Attaching Plywood For Roof Sheathing? Screws?
Old 07-26-2007, 11:25 AM   #1
Can't Post
sandyman720's Avatar
Trade: Construction
What size and type of screws are best to attach plywood over roof rafters?
sandyman720 is offline
Old 07-26-2007, 03:01 PM   #2
Bah Humbug!
Grumpy's Avatar
Re: Attaching Plywood For Roof Sheathing? Screws?
Screws? I've never used screws on plywood. Why not nails? Usually 8 penny.
Grumpy is offline
Old 07-26-2007, 03:16 PM   #3
reveivl's Avatar
Trade: Renovations
I use 2" galv ring shank nails out of the spiker.
reveivl is offline
Old 07-26-2007, 05:35 PM   #4
nixfix's Avatar
Trade: Roofer
we use atleast 2 1/4" to 2 1/2" screws to put down 1/2" inch plywood or OSB, but most of the time we use 2 3/8" coated coil nails also known as #8's for hand nailing.
nixfix is offline
Old 07-27-2007, 07:42 AM   #5
MJW's Avatar
Trade: General Contractor, Roofing, siding, windows
A sheathing stapler is the fastest. That is all that is used here. Use 8's or 16's to tack them, then hit 'em with the stapler.
MJW is offline
Old 07-27-2007, 09:08 AM   #6
Thom
thom's Avatar
yup, that's the way it's done here also. Just don't skimp on the staples.
thom is offline
Old 07-28-2007, 11:31 PM   #7
Expert Roofer
theroofinggod's Avatar
Trade: ROOFING/HOME IMPROVEMENTS-WINDOWS/SIDING/GUTTERING/COPPER WORK,ETC
Send a message via MSN to theroofinggod Send a message via Yahoo to theroofinggod
coil nailer,use ring shank 8d,screws don`t have the same strength,specially if a tree hits the decking the screws will break the nails won`t
theroofinggod is offline
Old 07-29-2007, 10:41 AM   #8
2ndGen's Avatar
Trade: Thoroughbred Roofer
Ditto TRG.
Coil gun it with 8D nails.
Fast, cheap and strongest way to go.
2ndGen is offline
Old 07-29-2007, 12:54 PM   #9
Ed the Roofer's Avatar
Trade: Roofing Contractor
I follow the code requirements and the spacing and attachment methods listed by the APA, American Plywood Association.
8 penny coil nails, usually with ring shank and spacing with clips or at least a 10 penny nail.
12 " OC on interior sheet rafters and 6 " OC on exterior perimeter rafters of each sheet.
Ed
Ed the Roofer is offline
Old 07-29-2007, 04:19 PM   #10
MJW's Avatar
Well, when we use staples up here, they are about 2 inches apart if that, in most spots. I'm sure they'll hold just fine.
Higher wind areas of the country may require ring shank nails though. I'm not sure.
MJW is offline
Old 07-29-2007, 06:18 PM   #11
troubleseeker's Avatar
Never screwed the plywood roof decking on. 2" (8d) galvanized ring shanks with a nail gun. Believe me, you don't want to have to remove one of these sheets when fastened at the proper nail spacing.
I personally do not like staples because I don't have any confidence in the longevity of the wire gauge.
troubleseeker is offline
Old 07-29-2007, 07:45 PM   #12
tinner666's Avatar
Don't trust any fastener driven 1/2way through the decking!
Sometimes, all the holding power is concentrated in the bottom ply! Less than 1/8" of material!
Frank Slate Roof Repairs, Richmond, Va.
tinner666 is offline
Old 07-29-2007, 11:38 PM   #13
Expert Roofer
yeah ,I think the head on the nail ,is the "coup de grace"
Old 12-21-2010, 02:42 PM   #14
glenndacho's Avatar
Trade: Residential Commercial Design Build Remodel
osb stiffer than plywood ?
glenndacho is offline
Old 12-21-2010, 03:39 PM   #15
MrRoofer's Avatar
Trade: Roofing
Things have changed a lot in over three years eh?
'I'm living on the edge!'
MrRoofer is offline
Old 12-21-2010, 03:48 PM   #16
Level 27 Contractor
Bastien1337's Avatar
Trade: Renovation
I use screws but then again i dont do much roofing usually repairs for small areas or maybe if its part of a small deck job. i just go with that cos ive got em out already.
Sebastian
Visit my Facebook page here -http://www.facebook.com/photos.php?id=118626348206095
Bastien1337 is offline
Old 12-22-2010, 12:13 AM   #17
Roofsafe's Avatar
Trade: Residential roofing
I walked on a plywood sheathed deck a few years ago after getting used to the OSB decks, there was so much popping and snapping of the wood that I didn't know if I wanted to go to the ridge or just get back down and let someone else do the roof. I had to talk myself into staying up there because this was a regular customer. The CDX plywood wasn't as strong as I remembered it being in the past, my first trip off the roof was aboard a sheet of plywood just laying on the deck, what a ride. That was also my first day on the job in construction.
Anyway, I did the roof but I think I'll stick with OSB sheathing, there aren't any voids that I have ever found, and it seems to be stronger than 1/2 inch plywood, unless you buy 5/8 or 3/4 inch stuff. But the Canadian stuff is the best.
Roofsafe is offline
Old 12-22-2010, 01:01 AM   #18
Doofenshmirtz Evil Inc.
JumboJack's Avatar
What in the world is up with all the zombie threads latley....
in texas with framing and cornish people will do it for 3.00 a foot. What do yall think about that? Just laber
JumboJack is offline
The Following User Says Thank You to JumboJack For This Useful Post:
TimNJ (12-22-2010)
Old 12-22-2010, 08:32 AM   #19
rjconstructs's Avatar
Trade: Residential remodel
This seems to be a beginners question. How long have you been doing construction?
rjconstructs is offline
Old 12-22-2010, 08:35 AM   #20
jmiller's Avatar
Trade: Roofing
three.year.old.thread.
jmiller is offline
no plywood? phinsher Roofing 28 04-18-2010 06:48 PM
How many screws does it take to secure a door jamb? Dustball Remodeling 28 02-21-2008 05:03 PM
Exterior Wall Sheathing in B.C., Canada? wallmaxx Framing 9 01-21-2008 01:10 AM
Bending/Stripping Cabinet Screws RizzoMaryland Carpentry 27 03-23-2007 10:18 PM
MDO as both siding & sheathing karma_carpentry Carpentry 8 07-30-2006 09:35 PM
