Bastard Hip With Common Overhang
Old 12-02-2015, 08:42 PM   #1
deedledeedle's Avatar
Trade: carpenter
Rewards Points: 24
hi guys,
-from new zealand so some terminology may be different to yours!
we have to build a few trusses and pitch a roof with a bastard hip after christmas and i'd like a bit of feedback if you see any red flags in my description
the main roof is 29 degrees and the bastard is 39 degrees
on the inside of the building there are several exposed hardwood trusses,the top and bottom chords being 12x8 and the king/queen posts 8x8
we have a main truss at 29 degrees each side,a half truss at 39 degrees and 2 hip trusses at around 24.5 dgrees all coming together and sharing a common kingpost
directly on top of these trusses is the ceiling lining of t&g oak and immediately above that our roof framing (10x2),the ceiling lining will be fastened directly to the rafters.
there is a common height soffit (overhang?) and fascia all around this area,the overhang is also the same-6 inches
this brings me to my problem-the differing roof pitch gives me different plumb cuts on my rafter tails but i need to make it the same
if i put my 3x2purlins(battens?) on edge instead of flat on the steeper pitch this brings the plumb measurement to almost the same(close enough to not worry about)however this has the knock on effect of mowing the hips forward? or does it? i'm having problems visualising it!
any comments?
deedledeedle is offline
Old 12-02-2015, 09:03 PM   #2
Sure, I can do that...
jlhaslip's Avatar
Trade: carpentry/renovations
Rewards Points: 232
Send a message via Skype™ to jlhaslip
Re: Bastard Hip With Common Overhang
I could spend a bunch of time replying here, or just post this link for you.
Money well spent.
http://www.amazon.com/Roof-Framers-B.../dp/0964335433
jlhaslip is online now
Old 12-03-2015, 03:14 AM   #3
Walraven's Avatar
Trade: carpenter/joiner
Rewards Points: 364
First welcome and where about's in NZ are you from
Also flat soffit or raking?
Do you see someone skilled in their work? They will serve before kings.
Walraven is offline
Old 12-03-2015, 03:20 AM   #4
Trade: carpenter
Rewards Points: 24
living and working in the queenstown area-seems like summers arrived at last
the soffit is flat.
Old 12-03-2015, 03:49 AM   #5
Walraven's Avatar
Rewards Points: 364
Do you need equal depth soffits?
Walraven is offline
Old 12-03-2015, 04:01 AM   #6
Trade: carpenter
Rewards Points: 24
yep,both 6" and the soffit lining is 3 1/2" cedar t&g so anything beyond a minor difference will stand out
Old 12-03-2015, 04:09 AM   #7
Walraven's Avatar
Rewards Points: 364
you could set your plates higher on the steeper side that should keep your fascia lined up and soffit depth even.
Walraven is offline
Old 12-03-2015, 04:15 AM   #8
Walraven's Avatar
Rewards Points: 364
Like this
Walraven is offline
Old 12-03-2015, 04:17 AM   #9
Trade: carpenter
Rewards Points: 24
could do but would that not lift the rafters away from the trusses?i'd then have to put firings on the undersides of the rafters for the linings?-i need a common ceiling line.
problem is if i was building this i'd adjust to suit as i was building but i'm going to have to explain this to one of the guys and i want it solved in my head before anythings cut-the timber for the trusses is about $350 pm!and a 3 month lead time!
hows work up there? good chippies are impossible to find down here at the moment,building is going off
Old 12-03-2015, 04:21 AM   #10
Walraven's Avatar
Rewards Points: 364
We are so busy booked out 2016 already, huge shortages of tradesmen as well.
Walraven is offline
Old 12-03-2015, 04:42 AM   #11
Trade: carpenter
Rewards Points: 24
Money well spent.
if that was available in metric i'd probably order now!
Old 12-03-2015, 06:55 AM   #12
Framer53's Avatar
Trade: Handyman
Rewards Points: 242
Can you not use conversion?
I know that our Canadian friends use metric and the convert.
Framer53 is offline
Interesting/ most common languages in USA Reg Off Topic (Non Trade) 2 05-15-2014 07:59 AM
Common Rafter Length - SpreadSheet Texas Wax Framing 11 12-25-2012 01:01 AM
hip VS common parkers5150 Framing 26 10-10-2012 06:32 PM
common chemical question--- davinci General Discussion 5 02-02-2011 10:17 AM
Does Honeywell TH8110 require common connection for backlight always on? Electric_Light HVAC 7 09-01-2010 05:58 PM
