03-24-2008, 09:50 PM
#1
Trade:
Siding, Windows, Seamless Gutters, Metal Roofing
Base and Cap Sheet Install Temp
How warm does it need to be for Base and Cap Sheet to be installed properly. Label says 50 Degrees, Im dying to get it on, although the days seem to only hit 40 at noon
Originally Posted by Celtic
Like I said...I'm sure you are very good at what you do ~ whatever that is and where ever it happens.
03-24-2008, 10:03 PM
#2
Supercilious Roofer
Trade:
Roofing
If its with hot or torch down 40 and sunnys ok. If its peel and seal or cold adhesive a little warmer would be nice. Especially if its a light color sheet.
03-24-2008, 10:17 PM
#3
Trade:
peel and seal. over a sun room, is there a big difference going white vs black? is the temperature difference that great, does one tend to last longer?
03-24-2008, 11:26 PM
#4
Roofing and Architectural
Trade:
Roofing and Architectural Metals
The times we install peel and stick less than say 60 degrees out, we use either a heat gun or a torch to warm it slightly and it does very well. Be very careful, you only want to WARM it, not get it hot. 80 pound roller behind it is a must for a proper job. It doesn't take much heat to get it to adhere very nicely, but it also doesn't take much more than that to burn it too.
03-25-2008, 12:38 AM
#5
Commercial Roofing
Trade:
Roofing Contractor
how are the flashings adhered with those peel and stick sheets? doesnt seem like it would do very well.
www.roseroofing.net
Our Seamless Membrane Roofing Systems outperform. Our Seamless Spray Foam Roofing system pays for itself. Call for your free project analysis. 815-588-1401 All roofing maintenance and repair available.
03-25-2008, 12:57 AM
#6
Trade:
set in mastic
03-25-2008, 06:43 AM
#7
Trade:
There will be no flashings on this set up, it ties into the house under an eave. The rolls are attached to the drip edge with glue
03-25-2008, 08:59 AM
#8
Supercilious Roofer
Trade:
Roofing
When putting it down black will heat up on a sunny day and stick better.
A white roof will be significantly cooler on hot sunny days than a darker roof.
And in turn should last a bit longer.
03-25-2008, 10:53 AM
#9
Commercial Roofing
Trade:
Roofing Contractor
In everyone's opinion (those that have used the SA products), do you think that these products are viable alternatives to heated modified bitumen products?
www.roseroofing.net
03-25-2008, 12:42 PM
#10
Trade:
There is a lot of technolgy with adhesives. Example: ( a type of silly putty for adhering tiles on the space shuttle ) Another example:, 'Grace Ice and water Shield' , Just change the surface to be UV resistant and there you have it.
I have a friend who manages an older commercial roofing company where I am at and he says there pretty good, but I take what he says with a grain of salt, I have caught him in his own BS before.
I saw on the TV the other night where in the ancient far east ( over 2000 years ago ) they used bitumen for adhering bricks together
Me, I have not used any SA but I try to keep an open mind.
03-25-2008, 08:33 PM
#11
APPLIED RIGHT
Trade:
roofing
I would never use peel and stick on a completely flat surface,there must IMO be a good run-off(1 1/2-2/12 pitch min) and then still heat the seams
03-25-2008, 08:38 PM
#12
Trade:
its a 3 that im dealing with.
03-25-2008, 09:13 PM
#13
APPLIED RIGHT
Trade:
roofing
Great to hear that,shouldn't be any problem,good luck!
03-25-2008, 11:24 PM
#14
APPLIED RIGHT
Trade:
roofing
"A Roof is only as good as it is Applied"
03-25-2008, 11:28 PM
#15
Commercial Roofing
Trade:
Roofing Contractor
Yeah, the only products I think I would use on a truly flat roof would be CTP or polyurea.
www.roseroofing.net
| Thread Tools |
Search this Thread |
| Display Modes |
Rate This Thread |
Linear Mode
