofing 26 06-19-2009 04:12 PM
Low Pitch Roof solutions Fixer Roofing 4 02-18-2007 10:09 AM
Pictures of aluminum edge flashing for EPDM roof ??? epdmHelpNeeded Roofing 4 10-28-2006 04:03 PM
Do You Need A New Roof ??? Perfect Roofing Roofing 0 02-10-2005 01:46 AM
